TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Reset your Oil count down after oil change on (e46 and up) SIA IV system
Reply
      12-27-2007, 12:14 AM   #1
LACA335i
LACA335i's Avatar
Drives: E92 335i coupe Black AUTO
2007 335I SEDAN  [0.00]
Here is helpful information for people who want to change your oil at home and reset the oil countdown. This procedure work with E46 and up. It might work on e90 335i and e92. Im not really sure how the new 335i reset oil count down work. Since it is using the fob. im prety sure it work the same way as the e46 model. i will mess around with it..
Procedure: on e46 (manual reset mode) on 2001 vehicle onward without the diagnostic connector in the engine compartment.
1. ignition key must be "off"
2 Press and hold the odmeter button in the instrument cluster (left button) and turn ignition key to the first position (KLR)
3 Keep the button pressed for about 5 to 6 seconds until one of the following word appears in the display "oil service" or inspection' with "reset"
4 release the reset buttom and press and hold it again until "reset" begin to flash.
5 while the display is flashing, press the left button briefly to reset the service interval. After the display has shown the new interval. th following appears "end sia"
NOTE: The system can only be reset again after 10 liters (2.5 gal of fuel have been consumed)
Any BMW dealership technician wanna confirm this.. ???
      12-27-2007, 01:02 AM   #2
e92phreak
e92phreak's Avatar
Drives: E92 335i TiAg/E46 323i TiAg
2007 E92 335i  [9.50]
2000 E46 323i  [0.00]
Thanks for the info... was just going to reset my E46 but forgot the instructions LOL...
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo
      12-27-2007, 02:38 AM   #3
LACA335i
LACA335i's Avatar
you r welcome
      12-27-2007, 02:44 AM   #4
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
The dealer wanted to charge me $68 for this simple DIY..........
I hope it works............
THANKS!!!!
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      12-27-2007, 02:58 AM   #5
LACA335i
LACA335i's Avatar
THANKS!!!!
it should work.. let me know ... for reseting the oil service light on by manually.. I got it from a BMW step trainning programed cd. im part of the BMW program
      12-27-2007, 03:40 AM   #6
LACA335i
LACA335i's Avatar
THANKS!!!!
which dealership did u call or go to? i think their labor cost is around 120 per hour. There are couple way to reset the oil service light. One of them is by factory oem scan tools it only take them like 5 mins to reset it for ya.
      12-27-2007, 11:07 AM   #7
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
BMW of Riverside.....just got my 2nd free oil change last week at 40k miles.
      12-27-2007, 10:15 PM   #8
Jaws
Jaws's Avatar
Drives: 2006 325i mt
Why would you want to reset the oil life counter? You're just screwing yourself out of free oil changes.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red
2007 Chev Silverado crew cab Z71
      12-27-2007, 10:23 PM   #9
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
I need to do it after my warranty expires.........
      12-27-2007, 10:28 PM   #10
LACA335i
LACA335i's Avatar
so you got about 10K mile to go until your warranty is expire.
      12-27-2007, 10:30 PM   #11
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
yep........and i'm not even going to worry about reseting the counter until it reads negative.....
      12-27-2007, 11:46 PM   #12
jon@themshop
jon@themshop's Avatar
Drives: BMW
The E90 systems do NOT use SIA IV. It's a new system called CBS which stands for Condition Based Service.
Just because the procedure you posted works for the E46 doesn't always mean it'll work on the newer BMW's like the E90.
Instructions to reset service operations can be found on the E90 Driver Information Systems on page 65.
What "part" of the BMW program are you talking about?
      12-28-2007, 12:13 AM   #13
LACA335i
LACA335i's Avatar
BY the way, thank for comfirm it.
Im not sure about e90 car because they might have new system. i know for sure it will work on e46 from 2001 and newer model. i also state "It might work on e90 335i and e92. Im not really sure how the new 335i reset oil count down work. Since it is using the fob. im prety sure it work the same way as the e46 model. i will mess around with it.. "
Im going throught the BMW Fasttrack PRogram that offer for UTI graduated student by the BMW Manufactory. After completion of the 12 weeks course you will get 7 BMW Specific Certification... Majority of the tech at bmw dealership either already have experience for many years or graduated from Either Step or Fasttrack program trained by BMW
      12-28-2007, 12:32 AM   #14
jon@themshop
Drives: BMW
So are you a UTI graduate?
      12-28-2007, 01:01 AM   #15
LACA335i
LACA335i's Avatar
yes sir. i believe i meet you once long time ago..
Reply
