BMW 3-Series (E90 E92) Forum
Bimmerlabs 330i Tune DIY Step by Step
| 07-05-2020, 06:31 PM | #1 |
Rep 2,025
Drives: 2008 E92 328xi
I've decided to make a video as to have a visual guide for people looking to tune their 325i/328i N52 to utilize the 3 stage intake manifold and updated tuning settings of the 330i with the Bimmerlabs website and 330i tune.
I have talked to quite a few guys with N52s that wanted to do the swap but didn't know how to tune the car and the price of a tune like Stage FP, AA, etc seemed high so this should help. This should be a fairly comprehensive video guide of exactly how I did it aswell as a few troubleshooting steps for issues I had when getting the computer to recognize the cable and flashing process. I've linked all the websites in the description of the video but thought I'd do it here aswell. Links: Tuning software: Https://www.Bimmerlabs.com BMW diagnostic and flashing software: Https://www.Bimmergeeks.net/downloads K+DCAN Cable: Https://www.bimmerlabs.com/store |
24
Silnismo231.50 desertman1232251.50 donut_boi1007.50 Noir893.00 bobbytomorow12.50 b1aze576.00 wayman519109.00 hassmaschine3996.50 Donethat394.50 Volasko742.00 bluewater328650.50 gjm1202261.50 Thorin120.50 javeci016.00 billowusu18.50 F31B48299.50 W4HG0N30.00 e90yyc2758.50 3PedalJake3511.50 DougNBodie29.00 TW51620.00 PJLux108.00 bshambam203.50 styast46.00 |
| 07-06-2020, 04:15 PM | #2 |
Rep 284
Drives: E82 N52 6MT A51
Thanks dude, the video is awesome. Did you shit your pants when you saw fatal error?
DougNBodie29.00 |
| 07-06-2020, 07:02 PM | #3 |
Rep 7,212
Nice.
BTW, errors are almost always a cable or setup issue. And it's basically literally impossible to brick your DME in WinKFP, especially with a batch flash. |
tlow982858.00 Reverend_Wrong28.50 |
| 07-06-2020, 07:02 PM | #4 |
Rep 2,025
| 07-06-2020, 07:06 PM | #5 |
Rep 2,025
It seems pretty safe after I already did it. Literally all my issues were indeed cable setup related. Might flash the mafless tune soon.
| 07-13-2020, 10:48 PM | #7 |
Rep 2,098
Glad someone finally did a full video. Too bad you're wipers didnt go ape-shit like mine. I think it is good to show that and the dash going nuts so people dont get freaked out as its happening (and potentially knee-jerk remove the plug).
| 07-14-2020, 02:41 AM | #9 |
![]() ![]() ![]() 528
Rep 596
Drives: E92 328xi 6mt swap
any benefit from running this on a 328 without the 3SIM?
| 07-14-2020, 02:47 AM | #10 |
Rep 2,025
I was eager for the wipers to go off to add to the excitement, I mentioned it could happen so at least there's that. Most of the noises and such I got were the warning blings and the fuel pump priming.
bluewater328650.50 |
| 07-14-2020, 02:50 AM | #11 |
Rep 2,025
3PedalJake3511.50 |
| 07-14-2020, 02:55 AM | #12 |
Rep 596
| 07-14-2020, 03:39 AM | #13 |
Rep 2,025
Good luck. Make sure to have driven the car before doing it or that your battery is in good health as the RSA delete can be a bit lengthy depending on your pc.
| 07-14-2020, 03:46 AM | #14 |
Rep 596
I have a 30 amp charger that I've used to upgrade all the modules in my car, I think I'll be fine
E92William2047.50 |
| 07-14-2020, 10:57 AM | #15 |
![]() 2262
Rep 2,826
Many thanks to E92William for making this video!
A couple of questions - I already have the Bimmergeeks Std Tools on my PC so the 3 folders mentioned around 1:38 were deleted when installed. Do I need to uninstall Std Tools and start over, skipping the delete of the 3 folders? Is a battery charger/maintainer like CTEK or Battery Tender attached enough for doing this flash?
E82 - BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
F22 - Stock M Sport, 6MT |
| 07-14-2020, 12:49 PM | #16 | |
Rep 2,025
![]() I personally deleted all my standard tools and installed again without deleting the 3 folders. Not going to be taking any chances plus I wasn't in a rush. I didn't use a charger at all for any of the flashing process. I think if your battery is good and you recently drove the car it will hold up just fine but if you want get it, I have a CTEK laying around too. Just flashed the MAFless tune a few minutes ago with no charger and it started up fine. |
gjm1202261.50 |
| 07-15-2020, 01:52 AM | #17 |
Rep 2,025
After driving the car with the mafless tune, I think I should have done it from the start. Car is more responsive, more peppy and the gas pedal input feels more inline with engine response than stock or 330i tune. Only downside is the cruise control not working. Car is on stock maf sensor.
Another thing I quite liked is that, on cold starts the mafless tune starts up like a normal 328i would. The 330i tune tends to rev the engine to almost 2k upon cold start up. Maybe it was only for my car but It particularly bothered me specially on a dead cold engine. For example in this video upon start, instead of revving to 1300 at first it'd do 1800. |
| 07-15-2020, 03:31 PM | #19 | |
@Lucky.330i
39
Rep 91
Drives: 2006 BMW 330i
| 07-15-2020, 04:06 PM | #20 | |
Rep 2,098
HydroxFrost38.50 |
| 07-15-2020, 04:09 PM | #21 |
@Lucky.330i
39
Rep 91
| 07-15-2020, 04:09 PM | #22 |
Rep 2,025
The maf has an iat in it too. Maybe your car has a bad maf but the iat part is fine. Obviously the idea behind the mafless tune is to get rid of the bulky stock MAF and put in the tiny IAT. But it works well with the stock part too. You should flash it and see how it does.
HydroxFrost38.50 |
| Bookmarks |
