BMW 3-Series (E90 E92) Forum
N52 Single Turbo Options
| 03-22-2012, 11:00 AM | #1 |
![]() 640
Rep 1,402
Just thinking, how about a single turbo instead of the elusive Gavin or ESS supercharger.
I don't know it they would fit, but the options could be; 1) N55 stock turbo, manifold, and downpipe 2) HPF N54 single turbo manifold and smaller 300-350hp turbo 3) Vishnu N54 single turbo manifold and smaller 300-350hp turbo You could use stock 335 intercoolers (cheap takeoffs) and some piping pieces. Last edited by CobraMarty; 03-22-2012 at 11:25 AM.. |
| 03-22-2012, 11:32 AM | #2 |
Rep 20
As I understand it the N52/N51's internals aren't reinforced enough to handle turbos, supercharging is the only way we're going to get forced induction on this platform and even that seems like a pipe dream.
| 03-22-2012, 01:17 PM | #4 |
just another bmw douche bag
200
Rep 3,639
| 03-22-2012, 05:29 PM | #5 |
Rep 495
Drives: '04 M3 & '07 X3 M-Sport
Honestly I've been looking at this route for my X3. I've kinda been looking at all possibilities from Gavin's S/C, to a motorswap, and now an N55 single turbo.
From a non-technical standpoint and maybe some "common sense" the n55 is sort of based on the n52 with a single turbo added whereas the n54 was based on the m54 engine. Taking the various bits from the n55 (injectors, turbo w/manifold, intercooler, etc) and fitting to the n52 should be straight forward. I figured since both motors had valvetronic, double vanos, etc, all the sensors should be the same and tuning should be "easier". I'm thinking replacing the cylinder sleeves with something stronger should be a good start towards some insurance. My version of the n52 is rated at 260hp (I don't know why the extra 5hp over the 330i or z4 3.0si). So an extra 40hp from a stock n55 setup should be no problem. Following that thought, getting a stock n55 software profile should be cake to load. We'll see what I find out when I get some time to plan. So far this is just theoretical. I had my mind set on a motor swap, but my last one was an s52 into an e30 and electronics was not a concern back then. |
| 03-22-2012, 07:13 PM | #6 | |
![]() 68
Rep 1,087
Drives: 2006 BMW 325i
| 03-22-2012, 07:52 PM | #7 |
![]() 640
Rep 1,402
Off the N55 could use the turbo and manifold, use someone's N55 take off downpipe, use your vehicle specific take off stock 335 intercooler.
Other parts- adapter to connect N55 downpipe to 328 exhaust, air filter and tubing, intercooler piping, tuning. |
| 03-22-2012, 09:02 PM | #8 |
Rep 495
| 03-22-2012, 09:05 PM | #9 | |
![]() 300
Rep 1,215
"The cylinder bore consists of an Alusil structure, there are no iron cylinder liners as with previous 6 cylinder designs. The cylinder bores cannot be machined, however this design still allows for planing of the deck surface if needed." |
| 03-22-2012, 09:36 PM | #10 |
Rep 495
Thanks for the clarification guys. Well that sucks.
| 03-22-2012, 11:25 PM | #12 |
![]() 21
Rep 271
While getting my car dyno tuned today (more on that soon), they had a professional drifting team there dyno'ing their turbo'd e46 ME. Their engine guy told me it's possible to turbo/supercharge the N52 engine, but the engine would have to be sleeved due to the magnesium block. He said it should be able to handle 6psi boost without issue.
I don't know how valid his answer is... but he had their 3.0L engine putting out around 700hp on the dyno. |
| 03-22-2012, 11:45 PM | #14 |
![]() 640
Rep 1,402
Don't want one. Did they ever get the HPFP problem fixed? How about that direct injection and those carboned up intake ports. Don't they still have PCV oil blowing issues that catch cans don't fix. Hows your insurance bill?
Go play in your own sandbox and leave us 328 owners alone. TY. |
| 03-22-2012, 11:48 PM | #15 | |
Team iTouge
137
Rep 2,101
I've been doing research about this as well, from what I concluded, if you'd wanna boost higher than 6 psi, you'd need a air cooling kit. Far past the intercooler, you'd need : oil cooler kit, meth and water injection or nitrous, and a tempurature management system. A friend of mine turbo'd his civic and he recommended using an extra set of fans to cool where the intercooler and another set to blow the hot air away from the headers. Ceramic coated parts are highly recommend as well. Good luck in your endevours, when you find the golden ticket , klet me know
. Ill be surely searching for more info as well!
| 03-23-2012, 02:29 AM | #16 | |
![]() 32
Rep 135
![]() I love my 328i too. Something will come, if not just keep saving for your next car and make it an m3 instead of a 335. |
| 03-23-2012, 03:07 AM | #17 |
Rep 495
And what am I supposed to do exactly?? In order to get an N55 engine, I have to get a new X3. First, I don't want a new X3 because its way too big. Second, I have a fully loaded M-Sport E83. In order to get the equivalent in an F25, I need to spend $60,000, or nearly $40,000 more than I did for my 20k mile '07. The way I see it, if I spend half that on modding my current car, well gee, there's a lot I can do for $20,000.
Just give it a rest already... |
| 03-23-2012, 03:10 AM | #18 | |
Rep 495
I imagine that guy also doesn't know that the N52 isn't sleeved to begin with like a typical motor. |
| 03-23-2012, 09:07 AM | #20 |
2006 330i, TSM, Black, manual, sport
912
Rep 3,698
Drives: '17 C2, GTI, Z4 3.0si Racecar
Oh gawd! Like we haven't heard that before
![]() Why are you even on the NA board anyway? It would cost me about $20K to get a 335 to where my 330 is. NOT going to do it.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
| 03-23-2012, 11:11 AM | #21 |
![]() 41
Rep 280
Say you just slapped a turbo on a stock N52 (325i) what exactly would happen? Just strain and reliability?
| Bookmarks |
