TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Intake camshaft
Reply
      11-17-2025, 10:59 AM   #1
bois567
Drives: BMW 528i
Intake camshaft
Hey guy,
I was working on my n52 engine and only to find that there is issue with starting. all my car does now is cranking cranking cranking.
For a while i was trying to identiy the issue and i noticed that the intake camshaft inlet that i was working on is not depressing or for lack of better word compresssing and uncompressing the valve spring to the open and close the valve when I was rotating the engine which might or might not epxlian why the car is only able to crank but not starting because the valve is not opening.
I can see motion on the exhaust side valve spring where they are being compressed and uncompressed when the engine is being rotated.
so i am wondering if the intake camshaft side valve spring should have some type of motion like up and down when the engine is being rotated by hand?
      11-17-2025, 01:28 PM   #2
Jros
Jros's Avatar
98
Drives: EUDM E92 325i 2006
check eccentric shaft position, if at minimum lift intake valves will not move or move like 0.1mm.
You can turn valvetronic motor with a 4mm hex in the back if you fit it to the head with cover off
EURO E92 325i N52B30 SWAP 6MT | N54 MANIFOLD | MILVS | 22RPD
Reply
