BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > VO NUMBER???
Reply
      08-07-2020, 08:21 PM   #1
TheeE90
Drives: BMW 335XI Sedan
VO NUMBER???
Ok so I'm new to this whole coding thing but I'm trying recode the smc modules in my headlights and I understand that you have to have your VO Number and VIN number loaded into the NCS expert to do so... my question is where do I find my VO number??? Can I get it from INPA or something?
      08-08-2020, 08:23 AM   #2
ctuna
Drives: 325xi 06 wagon MT
In the normal process of running NCS expert for the first time
when you read the car it shows the VO which is not actually a number
but a list of installed options. When you do this you want to save
the trace file which contains all the original options for a backup
before doing things that involve programing coding or changing the VO.
You can also get the list of installed options by running a Vin checker.
mdecoder used to be a good one . I have heard reports it went to a payed
service.
      08-12-2020, 11:01 AM   #3
TheeE90
service.
Thanks Ctuna.. the VO that comes up in NCS Expert.. is that the full VO??
      08-12-2020, 12:31 PM   #4
ctuna
That is as much VO as any of us no about .
It is a list of the same options you would see running
a Vin checker though the Vin checkers do not show the
battery programming as far as I know.
If you modify the VO it won't be the same as factory so
its a good idea to keep a copy of the master file , the first
trace file generated when reading the car.
      08-12-2020, 05:50 PM   #5
opjose
opjose's Avatar
259
Drives: 335xi
https://www.bimmerpost.com/forums/sh...php?p=20964616
Reply
