BMW 3-Series (E90 E92) Forum
Titanium silver paint 354
| 05-18-2024, 08:14 AM | #1 |
![]() 98
Rep 200
What are the chances that this spray paint matches bmw titanium silver paint 354. Curious if anyone has tried to match it.
| 05-20-2024, 02:14 PM | #3 |
Rep 29
Even if you were to get 354 from BMW in a spray can, the chances of matching the correct variant that's on your car is probably 1 in 50. They've used that color code for so long that there are multiple variants within that code.
| 05-21-2024, 12:16 AM | #4 |
DIYer
576
Rep 561
No, actually the 354 paint match code is pretty much the same color. I have 354 touch up paint by scratches happen and it is quite a close match. The real issue in matching is the continuous metallic flake distribution in factory paint is much more even. Paint codes don't work as huge variation, it depends on the persons ability to weight up values to mix 354. Some other places use computers to do all the mixing on 354 which has specific values to reach 354.
This is using rustoleum silver paint (7715 aluminum) to touch up some rust chipped spot on the roof. Its really quite a beautiful paint. You can see the flake is a different size but fairly close. If need be, spray it onto a test surface and compare though I doubt that will be very close to 354. I did this with some rustoelum titainum silver and that paints flake is wayy too big. Found Krylon fusion Matte Glacier Gray is basically perfect match for paint inside the wheels. |
KKevin97.50 |
| 05-21-2024, 07:31 AM | #5 | |
![]() 98
Rep 200
Bims328i575.50 |
| 05-21-2024, 11:24 PM | #6 |
![]() 2622
Rep 4,526
It will work fine for something small like that. Anything bigger and the spray pattern will not look very uniform with the car. Even if you’re a half shade off you won’t notice ok something that small
| Bookmarks |
