BMW 3-Series (E90 E92) Forum
Bimmerlabs 330i Tune DIY Step by Step
| 08-04-2020, 12:52 PM | #89 |
Rep 7,212
That sounds odd. Which "stock file" are you flashing? There's one that was an unmodified 330i file I was using for testing, I think I will remove that - but you should be able to start with the stock 330i file (downloaded as .bin), modify it and then upload it so you can get the batch flash. What happens if you flash the stock ZB#? My wife took the E90 on a road trip, so I can't test it myself right now.
KClemente145.00 |
| 08-08-2020, 05:28 PM | #90 | |
Rep 6
| 08-15-2020, 07:40 PM | #92 |
Rep 2,025
Drives: 2008 E92 328xi
Flashed 330i tune and swapped one of my 3 stage manifolds with refreshed disas in this forum member's e92 m sport. At first it ran weak while throwing codes for all 4 o2 sensors, we checked the connectors and all and the codes stayed then we reset adaptations and the codes went away for now it seems. The car still has a SES with no codes except for the 2fa3 which my car has too and shouldn't trigger the light. The car began to run way better after resetting and I hope it gets to how it should be after a bit of driving.
Is the service engine light on normal after resetting adaptations? Is resetting engine adaptations required for the car to run right after the tune/swap I didn't do it on mine and have had no issues. |
| 08-16-2020, 02:19 PM | #94 |
Rep 2,025
Neither did I at all but I didn't reset anything. Reminds me of my N54 days when you'd have an SES and no codes. I think it'll go away though since the car is driving much better now without codes.
| 08-16-2020, 06:30 PM | #95 |
![]() ![]() ![]() 99
Rep 406
Drives: S54/N52
So in short, is this tune recommended for non 3SIM'd cars as well?
And DISA codes for no DISAs actually present will remain in the system until they are installed with 3SIMs? |
| 08-16-2020, 08:43 PM | #97 | |
Rep 2,098
But more to point, after codes were cleared you still had the SES light? |
| 08-16-2020, 09:14 PM | #98 |
Rep 2,025
I had it without the 3 stage it ran very good of course I understand it's not ideal for what it's tuned for. The car has a service engine soon light after resetting adaptations but no codes in the DME at all except for the one you get with the 330i tune. The 4 o2 codes went away. The light wouldn't go away by clearing. I'll check with him in a few days and scan the car again
| 08-16-2020, 11:49 PM | #99 | |
Rep 200
Drives: 16 X5,06 e91 325ix,03 Mini R50
I will (hopefully) have the time to to install the manifold this week (need to inspect and test the DISA valves first, before pulling the single stage manifold) |
NICKSIL0.00 |
| 08-21-2020, 04:05 AM | #100 |
![]() 112
Rep 125
Just came across this thread and starting poking around on bimmerlabs website too. Thank you E92William for posting the video (i too would have shat a brick seeing those errors come up!) and hassmaschine for the website and support. Are there any tunes available for the 330i to delete out O2 sensors? I'm considering going catless in the next little bit since I'm reaching that mileage where they need to be replaced.
Current: e92 335i 6MT RB Twos Hybrid Turbos, Relocated Inlets, Walbro 450, RB PCV, PE Mod, FBO | Former: e90 330i 6MT + e46 330ci 5MT | IG: @Axel.Koast |
| 08-21-2020, 09:58 PM | #101 |
Rep 2,098
Hey hassmaschine Did you do something new to MSV80 3IM ver 0.9.07? I got the new IAT installed and went to reflash the NoMAF version. Saw that there was a new version 0.9.07 (from my original 0.8.97) and when everything was done and I had cleared the mass trouble codes...I noticed I hadn't gotten the 2FA3 code. Not that it wasn't a big deal to clear once we knew how (or that it was a real problem to begin with), but interesting that it doesn't come up.
...or is that just some sort of personal site update marker and I just got a weird placebo effect :P Last edited by bluewater328; 08-21-2020 at 10:19 PM.. |
| 08-22-2020, 01:09 PM | #102 | |
![]() 145
Rep 222
RSA Delete followed by stock flash (7623405) and it still results in a crank no start. I'm not the one to say anything about it but its similar to a checksum error. For the tune file I created, I used WinOLS to find hex addresses for specific maps I want and port it over to tunerpro on an xdf I created. I normally work on MSD80/81 so it's pretty similar terminology. If i use the vanilla winkfp without any batch flashes, I would have to flash the stock ZB# 2-3 times in order for the car to fire up. It must be flashed at least 2 times even though the first flash goes through without any error. Note: I don't believe it's my tune file as the car still won't start up even with batch flashing the stock file.
Cars give me headaches.
| 08-27-2020, 12:00 PM | #104 | |
![]() 2477
Rep 4,328
post the error messages you sent me, but I responded in the PM with the instructions to import the datens into winkfp, which is what your errors are related to. basically winkfp doesn't know how to talk to the module because the datens aren't installed correctly. |
| 08-27-2020, 12:44 PM | #105 | |
![]() 82
Rep 246
Drives: 2006 330i Manual
.The only issue I'm still having with the zed is inpa doesn't display the zusb numbers for any modules in case it fails to flash. |
| 08-27-2020, 01:57 PM | #106 |
![]() 6
Rep 37
Thanks for the replies guys!
Below is the error message. [C:\EC-APPS\NFS\BIN\MSV80.ctl] [19.08.2020, 21:47:31] [MULTIFLASH] MF_FG_NUMMER= MF_PABD=12msv80.ipo MF_PSGBD=12MSV80.prg MF_SG_ADR=12 MF_NAAB_DATEI= MF_PROGRAMM_DATEI=MSV80_RSADelete_0049QK0MI20S.0pa MF_DATEN_DATEI= MF_DIAGNOSEPROTOKOLL= HW interface activted. PABD set. P-SGBD set. INFO000=Error: Error 106: Error on setting ECU-Adress. Please check: Interface, PABD, P-SGBD INFO001=Error: Error 2000: Error LFCDHDIA.CPP (12msv80.IPS/IPO) CDHapiResultText 1 Error in EDIABAS or in ECU description file (SGBD) SYS-0010: Initialization error 12MSV80 INFO002=Error: Error 2000: Error COAPI2.CPP coapiRunCabd 6 Error in EDIABAS or in ECU description file (SGBD) SET_ECU_ADDRESS INFO003=Error: Error 2000: Error COAPIKF.CPPcoapiKfSetGlobalPabdSgbdEcuAddr 5 Error in EDIABAS or in ECU description file (SGBD) Run SET_ECU_ADDRESS Job Error: ECU-Address could not be set! ERG=Programming not ok. Fatal Error Batch mode ended Press any key to continue . . . It sounds like I can flash the stock tune with WinFPK and the car should be ok? Are there any issues with this as the RSA Delete crashed while flashing? I will try this out later today, just do not want to keep going down a further rabbit hole and creating more problems. |
| 08-27-2020, 02:21 PM | #107 | ||
Rep 2,098
| 08-27-2020, 08:42 PM | #109 |
![]() 6
Rep 37
I imported the daten files to winfpk per the instructions provided by nsjames. It started to flash, got to 15% and then I got the following error message.
Press any key to continue . . . [C:\EC-APPS\NFS\BIN\MSV80.ctl] [19.08.2020, 21:47:31] [MULTIFLASH] MF_FG_NUMMER= MF_PABD=12msv80.ipo MF_PSGBD=12MSV80.prg MF_SG_ADR=12 MF_NAAB_DATEI= MF_PROGRAMM_DATEI=MSV80_RSADelete_0049QK0MI20S.0pa MF_DATEN_DATEI= MF_DIAGNOSEPROTOKOLL= HW interface activted. PABD set. P-SGBD set. ECU-Address set. Data and/or program and/or NAAB file set. Program will be programmed. INFO000=Error: Error 211: Error on flash programming! INFO001=Error: Error 2089: PABD 05MSV80 Programmieren 2544 switching programming mode failed 12MSV80, DIAGNOSE_MODE (ECUPM): ERROR_ECU_SECURITY_ACCESS_DENIED__SECURITY_ACCESS_ REQUESTED INFO002=Error: Error 2084: PABD 05MSV80 FlashSchreiben 1448 Flash download failed 12MSV80, FLASH_SCHREIBEN (...): ERROR_ECU_INCORRECT_BYTE_COUNT_DURING_BLOCK_TRANSF ER INFO003=Error: Error 2084: PABD 05MSV80 Programmieren 3247 Flash download failed 12MSV80, FLASH_SCHREIBEN (...) INFO004=Error: Error 2084: Error COAPI2.CPP coapiRunCabd 6 Flash download failed SG_PROGRAMMIEREN INFO005=Error: Error 2084: Error COAPIKF.CPP coapiKfProgSgDevelop 4 Flash download failed ERG=Programming not ok. Fatal Error Batch mode ended Press any key to continue . . . Any ideas? |
| 08-27-2020, 09:12 PM | #110 | |
Rep 2,098
EDIT: I see it worked out in the other thread. Glad to hear it. Last edited by bluewater328; 08-27-2020 at 10:23 PM.. |
| Bookmarks |
