BMW 3-Series (E90 E92) Forum
Help with grinding noise on intake side of engine
| 09-18-2025, 07:32 PM | #1 |
Rep 3
I have a 2008 328xi e90 with an n52 that has a grinding noise on the intake side which gets faster when first accelerating then goes away at higher rpm, will do it at idle as well.
| 09-19-2025, 04:58 AM | #2 |
Rep 3,288
Drives: E92 325i MSport Coupe
Failed bearings in either alternator pulley or tensioner pulley..?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace with cross bar; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Carlson55041.00 |
| 10-16-2025, 07:50 AM | #4 |
![]() 98
Rep 132
if it goes away suddenly over 4k rpm, suspect disa valves rattle (if you have 'em!)
or maybe something related to oil pressure, a noise that gets faster with rpm could be lifters or nearby hardware, it may get better at higher rpm due to more oil pumping up there
EURO E92 325i N52B30 SWAP 6MT | N54 MANIFOLD | MILVS | 22RPD
kkasson551.50 |
| Bookmarks |
