The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > BMW Performance Exhaust installed on my 330i. Its too quiet!! why?? pics
Reply
      08-25-2013, 11:10 AM   #1
plasma23
plasma23's Avatar
31
Drives: F82 M4 Comp
2007 330i N53  [0.00]
Hi guys, I finally got my PE fitted on my e90 330i (N53) M Sport auto. I got it fitted by the dealer (BMW Reading) for £102 inc VAT which I thought was a pretty reasonable price.
Please look at my previous post of when my BMW PE was delivered:
http://www.e90post.com/forums/showthread.php?t=872327
Anyway I had really high expectations for this exhaust, sound wise that is. After speaking to several forum members with this particular exhaust as well as reading numerous positive reviews I though the difference would be day and night, compared to the stock exhaust.
After waiting for an anxious 1 and a half hours at the dealer, I was eager to start up my car with the new exhaust.
FIRST IMPRESSIONS: VERY subtle! not much of a difference compared to stock! Admittedly there was VERY slight deeper burble but hardly enough for a noticeable difference and something you had to listen very hard to notice. As I drove home, I opened up the engine (plus 4k) on DS mode thinking it would sound more raspy but again not much of a difference between stock. I was/am thoroughly disappointed.
I thought something must be wrong, so I read up on the instructional manual and it stated "Only for the 330i: Remove the exhaust flap control."
Emailed the dealer in reference to this and they told me the manual was referring to a small vacuum pipe and it had to be removed before fitting the PE otherwise it can break off as you take off the stock exhaust. They also said that only the 330i and 335i models have this vacuum pipe attached to the exhaust, this could affect on the sound because the flaps won’t be performing as they should. This will have a negative effect on the performance and air flow through the exhaust however.
I thought perhaps my flapper was closed, hence the reason why it sounded so muted. The flap is open when the engine is off. Turn on the engine (park mode) rev it up and it is still open. So why does still sound so muted??!! I then tested both tail pipes were exhausting gas with a piece of paper and I can confirm they both were.
Here are a couple of pics:
As shown in the pics, the vacuum pipe comes from the acoustic damper, (black knob connected to the tail pipe) and goes towards to boot.
So I am guessing if my flapper is open, its the same as this 'golf tee mod' people are talking about to make the car sound louder? Read up on some other forums and apparently the flap controller is in the boot of the car and that must be disconnected? I am guessing this is what the dealer did?
      08-25-2013, 01:14 PM   #2
cuiter23
cuiter23's Avatar
85
Drives: 2023 G87 M2 6Spd
2007 BMW 328i  [6.00]
The PE isn't very loud to begin with...
[SOLD] 2007 E90 328i - Titanium Metallic l 19" VMR V710 l H&R Trak+ Spacers l M-Sport Rear Bumper l Mtech Rear Lip Spoiler l Hamann Front Lip l Eibach Sportline l AA N52 Signature Exhaust l OEM Blacklines l MTEC V3 AE l 6000K HID l Nokya 7000K Fogs l MTEC License Plate LED l Interior LED l 15% Tint l BlackVue DR380G-HD + PMP
2023 G87 M2 6Spd - HEA Package | OEM M Performance Carbon Wing
      08-25-2013, 05:21 PM   #3
benzo23
benzo23's Avatar
81
Drives: 14 F30 AW MSport
If I remember correctly you're the chap who had just the rear section only. Yours didnt have the center resonator delete pipe with it. Perhaps deleting your resonator will wake it up a bit. Mine is plenty loud and more noticeable over stock
      08-25-2013, 08:25 PM   #4
calypsoe36
Ninja
69
Drives: E92 M3, E46 ZHP
Yeah, the mid-pipe that deletes the resonator is a crucial part. Without that in place, the sound will be still be substantially dampened. The PE is not overly loud anyway, but it should be much more noticeable than what you have described.
2013 E92 M3 ZCP
2005 E46 330i ZHP
2020 Porsche 718 GT4
2020 Tesla Model Y Performance
      08-26-2013, 06:27 AM   #5
Phil325i
Phil325i's Avatar
Drives: E92 325i MSport Coupe
Not on European versions it isn't. The resonator on EU models is substantially smaller than those for the USA. And in any case, on Euro models there is an additional exhaust sensor post-resonator - hence the PE is rear muffler only.
I agree with you though, there must something wrong with the OP's set-up for him to complain it's too quiet!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace with cross bar; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      08-26-2013, 10:43 AM   #6
Volasko
Volasko's Avatar
757
Drives: 06 330i E90, 18 530xe G30
Breaking it in makes it louder. +1 on the mid pipe comment
      08-26-2013, 01:07 PM   #7
plasma23
plasma23's Avatar
31
Drives: F82 M4 Comp
thanks for all the response guys. This exhaust situation has really done my head in!
Seeing as my exhaust flapper is always open, it should make it loud.
My only hope now is for the exhaust to get louder over time during the break in period?
Unless the dealer didn't seal the clamp properly from the pipe to the muffler but then this would make it louder I assume
      08-26-2013, 05:11 PM   #8
Rival
Drives: 95 z28
delete 2nd cats.
2010 335i M sport
2008 328i
2006 325i
1995 Z28 6spd - 377rwhp rip
      08-26-2013, 05:28 PM   #9
SDemetris
FSAE Dude
Drives: E90 328xi
Originally Posted by Rival View Post
delete 2nd cats.
second to that.. a bit louder and more fun burbley backfire noises
2007 TiAg 328xi: AA Tune, AFE intake, Full exhaust, 335xi Brakes, H&R RSB, UUC FSB, H&R Sports, Billy Sports...BBS SR 17x8
1985 Gazelle Beige 325e: Poly everything, e24 3.25 LSD, 225 lb weight reduction, Corbeau FX1, Shifter machined by me, roll bar, harness, all the other goodies. My "Racecar"...15x7 BBS RA
      08-27-2013, 05:22 AM   #10
plasma23
plasma23's Avatar
31
Drives: F82 M4 Comp
So how do I go about deleting the secondary cats? Can I do it myself or would it need to be taken to the garage?
Because my car is still under the BMW warranty, I would not want to void it, but perhaps the dealer can delete 2nd cats? Would it effect my emissions, as I still want my car to pass its MOT
      08-27-2013, 11:29 AM   #11
SDemetris
FSAE Dude
Drives: E90 328xi
it should not affect emissions. it is after all O2 sensor so you would not get a code.. and yes, welding is involved so you would most likely have to take it to an exhaust shop
      08-28-2013, 01:47 AM   #12
mammothboarderdc
mammothboarderdc's Avatar
Drives: E90 328i Sport
random... how much did you get the pe for?
      08-28-2013, 09:15 AM   #13
mccannable
Drives: 2014 X1
Is that different than the us. I looked at mine and no valve on mine.
      08-28-2013, 09:31 AM   #14
essex_lad
Drives: E92 Msport N53 Stage 2
If your not happy with it and you want something louder I would happily buy this off you.
      08-28-2013, 10:56 AM   #15
Phil325i
Phil325i's Avatar
Yours is a 325i, so a different part number than the OP's (no flap mechanism!)...
      08-28-2013, 12:44 PM   #16
essex_lad
im sure it has the flap mechanism even if it doesn't I can just leave it open.
      08-28-2013, 12:45 PM   #17
essex_lad
So I'm happy to have it off you if your getting a louder exhaust.
      08-28-2013, 12:52 PM   #18
essex_lad
If you want it loud just go to a custom exhaust place and have them put a straight through system in so they do away with all the silencers and keep the cats. It will be nice and loud and still pass mot emissions test.
      09-01-2013, 05:20 AM   #19
plasma23
plasma23's Avatar
31
Drives: F82 M4 Comp
Yep it has the flap mechanism. Everything is the same On the 2 cars except the intake manifold has 2 adjuster units in it.
Hi mate. You have the e90 325i n53 and it has the flap mechanism? Sounds odd
      09-02-2013, 05:12 AM   #20
plasma23
plasma23's Avatar
31
Drives: F82 M4 Comp
got it for £680 inc VAT plus £100 inc VAT fitting at the stealer
      09-02-2013, 05:15 AM   #21
plasma23
plasma23's Avatar
31
Drives: F82 M4 Comp
Hmm sounds like an interesting thought. Im going to the stealers hopefully this weekend so they can check the PE and see if everything is performing as it should.
Perhaps I can ask them to put a straight through system but my cars still under the BMW warranty so i dont know if I can do this.
just on a side note, I had a bit of a drag race (no pedestrians were around, wide empty road) with a Vauxhall Astra diesel (2 litre) and past 5k the PE was quite loud. And of course I obliterated him pulled multiple bus lengths
      09-02-2013, 07:29 AM   #22
essex_lad
Good man lol and I'm sure there's company's out there that can do the system without voiding your warranty and having to go to the stealers.
Reply
