BMW 3-Series (E90 E92) Forum
help programming SZL sensor with INPA
| 04-29-2013, 11:51 AM | #1 |
![]() 11
Rep 32
Are there any guides on how to program an SZL sensor? I have an 2006 330, and I recently cleaned the szl sensor and now my turn signals don't work, but the obc button works.
So I'm thinking to get a used szl sensor and code it to the car with INPA, but I couldn't find any DIY on programming SZL with INPA ? thanks |
| 04-29-2013, 01:31 PM | #2 | |
Rep 347
Could explain how you cleaned this sensor? Do you have some errors in INPA? |
| 05-28-2014, 06:05 AM | #5 |
Rep 328
Then he'll have to Re-initialize the DSC thru INPA or the ABS, Traction control, and yellow Brake lights will never go off. Ask me how I know. SZL is steering angle sensor right? If he had it apart to clean it, then he just needs to reset it thru INPA or another qualified scan tool.
| 05-28-2014, 06:08 AM | #6 |
![]() ![]() ![]() ![]() 99
Rep 713
True, but it can't be re-init by INPA, anyway I was trying many times do this using INPA and I just couldn't. You can use Tool32 or DIS to initialize sensor, it is very simple.
| 05-28-2014, 06:13 AM | #7 |
Rep 328
Really? I thought I was just an idiot. I've tried resetting my SZL with INPA on multiple installations, and always just get a dialog box saying something along the lines of "must use steering wheel balancer" good to know. I also didn't know you COULD reset it with Tool32, gonna look into that. Thanks for the info. Can Tool32 also realign EWS with DME?
| 05-28-2014, 07:09 AM | #8 |
Rep 713
Not sure about DME, but Tool32 is really powerful tool
![]() To re-init angle sensor you need to open DSC.prg and execute lenkwinkel_dsc_abgleichen, that's it. Steering wheel must be in straight position. |
| Bookmarks |
