TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Radiator Fan Options
Reply
      08-17-2018, 04:33 PM   #1
Pinscher
Drives: 2008 335i
He Guys,
Is there such a thing as a radiator fan upgrade for our E90's?
like one that is has the loudness of a mouse? lol... okay, end of line.
      08-17-2018, 05:23 PM   #2
Phyrexia
Resident Pedant
Drives: '15 335i 8AT
There are 400w and 600w OE units available. One was for cars with the Towing Package which I do not believe was available in the US. Neither will be quiet but if yours is loud it's probably old.
I'm sure you could rig some kind of finger chopper arrangement but I'm not sure if it's neccessary. Even the late great JustPete had the OE fan on his race car.
      08-17-2018, 06:15 PM   #3
Pinscher
Drives: 2008 335i
I don't need anything fancy, but it's loud. sometimes it sounds like it's grinding on the radiator, which it's not (i spaced it out to be sure).
I know it's summer and the thing turns on high when you have AC on, etc, but it's loud.
Mostly i'm trying to eliminate the extra noise caused by the dying nature of this fan so i thought to see if there was something better on the market.
Okay, thank you for the reality check
      08-17-2018, 06:36 PM   #4
9krpmrx8
Clean is the new cool, keep it that way.
9krpmrx8's Avatar
820
Drives: 11' Alpine White 335i Sedan
The only upgrade is to run the 335is 800W radiator fan.
edit: Oh wait, this is the NA subforum so maybe the normal 600W 335i fan is an upgrade.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive
      08-17-2018, 06:43 PM   #5
Phyrexia
Resident Pedant
Yes I think the motors are the same but the shroud is different. They're different part numbers though
'15 F30 335i 8AT Estoril II/Black/P337A (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / K&N Filter / Holes in Airbox make fun noise / ER CP / CSF IC / NGK 97506 / ER DP / M-Adaptive Delete / Bilstein B12 / Eibach Pro-Kit
      08-20-2018, 02:36 PM   #6
Pinscher
Drives: 2008 335i
so the 335 fan will or won't fit.
      06-10-2019, 10:47 AM   #7
yupetc
Drives: F15N55, G30B58
the 335 fan won't fit according to the picture comparison I see. But you can get the 600W version, I found it on ECS tuning. part number is 17427562080. There's an aftermarket version for way cheaper too (TYC).
2017 540i - MHD2+, VRSF DP, TU Pump
2015 X535i - CP Pistons, Manley Rods, Irox coated bearings, Cometic head gasket, Wagner head studs, M2 crankshaft, MILVs VRSF charge Pipe, Wagner FMIC PURE500 turbo, MHD2+ VRSF DP, B58TU HPFP UR Front/Rear Sway Bars, Eibach springs, KONI FSD Struts
      06-10-2019, 12:27 PM   #8
rjahl
rjahl's Avatar
1024
Drives: Z4 35is
2012 Z4 35is  [0.00]
Remind me, why?
Has anyone looked at the real duty cycle of the Stock Fan? I can't say too much about the 3 series, but the N52 cooling in my E85 was robust, that fan never had to run hard. Except with the AC was active.
The DME will set the fan to higher speeds with the Air conditioning compressor tuned on, even if the coolant temperatures are low.
The DME controls the coolant temperature anyways, you can't change the engine operating temperatures with a more powerful fan.
Phyrexia516.00
      06-10-2019, 01:08 PM   #9
Phyrexia
Resident Pedant
I pulled a 2000 pound trailer 2100 miles last July with the stock 400w fan and a six speed. I also had about 800 pounds of stuff in the car, not including the large mammal that is my body.
Oil temp was more of a concern than coolant temp. A 60/40 water:coolant mix never exceeded 215 F. However, I almost pulled over once pulling a very tall hill east of Albuquerque, WOT in 3rd Gear at about 70 MPH because my oil temps were approaching the Serious Shit level. Sorry, my gauge cluster has an MPG label there, but it was about 3/4 of the way, so at or above the High dot on a sport cluster.
With that said, if the 400w fan can do that, I don't know if I see the point in an upgraded fan for our cars. There are 328 race cars running the stock fan.
      06-10-2019, 03:38 PM   #10
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Just get a stock fan and be done with it.
If you're worried about temps, consider the 335i oil cooler or even just the hot weather version of the heat exchanger.
https://www.e90post.com/forums/showthread.php?t=1412435
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
      06-11-2019, 11:41 AM   #11
yupetc
I think the original poster was looking for a replacement fan to begin with, but there are many options out there that seems like an upgrade. And I can understand if my fan went out and need a new one, for congruent pricing, I'd probably go for a higher grade fan anyways. But I agree with you all, no point upgrading the fan just for the hell of it, our stock fan are just fine the way it is.
      07-17-2019, 11:35 AM   #12
Pinscher
Drives: 2008 335i
The fan was rubbing against the trans fluid cooler.
car is sold, now i have a 335
Reply
