Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Heated Steering Wheel Retrofit
Reply
      05-19-2020, 06:34 PM   #133
toddyus
Drives: 2011 335i x-drive
Originally Posted by toddyus View Post
A couple questions for the new 12 and 3-pin connectors:
  1. Do you need a special tool to remove the pins from the existing 12-pin connector?
  2. For new wires that you're adding, are you using crimp connectors to place into the terminals? If so, what crimp connectors are correct?
Thanks.
Nevermind. I re-read the thread and found the answers.
      05-19-2020, 09:40 PM   #134
infinite_creations25
Drives: 2026 BMW M3 Comp xDrive
AFAIK, the angle sensor is located in the SZL and not clock spring. As long as the SZL is not spun at all, coding/recalibration shouldn't be needed right?
      12-24-2020, 11:53 AM   #135
Sh0ty
Sh0ty's Avatar
Drives: 2021 G05 PHEV, 2007 E92 328i
Does anyone have the part number for the terminal that plugs into the heated steering wheel switch its self?
My switch, as well as many others I see on eBay do not come with the small harness that plugs into the 3 pin unit listed in this guide.
Thanks!
      12-24-2020, 12:19 PM   #136
Clammy
Drives: 2006 330i 6MT
Thanks very much for this!
I recently did this install, and thanks to this DIY, it took me about an hour to complete.
This is one of the best mods I've ever done to a vehicle! I will never own another car without a heated steering wheel!
Cheers!
      12-30-2020, 05:42 PM   #137
Sh0ty
Sh0ty's Avatar
Thanks!
Wasn't able to get the original BMW part, however another user (I couldn't find it again in this thread) found that Seeed Studio makes a 4 pin 2mm pitch harness that fits. I sourced it from Mouser in a 5 pack, so if anyone needs this harness, PM me and I'll happily mail you one for the price of postage at cost. I ended up shaving the fins and top of the connector for a more secure fit:
From here, I'll just clip the unused wire and then wire it directly to the 12 pin connector, obviating any need for the 3 pin connector detailed in this DIY.
Thanks everyone for the great resources here!
      01-09-2021, 06:27 AM   #138
C10EXR
Drives: Bmw e92 335D
Hey. I have a bmw e92 335d in uk. Just purchased all the parts needed except wiring. Will your information on wiring be the same for my car or if you know of any difference could you please let me know. (Just signed up to this forum so unsure how to message? Thanks!!
      01-10-2021, 09:58 AM   #139
Mkals
Drives: Bmw 320d E90
It can be installed on a manual car? I always find a steering wheel with paddle shift.
      01-13-2021, 01:08 PM   #140
pdubsalot
Drives: 2006 BMW 330xi
Which three wires did you use? Or does it matter?
      01-17-2021, 11:16 AM   #141
Milladyjm
Drives: 335d, X5d, F31-d, Evo X
To anyone who has done a heated wheel retrofit, can anyone point me in the right direction here? Where does the brown wire on the right go? Does that get grounded anywhere? And the two wires on the bottom, is it correct that those will run to the fuse box for power and ground?
      01-20-2021, 04:18 PM   #142
Sh0ty
Sh0ty's Avatar
Red, white and yellow. The 4th pin on that switch is unused.
      01-20-2021, 04:27 PM   #143
Sh0ty
Sh0ty's Avatar
Originally Posted by Nickco43 View Post
The brown wire from the switch (pin 2) runs to ground.
The green striped wire (pin 9 from the 12 pin connector) runs to 12V from a switched fuse (I used a Bussmann fuse tap)
The brown wire (pin 7 from the 12 pin connector) also runs to ground.
      01-30-2021, 11:19 AM   #144
bigrock07
Drives: 2015 F83 M4, 2021 M340xi
Has anyone done this retrofit into a pre-lci? I have an 07 e93 335i and I got the parts from a lci e92 and I made the harness(minus the correct size wires) but it isn't working. When I plug it all in the heated wheel doesn't work, and neither do my steering wheel controls. Could this be a bad clockspring? I checked wires they are getting 12v and followed the wiring diagram correctly. Thanks for the help I'm excited for this retrofit.
      01-30-2021, 01:48 PM   #145
Nickco43
Nickco43's Avatar
1713
Drives: 2016 BMW X1
Your clock spring is bad.
      02-01-2021, 03:28 PM   #146
Clammy
I did the retrofit into my '06 330i, and it works AWESOMELY!
Cheers!
      02-01-2021, 03:32 PM   #147
vilord
Drives: E91, Tundra, TT, SV650
+1 bad clock spring.
I did this retrofit in my 2007 e91 with a wheel from a 2010 e92, drove with that for 2 years, then after that car was wrecked, took the same wheel and controls with a new airbag to the '09 e91 lci i have now. It is my step-daughter's favorite feature of the car! (with "stiff steering wheel" being her least favorite)
There wasn't any change as part of the LCI to those components.
Jesse
      02-07-2021, 09:59 AM   #148
relative4
Drives: '08 335xi E90 MT stage 1+
Hi guys, part number question. Early in the thread, part number 32306795568 was specified as the heated steering wheel. If I read realoem.com correctly, 32306795568 is the non-heated steering wheel, and the heated steering wheel is 32306795569. Do I have that right?
The car is a 2007 335xi E90 auto, non M-sport, no paddles.
      02-10-2021, 10:22 AM   #149
Canuck335
Drives: 2011 335ix Sedan 6MT
I think 32306795568 is a newer substitute for the original un-heated wheel, 32306764546.
If you look at this link
https://www.realoem.com/bmw/enUS/sho...diagId=32_1565
You see 32306795568 is heated.
So I'm thinking they just sub 32306795568 for the non-heated one going forward.
      02-10-2021, 10:57 AM   #150
relative4
Actually, that page, which is where I got the information in the first place, implies pretty clearly that 5568 is not heated, and it states much more clearly that 5569 is heated. I have confirmed that the heated wheel is 5569.
      02-15-2021, 03:38 PM   #151
Mkals
Anyone knows if is it possible on manual car? I always found a steering wheel with paddle shift :S
      02-15-2021, 03:46 PM   #152
david in germany
Drives: 118i, 335i and 328i
Yes, keep looking.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
      02-15-2021, 03:59 PM   #153
Mkals
Perfect. But is the method to do the same as this DIY?
      11-13-2021, 03:06 PM   #154
uche.oj
Drives: BMW E91 320I
Hi all I'm new to the forum and I'm not quite sure how it works. Just bought the heated steering wheel, clockspring and switch. I was wondering if the custom cable could be made for me?
Reply
