TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N54 6speed transmission swap into N52
Reply
      04-27-2016, 02:24 AM   #1
DigiDon
DigiDon's Avatar
Drives: Alpine White E92
Ok finally completed this swap about two weeks ago and am very happy with the results. So far everything is working flawless.
I converted an already Manual N52 to Manual N54. This should work the same for an Automatic N52 but will need additional parts which I have not listed like pedal assembly and clutch master and slave and possibly programming or vehicle order coding.
The two top bolt holes on the transmission need to be enlarged and or offset as they are a couple mm off from the N52 Block, and a custom driveshaft will need to be made using either a front N54 driveshaft or Lexus GS300 front driveshaft. All other parts are OEM BMW. The N54 transmission is about 3" longer than the N52 transmission which made it impossible to reuse most of the N52 parts including the shifter mechanism and mounting parts.
I listed the parts that you should use and noted what I actually did with an *.
1. 23 00 7 571 423 Used One N54 Manual Transmission
*Purchased from LKQ/salvage yard
2. 21 20 7 590 942 New/Used One Flywheel
6 bolt N54 Flywheel, 01/2009 and up N54 Flywheel (MFactory single mass)
*Found two used one locally and one from ebay
*ended up using stock N52 Flywheel modified
3. 11 22 7 520 706 New Six Flywheel bolts
4. 21 20 7 536 792 New One Pilot Bearing
5. 21 20 7 603 248 New One Clutch Kit over 500hp stiffer pedal (335is/550i 6speed)
or
21 20 7 567 623 New One Clutch Kit under 500hp softer pedal (all other N54 6speed)
both kits include throwout bearing, disc, pressure plate, fork
*reused current E36 Pressure plate and made custom 6pad ceramic clutch disc
6. 21 20 7 548 047 New Six Pressure Plate Bolts
7. 22 31 6 796 993 New/Used One Transmission Support Bracket
Bolts to back of transmission, may come with a used transmission
8. 22 31 6 774 293 New/Used Four Bolts for Transmission Support Bracket
9. 22 31 6 799 331 New Two Transmission Bearing/Transmission Mount
* New E46 M3 Mounts reused stock N52 fastners/nuts
10. 22 31 6 778 059 New/Used One Transmission Crossmember
Moved further back on Chassis. Bolt holes ready.
*Reused stock N52 fastners/bolts
11. 26 11 7 610 061 New One Driveshaft Flex Joint/ U-joint/ guibo
*need longer Bolts N52 fastners too short
12. 26 11 7 527 475 New/Used Six Flex Joint Bolts
13. 26 12 7 536 563 New/Used Six Flex Joint Locking Nuts
*Can reuse stock N52 locking nuts
14. 26 11 7 526 611 New One Driveshaft Centering Sleeve
*inserted in front of Lexus GS300 Driveshaft after I removed Lexus Sleeve. It fits..
*front driveshaft is Lexus GS300 2JZGE driveshaft, center bearing and rear is stock N52
15. 25 11 7 524 720 New/Used One Shifting Arm
16. 25 11 7 507 695 New Two Bush Bearing Oval
*can reuse N52 bushing same if you can get it out without damage
17. 25 11 7 529 078 New Two Bolt/Clip for shifting arm to transmission
*can reuse N52 bolt/clips same
18. 25 11 7 524 722 New/used One Selector Rod
19. 25 11 7 571 899 New Two Selector Rod Clips
*Reused stock N52 clips same
20. 25 11 7 555 911 New/Used Shift Lever
*reused stock shift lever, modified lengthened and bent to fit
21. 25 11 7 539 193 New/Used Shifting Arm Bracket
*Small part and overlooked, can't drive without it
*Special order from Germany
22. 07 11 9 905 949 New/Used Two Locking Nuts for Shifting Arm Bracket
23. 25 11 1 220 600 New Shift Lever Bearing
24. 25 11 1 222 015 New Shifting Arm Bearing/bushing
*reused stock N52 Bearing same.
I ended up using the stock N52 Flywheel only because it was lighter than the N54 Flywheels. I modified it to be able to use the N54 flywheel centering pin.
I welded the two driveshafts together, front portion is the Lexus GS300 shaft welded to rear section N52 shaft.
Modified shifter
Appreciate 7
      04-27-2016, 11:03 AM   #2
Ruddigger
Ruddigger's Avatar
699
Drives: 2012 E91
Because the n52 transmission couldnt handle the 400hp he's laying down with his custom turbo setup.
My build thread.
It's a wagon with stuff on it.
      04-28-2016, 04:26 AM   #3
W37V
[Oo=||=oO]
No_Country
1143
Drives: e92n52 & f15n57
Amazing write up. Thank you for doing this. Also, how the heck did you come up with a Lexus part? Did you just have it laying around and figured, let me give this a try?
      05-04-2016, 04:28 AM   #4
WatashiEd
WatashiEd's Avatar
Australia
37
Drives: 2015 F82 M4 DCT
Subscribed Jayson!!! Sooooo inspiring!!! At the end of the day, it's not what your money can buy but what you can build that matters!!!
Sapphire Black M4 | iPE - Valvetronic exhaust | VRSF 3″ catless dp | Bootmod 3 Stage 2 | OEM LED alcantara steering wheel | OEM M4 GTS CF hood | Vorsteiner GT wing | M Performance CF splitter | Vorsteiner CF front lip | M Performance CF side skirt extension | 3D CF diffuser | OEM CF mirror cap | H&R lower spring | Rays Engineering TE37 Ultra Bronze 20x10F 20x11R
      05-27-2016, 09:28 AM   #5
Lovo
Drives: 06 323i
Read through his old thread and thought the exact same thing lol.
Guess he got lucky..
      05-31-2016, 02:56 PM   #6
tetsuo111
Save the Manuals!
tetsuo111's Avatar
Drives: E91 RWD 6MT, X3, Ducati S4R
DigiDon
Any updates and user feedback on your project post-install? Especially installing new MT SW and integration with the DME?
Weight Loss - In addition to the enjoyment from driving a stick, there ought to be significant weight loss benefits here. The N54 MT is 75# less than the N52 AT, per RealOEM. If one completely ignores the visceral gains of moving from AT to MT, and looks solely at weight, the cost per pound lost is actually equal to or less expensive than typical aftermarket lightweight parts.
I hadn't seriously considered a trans swap due to the economics - until now. The combination of performance gained together with losing a big chunk of mass, especially towards the front, is compelling. From one perspective, this would be like buying 75 lbs of lightweight parts, and getting a N54 MT thrown in the deal as a perk!
I love light and agile. I know - it would be better to have a Miata or Porsche instead. But a 3300# sportwagon with 300+ hp, 6MT, and stock appearance is very very compelling.
2011 6MT RWD ClubSport Wagon | 3,185lbs | 1 of 149 ZSPs delivered in North America
Outside: BMW M-Aero, Euro region lighting, Seibon | Inside: M3 cockpit, Recaro SPG, Prototipo, AutoSolutions SSK, UCP | Stop: M3 ST-40R, PFC | Grip: Solid-mounted subframes, rear coilover conversion, M3 Nitron R3, Hyperco, SPL, AKG, ARC8 | Go: StageFP, CF snorkel, 3IM, MILVs, SuperSprint headers, Dundon Motorsports Inconel exhaust, VoltPhreaks | Cool: CSF | PCA #2018100384 | BMW CCA #505794
      05-31-2016, 06:00 PM   #7
E91 M Sport
E91 M Sport's Avatar
Drives: 2012 E91 M Sport
Originally Posted by tetsuo111 View Post
DigiDon
He was already running a manual. The power was abusing the stock tranny that was bolted up to the n52 so he sought out the n54's.
      05-31-2016, 06:53 PM   #8
hassmaschine
Drives: "NBO" 330i
yeah, I don't think you really need to worry about using the N54 6MT unless you're making a lot more power than what the typical superchargers are putting out. the N52 6mt would be pretty close to bolt on.
removing the VO for automatic is pretty dang easy. I need to verify getting the DME to accept changes to the VO, but I have a pretty good idea of how to do it.
      06-30-2016, 12:16 AM   #9
DigiDon
DigiDon's Avatar
DigiDon
Sorry Been MIA..
Well I went from an N52 manual to an N54 manual just to have a stronger transmission. So far everything works perfectly. Transmission feels great, gearing is slightly different though.
In your case I would try to go with an N52 Manual if your not planning on going over 350hp. The N52 Transmission is lighter than an N54 transmission and would be a direct bolt up to your N52 engine (less modifications needed). On the other hand it is alot easier to get an N54 Manual transmission (more used ones available) and the used N54 transmissions are cheaper than the used N52 Manual transmissions.
Ruddigger699.00
tetsuo1111257.50
tetsuo1111257.50
tetsuo1111257.50
tetsuo1111257.50
      06-30-2016, 10:50 AM   #10
ZeroSum
ZeroSum's Avatar
37
Drives: E90 328i/MR2
Very nice.
2008 Monaco Blue 328i Sedan / Charcoal Delete / K&N Drop In Filter / RM Intake Boot / AA Tune
1993 MR2
      09-12-2016, 12:43 PM   #11
Hobbs64
Drives: 2007 328xi
Don,
I'm new on this forum. I was reading your post and wanted to first thank you, and second reach out regarding your turbo setup. I have a 2007 328xi. I just starting a project on the engine. I'm going to use the N54 block and crank with the N52 top end. I want to mate the to the N54 6 speed trans. and top the build off with a single turbo. That brings me back to your build. Would you be willing to share information on you turbo build? Thanks again for the info on the trans swap.
C.G.
      09-12-2016, 02:07 PM   #12
bmw201113
Drives: Bmw 328i coupe
What would be required to swap a n54 manual into a n52 automatic? Or if this project was seriously taken on would it be better off to just do a n54 automatic
      09-15-2016, 07:35 PM   #13
DigiDon
DigiDon's Avatar
Originally Posted by Hobbs64 View Post
Don,
C.G.
No problem. I will share any information on my build.
      09-15-2016, 07:36 PM   #14
DigiDon
DigiDon's Avatar
I don't have that information. I went from an N52 manual to an N54 manual. I guess it would be similar.
      09-24-2016, 11:12 AM   #15
e90dum
Drives: E90 LCI 328i manual
Why are his pics dead? Why is this forum the absolute worst about pictures?
      09-24-2016, 12:42 PM   #16
W37V
[Oo=||=oO]
No_Country
1143
People link to outside hosting sites and do not upload to the forum. Once the hosting site goes away, or link expires to hosting site, pictures are dead.
Always upload to forum.
      10-20-2016, 12:17 PM   #17
E82IsTheWay!
E82IsTheWay!'s Avatar
17
Drives: 2011 535i
or
Modified shifter
Your pics are gone bro!
      10-21-2016, 12:40 PM   #18
DigiDon
DigiDon's Avatar
Yep Not really sure how to fix that. They are on my Facebook page in a folder named "Project Turbo N52 328i" https://www.facebook.com/jayson.puna...7132103&type=3
      10-24-2016, 11:23 AM   #19
Ruddigger
Ruddigger's Avatar
699
Drives: 2012 E91
Upload them to imgur and link them from there.
My build thread.
      12-12-2017, 02:58 PM   #20
tsm007
tsm007's Avatar
Drives: 2016 BMW 328i
2016 BMW 328i  [0.00]
2008 BMW 328xi  [10.00]
2003 Honda CBR954RR  [0.00]
Hat off to you. Amazing job.
Instagram: TSM_007
      11-18-2018, 11:00 PM   #21
Eagle1oh7
Eagle1oh7's Avatar
Drives: '11 328i Sedan
So why couldn't you use an OE driveshaft for the 6MT?
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod
      12-04-2023, 12:09 AM   #22
Blau
J
Blau's Avatar
Drives: BMW 128i
2011 BMW 128i  [6.00]
2013 BMW X3 28i  [0.00]
3. 11 22 7 520 706 New Six Flywheel [...]
Old thread, but maybe you'll respond. The pics aren't loading and I was hoping you could reshare the modifications you made to the flywheel and bell housing. I am trying to pop this trans into a 128i.
Reply
