Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > ISTA/P
Reply
      03-23-2019, 04:38 AM   #1
Bmw330
Drives: Bmw 330d
ISTA/P
When I load up ISTA/P, create new session, select ISTA/P server automatically, it’s not showing any items to connect too? , I’m assuming I should see the cable here? , what am I missing?
My cable works for ISTA /D and inpa etc.....
      03-23-2019, 05:41 AM   #2
Sensible_
Drives: 2008 E90
For ISTA P you need an emulator for use with DCAN. Use ISTA Loader.
      03-23-2019, 07:51 AM   #3
Bmw330
Drives: Bmw 330d
Got it working, I needed to click on the dcan emulator before opening ISTA/p.
I was trying to get my alpine retrofit kit coded, but after loading up the conversions as per instruction there is no Alpine retrofit option!
      03-23-2019, 01:25 PM   #4
Sensible_
Drives: 2008 E90
Don't need ISTAP for this.
Just VO Code $676 and default code your headunit...
      03-23-2019, 01:57 PM   #5
Bmw330
Drives: Bmw 330d
The retrofit instructions stated ISTA/P, and select hifi retrofit alpine conversion, I didn’t have this option in ISTA though.....
Any idiots guide to do this?, is this through ESYS? thanks for your help
      03-23-2019, 03:44 PM   #6
ctuna
Drives: 325xi 06 wagon MT
676 will drop all radio or idrive outputs to 5 volt differential
levels so you would loose the rear seats as the volume would
be cut in half.
I remember there being two version of this kit back in the days
one required coding one did not.
http://www.e90post.com/forums/showth...ighlight=graph
      03-23-2019, 04:12 PM   #7
Levanime
BimECU
Levanime's Avatar
Drives: BMW
2007 BMW 335  [0.00]
Don't use ISTA/P with K+DCAN whatever it is
      03-24-2019, 03:58 AM   #8
Bmw330
Drives: Bmw 330d
Oh, is the cable not suitable?
      03-24-2019, 05:07 PM   #9
ctuna
What year is the car?
Cars made before 3/07 in the US use the K can bus
it allows you do more with a K/D can cable.
Also you don't need to use Ista p to do the Hi Fi conversion
you can use NCSexpert.
Just add option 676. to the VO and default code the Radio if
it is idrive more modules have to be default coded.
      03-25-2019, 04:36 AM   #10
Bmw330
Drives: Bmw 330d
It’s a 2011 car (uk).
I did code last night to in ncs expert to the following ...
Run NCSexpert
Click "file" and select "load profile" and select "expertmode"
Click "VIN/ZCS/FA
Click "ZCS/FA f. ECU
Select chassis type "e89"
On choose ECU select "CAS"
After your vin is shown select "enter FA"
Ensure VIN shown is correct and select "OK"
Enter $676 and then select "add"
Then scroll down and select "£676" and select "OK"
Then select "Back button"
Then select "F4 Process ECU"
Then select from drop down list "CAS"
Then select "F2 Change Job"
Then select "FA_WRITE" and click "OK"
Ensure CAS is shown on "Get Coded" and FA_WRITE shown on "JOB NAME"
Select "F3 Execute Job"
All seemed to work, are there any modules missing or should that above do it?
      03-25-2019, 09:43 AM   #11
ctuna
Did you default code the radio once you got 676 in.
I assume you have pro radio you didn't say if it
was idrive or pro radio.
      03-25-2019, 11:00 AM   #12
Bmw330
Drives: Bmw 330d
I only did what was above, could you let me know what else needed doing?
(Feel free to modify the text above to confirm correct steps, which I’m sure would be useful for anyone adding the alpine kit) It’s an I-Drive.
      03-25-2019, 11:43 AM   #13
Sensible_
Drives: 2008 E90
You also need to:
Add 676 to the NFRM FA.
Do exactly the same but do:
Then select from drop down list "NFRM" (or FRM whatever you have)
Instead of:
Then do the same....
Then select from drop down list "RAD2" (RAD2 is for the head unit for non idrive cars.
Then change job to sg_coderien
The execute the job. That will code the rad2 to the default settings based on your VO.
      03-25-2019, 11:59 AM   #14
ctuna
If its and idrive there are severa modules you have to default code,
And you won't have a Rad file.
      03-25-2019, 12:00 PM   #15
Bmw330
Drives: Bmw 330d
Thanks, very useful.....
As it’s an I-Drive, do you have a list of all the modules which need coding?
      03-25-2019, 12:10 PM   #16
ctuna
https://www.e90post.com/forums/showt...ght=676&page=2
Read the whole thread since there are two or more idrive variations
the modules may varry.
      03-25-2019, 12:40 PM   #17
Bmw330
Drives: Bmw 330d
It appears the following need updating too with SG_CODIEREN, CHOST/CAPPL/CGATE/CAUDI/CTUNE
This is the first try I’ve had at coding with ncs, where do you find these?,
I’d like to make a step by step written guide so its easy to follow!.
Thanks for your help
      03-25-2019, 12:48 PM   #18
Bmw330
Drives: Bmw 330d
Run NCSexpert
Click "VIN/ZCS/FA
Then select from drop down list "FRM"
Ensure FRM is shown on "Get Coded" and FA_WRITE shown on "JOB NAME"
Where/how do you find the following? CHOST/CAPPL/CGATE/CAUDI/CTUNE, I cant seem to find them.
I also have both FRM and NFRM?, does $676 need coding in both of these as well as CAS?
      03-27-2019, 06:58 AM   #19
Bmw330
Drives: Bmw 330d
Can anyone provide any help with the above please?
      03-27-2019, 07:03 AM   #20
ctuna
If you followed one of the simpler coding tutorials to do something
like setup digital v or open the close the windows with the keyfob you
would encounter the list of modules in your car.
When you setup the profile for coding and read the car its populates
the program/profile with the modules it reads from your car.
You can also do a check on the hardware modules in your car by
reading them with functional jobs in Inpa.
diagnostic manual ista/inpa
https://bimmerprofs.com/diagnostics-inpa-part-1/
https://www.google.com/url?sa=t&rct=...xo19teM9vkTF-C
https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF
https://www.bimmerforums.com/forum/s...-P-actually-do
This next one seems kind of old
http://codinge90.com/
What you have done in the last entry's is to change the VO
which stores the change you want in the CAS and NFRM(I think)
now to finalize the change it needs to go into the modules where
the changes actually take place.
Default coding.
1. Load NCSExpert.
2. Load Profile and select Expertmode
3. F1 (VIN/ZCS/FA)
4. F3 (ZCS/FA f .ECU)
5. Choose E89 (for the E9X)
6. Select CAS
7. F6 (BACK)
8. F4 (Process ECU) (at this point the list should show up)
9. Select the Module I want to Revert back to Stock.
10. F2->Choose "SG_Codieren->ok
11. F3->to start coding the ecu with factory settings according to the vehicle
Repeat for each module.
Depending on your download the newer profiles may only have
manipulation or factory profiles . Factory is the one that causes
data to be read from the CAS and NFRM modules rather than
a coding file as described in the coding process.
      03-27-2019, 07:23 AM   #21
Bmw330
Drives: Bmw 330d
When I set up the coding I do get a list of about 25 modules, none are these though....
I get stuff like media, CIC, dwas, pdc etc, so I was just wondering if my car actually had these modules as stated above, or if they are buried deeper elsewhere....
      03-27-2019, 07:53 AM   #22
ctuna
run inpa functional jobs as described in the link to get
a list of installed hardware modules and descriptions.
Sorry no idrive expert here but according to the people that
have done this some variation of the list of modules from
the thread on going to 676 should pop up in the indicated
ECU list.
The idrive changed from cic to ccc at some point in the US
there may be other variations in Europe.
You might also try the idrive sub forum.
Reply
