BMW 3-Series (E90 E92) Forum
Bough some oil: Total Quartz Ineo MC3 5W30
| 06-08-2010, 09:06 PM | #1 |
2006 join date crew
205
Rep 1,482
Will probably switch from Mobil1 I am currently using. The point of this post is for people who are looking at this oil, can read the back label like I wanted to. When I was shopping for this oil I could not find the picture of the back label with all the certifications/ratings. So here you go:
(As a side note I never bought oil online, it arrived very well packed and padded) Individual containers are sealed in a tough plastic bags to avoid oil spills (take that BP ) |
| 06-08-2010, 11:22 PM | #2 | |
2006 join date crew
205
Rep 1,482
| 06-09-2010, 08:19 AM | #3 |
I ask the questions you're afraid to ask.
45
Rep 2,489
| 06-09-2010, 08:56 AM | #4 |
Rep 1,543
I've used it in my 335I for 9,000miles with NO ISSUES whatsoever. Keep in mind I baked it to 245F daily! Its a Very good oil. I switched away from it though because Total recently changed the base oil from PAO to mineral oil. i.e the oil went from group IV to III. Total beefed up the additive package on this oil because of this, so it does just fine, regardless.
| 06-09-2010, 09:49 AM | #5 |
2006 join date crew
205
Rep 1,482
I wanted to try something else, because Mobil1 is not that great. Total came up in my mind, but from all oils they have, LL01 ones are SL not SM like BMW recommends. So went with LL04 SM which is what I bought
If I won't like it, the search will go on. Motul probably will be next, but that stuff is ridiculously expensive (300V line) |
| 06-09-2010, 10:20 AM | #7 |
***** noob
1541
Rep 10,477
Drives: 325xi>M235i>428GCx Mspor
dude..relax on this subject. We're not putting "unapproved" oil in your car man
you dont need to bring this up on every thread about other oils.
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
| 06-09-2010, 10:45 AM | #8 |
***** noob
1541
Rep 10,477
we all know about the LL01 approve oil but if someone wants to use other oils...let it be, we are well aware of it.
BMW also tells you not to mod your car, change oil 15000 miles, and the list goes on. Who cares!!!
2006 325xi (Sold)
| 06-09-2010, 10:53 AM | #9 |
Elitist
Rep 114
No kidding whats with the Oil Patrol® in here...
| 06-09-2010, 11:46 AM | #10 | |
Rep 10,867
![]() In all seriousness the MC3 is a good oil. Just be known that the TBN is lower for LL04 oils when compared to LL01 so the additive pkg will be depleted a lot faster when running on U.S. gasoline. On that basis alone, I would suggest 7.5k OCI with a UOA to determine if you could go farther along if longer OCI's are your goal. |
| 06-09-2010, 11:48 AM | #11 | |
45
Rep 2,489
How can you make an assertion that Mobil 1 (Elf, Castrol whatever) is "not that great?" Do you have more expertise with oil than the manufacturers. Not meant as a critisism, but I'd really like to be able to understand this minsdset. |
| 06-09-2010, 12:21 PM | #12 |
![]() 10
Rep 102
Don't know why such "hostility" towards comments to people that recommends approved oil. I find these comments helpful. I am sure that there are many here that does not care if the oil you use is approved by the manufacture or not, but there are some that do. There are also newbies on the forum that haven't come across the 10 thousand existing posts on oil, and will assume that these non-approved oils are "interchangeable" with the manufacture approved ones. So unless one can guarantee that all these oil will protect the engine the same, why not present both side of the story and let the reader decide?
Anyways... this is a great forum, just relax. Last edited by bimmernoob; 06-09-2010 at 12:33 PM.. |
| 06-09-2010, 12:55 PM | #13 | |
45
Rep 2,489
Correct. I couldn't care less about what you put into your car. That's between you, the dealership and the next poor schmuck that buys your car. What I am interested in, however, is to make sure that you have enough information to make an informed decision. Since lubrication caused failures are so rare with our cars, you can expect the dealership to request proof from you about lubricants used if you have a failure under warranty. The "some random dude on the 'net told me that King's Green was the best stuff since sliced bread" won't be sufficient to keep your warranty intact. |
| 06-09-2010, 01:21 PM | #14 |
Rep 2,783
When someone posts about oil, it is natural, on an enthusiast site to discuss approved v. non-approved oil. Otherwise everyone should just use this
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
| 06-09-2010, 03:32 PM | #15 |
***** noob
1541
Rep 10,477
You guys should check all the threads here each day and tell everyone not to MOD their cars cuz it is not approved by BMW.
Dont put that after market spoiler...its not approved by BMW Dont lower your car with that shitty KW stuff...not approved Dont do the Plastic grills...not approved Dont put that intake in there...guess what, not approved Wait What? dont put that exhaust....not approved You should not drive this BMW cuz you aint approved by BMW son
2006 325xi (Sold)
| 06-09-2010, 03:57 PM | #16 |
***** noob
1541
Rep 10,477
but the chill pill is not LL01 approved
2006 325xi (Sold)
| 06-09-2010, 04:11 PM | #17 |
Elitist
Rep 114
| 06-09-2010, 04:20 PM | #18 | |
Rep 1,543
| 06-09-2010, 04:23 PM | #19 | |
Rep 1,543
| 06-09-2010, 05:11 PM | #20 |
Rep 2,783
It's funny how people perform mods on their cars (I am not talking about cosmetic mods) and they are the 1st ones to complain, why is my car not handling right? Well let me see, you just lowered the car and changed various suspension components, uh....maybe it's BMW's fault. Uggggh.
| 06-09-2010, 06:13 PM | #21 | |
Rep 10,867
Did you find out what TAN was as well? I've seen UOA's on the 335D which had TBN under 2 @ 10k miles and TAN was at about that mark as well. |
| 06-10-2010, 01:47 PM | #22 | |
45
Rep 2,489
Lubrication issues don't rear their ugly heads until much later, so your comparison is worthless. What I do know is that BMW and the oil manufacturers spent millions on developing standards and lubricants to meet to meet those standards. To say "I know better" is a bit foolish. If you choose to disregard the requirements set forth by BMW (or any manufacturer) then feel free to do so - just don't promote the use of unapproved lubricants as if were OK. |
| Bookmarks |
