BMW 3-Series (E90 E92) Forum
Bimmerlabs 330i Tune DIY Step by Step
| 07-17-2020, 10:43 PM | #45 | |
![]() ![]() ![]() 528
Rep 596
Drives: E92 328xi 6mt swap
| 07-18-2020, 02:44 PM | #46 | |
@Lucky.330i
39
Rep 91
Drives: 2006 BMW 330i
| 07-19-2020, 10:30 AM | #47 | ||
![]() 1024
Rep 2,306
There were also a number of LCI 3 series with this trans. |
| 07-21-2020, 12:40 AM | #48 |
Rep 598
What should I do for my LCI N52K now with DISA?
Should I pay extra for their "Tuner" to add better throttle response or 91 Octane tune? ECS Tuning offer the service for $400+ but also charges $200+ for cable. That's just too much for $15 cable. |
| 07-21-2020, 10:13 AM | #50 | |
Rep 1,381
Drives: 09 E90 335i M-Sport 6MT RWD
No idea on the cost but ill be looking into it soon for my brothers 328 (and hopefully they can do the same for my 530 N52) |
| 07-21-2020, 10:22 AM | #51 | |
![]() 2477
Rep 4,328
ever. I pestered them about it for a while. I've not yet done the 330 trans tune. who's got a link to a thread with the software numbers? |
| 07-21-2020, 02:25 PM | #52 |
Rep 2,098
| 07-21-2020, 07:36 PM | #53 |
Rep 2,025
Drives: 2008 E92 328xi
Unless I missed something the file that @kakapo was talking about, "ZB 7587776" for the 330i GM 6AT flash isn't in the bimmerlabs website.
I wonder if it'd show up if I had a project as a euro 330i e92 ![]() Where could I get my hands on the 330i gm file you guys are talking about? Or is it a stock file that is available through winkfp |
| 07-22-2020, 12:48 AM | #56 |
Rep 2,025
I'll have to do some research and fiddling around because I haven't used Winkfp much at all except to flash the tunes, so have to figure out how to find the file and flash it.
If you could make it available on the website it would be easier as the stuff to make your 328 into a 330 would be mostly centralized there from engine to transmission. |
| 07-22-2020, 01:07 AM | #57 |
Rep 7,212
All I need is the ZB# and which cars it could apply to (whichever have the GM 6AT). Even if it's just the people in this thread, that's probably 95% of cases.
| 07-22-2020, 01:39 AM | #58 |
Rep 2,025
Well the ZB is 7587776 supposedly according to the previous posters.
I double checked on realoem it looks like no e60 got the gm transmission at least no usdm car 525/528/530. For E9x 328i up until 07/2007 it shows all of them with the gm box but then it has the 6hp and gm as options too, though I've never owned a 28i car with a 6hp. Same story with the 128i. Seems as soon as the USDM 330i ends production in 08/2006, the European 330i goes from using a 6hp to the gm 6at. At least as per realoem. Can't find an N53 equipped car that uses the gm 6 speed. Maybe it's because the n53 being based on the n54 wouldn't mount up? If there was I think it would be the ideal file specially for a modded n52 that will reach stock n53 power levels. Also I just found out all the F10s with the N52 engine came with the ZF8. Thats a great transmission. |
| 07-22-2020, 10:59 AM | #59 |
Rep 7,212
The ZB will probably be from an EU car. Also sometimes during transitions, BMW will use parts left in stock (parts bin cars, in a way).
edit: I do think 7587776 will work. it'z from an X3 3.0si, which also has the GA6L-45R. Last edited by hassmaschine; 07-22-2020 at 11:09 AM.. |
| 07-22-2020, 12:03 PM | #60 |
Rep 7,212
It's available now. Note that the only supported cables are an ICOM or Bimmergeeks. Anything else could potentially brick your TCU, and I can't help you if that happens.
I can't test it but let me know if there's any issue with the batch flash. |
| 07-22-2020, 12:04 PM | #61 |
Rep 596
The ZB 7587776 works for both me and one of my friend's cars. We both are currently running the Euro 330i transmission flash. I don't remember how he found it, probably from an old forum post, but I have to say that it has made a remarkable difference, the car seems to feel much better when I drove hard. I attached an image from INPA to prove that this ZB really works. Please make sure that you have a good power supply as I failed to flash my transmission before while trying to do this which caused me lots of needless stress.
| 07-22-2020, 12:10 PM | #62 |
Rep 2,025
I'll check it out, most likely I'll take the same course of action I did with the 330i tune and do it right after driving for a while so there's no chance of battery charge issues.
I'm using a bimmergeeks cable so I believe I should be in the clear. Are the steps for doing this the same as the other tunes? Open batch file and go? Regarding the flash itself, I suppose it resets adaptations for the transmission, wouldn't it be beneficial to do it right after changing transmission fluid for best results? |
| 07-22-2020, 12:16 PM | #63 | |
Rep 596
| 07-22-2020, 12:23 PM | #64 |
Rep 7,212
It's exactly the same. If your DME flash worked, it should be no problem. you do have to change your DME to the GM1912, or just add another project for it, and if you want you can always download the stock trans tune again. You don't have to flash the program because they should be the same.
| 07-23-2020, 02:46 PM | #65 |
Rep 2,025
Just checked and found it. There's two GM 1912 options but seems they both have the same stuff. Hopefully the e83 x3 is the best one of all the 330i tunes we can get. I'll change the fluid this weekend or soon enough and flash it after driving it for a while, so I don't over-credit the tune for something a fluid change could have done.
| 07-26-2020, 09:49 PM | #66 |
Rep 2,025
After trying to change the fluid and stripping the fill plug.. (reason 8272678162 why I dislike xdrive, can't fit a socket over the fill plug)
I'm just gonna try flashing it today. Transmission shifts good so I have no worries about the fluids condition. Just hope the flash file is compatible with the car itself |
| Bookmarks |
