BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Bimmerlabs 330i Tune DIY Step by Step
Reply
      06-17-2025, 10:29 AM   #837
Japanese E90
Drives: E90 328i
Does anyone experience torque down at 3k〜4k rpm like an flat spot of torque curve with this MAF less tune. Is this because I use the IAT from the stock MAF? or because of DISA valve open timing?
My car details: AFE intake + AA headers + LAPTORR exhaust. Currently canceling the O2 feedback but I experienced last time before canceling O2.
      10-11-2025, 12:40 PM   #838
wayman519
Drives: E82 N52 6MT A51
2018 BMW X2  [0.00]
2009 128i  [2.50]
I had flat spots in the rev range that was due to slow disa valves. They are not serviceable but it can be done. I opened the disas and soldered the connections cleaned out the oil and plastic welded it all back together.
      10-20-2025, 04:27 PM   #839
31amk31
Drives: E92 N53 325i
Does such a tune exist for the 325i N53? I got a 3 stage intake fitted and I'd like to put the 330i base map on it without going to a tuner.
      10-21-2025, 07:52 AM   #840
ivanchen1211
Drives: BMW Z4 3.0i
Does anyone know where to check the MSV80 zb number for the car? For example E92 328i WB33 MSV80 zb number, E92 330i WB51 MSV80 zb number? For MSV70 you can find the numebr on realoem but for MSV 80 I can't find it.
      10-22-2025, 03:30 AM   #841
Phil325i
Phil325i's Avatar
Drives: E92 325i MSport Coupe
Check out the Mosselman website
https://www.mosselmanturbo.com/
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace with cross bar; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      10-22-2025, 02:18 PM   #842
31amk31
Yes but that costs 600+ euros, admittedly it is an actual tune and not a base map.
For me, if a free base map exists like is shown for the N52, I'd much rather go that route.
Reply
