BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > What did you do to your car today?
Reply
      04-17-2020, 03:01 PM   #11661
Serf27
Serf27's Avatar
2971
Drives: 335i
Originally Posted by 335IE90 View Post
Looking to do walnut blasting soon how was it getting the manifold off that's all I'm dreading
It’s easy!
It took longer to remove the junction box from the manifold than it did to remove everything else. Reason why I ziptied the box, next time should only take 5 min to remove the manifold.
I recommend removing the screws that hold the junction box on the manifold, rather than trying to unclip it from the bracket.
      04-17-2020, 04:32 PM   #11662
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I got it on and that is a brand new tensioner from fcp car is running realized it was a t60 a little to late I was using a t55: but I got it on with a t60 there was still some meat left in there to grip on to
I'd order another belt tensioner & use your lifetime warranty for the part. When it comes in, swap it out and return the crappy one with the stripped t60, for a full refund.
Better than needing to get the belt off down the road and realizing you have to tread carefully!
I'd also look into investing into an 18", 1/2 drive power bar with a 1" extension, if you don't have one.
Also torx sockets wear down quickly if you use them a lot and own a mediocre, quality set like Lisle for example.
The best torx socket set I've ever owned is made by OTC.
OTC 5900A-Plus 52 Piece Master Square Drive Torx Set https://www.amazon.com/dp/B000YOVIIU..._DbIMEbXXYAA0J
      04-17-2020, 04:58 PM   #11663
oVeRdOsE.
oVeRdOsE.'s Avatar
4714
Drives: F25 E91N54 Audi Avnt Cayenne
B7? What's going on with that
meth kit purge. new battery. Out of the storage.
I dont plan to get it on the road soon...
      04-17-2020, 05:15 PM   #11664
S65Hunter
S65Hunter's Avatar
No_Country
1345
Drives: 2009 E92 M3
  [0.00]
Made it a hover craft......
upload
That's actually not even my car though. Just thought it was a funny pic.
nuron91.50
MadJoe55.00
      04-17-2020, 05:22 PM   #11665
blown07
blown07's Avatar
211
Drives: 335i
upload
That's a sweet lookin post-pre-LCI.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
      04-17-2020, 07:06 PM   #11666
apexit4
Poland
1246
Drives: 335D M-Sport, X5D
Originally Posted by Serf27 View Post
I’ve done a lot in the past few days and it’s added up so here are a lot of pics!
I added the factory oil cooler with new gaskets.
New aluminum coolant fitting that bolts to the head.
While the manifold was off, I decided to clean the valves using carb clean and valve cleaner. This makes a mess and I recommend walnut blasting for a cleaner and better job and it costs about the same in material!
Added a T fitting on the vacuum line at the TB for PCV delete.
Zip tied the junction box that is attached to the manifold to the fuel rail.
Also may have found what injector may be causing me some issues! This index 1 injector.
Today I’ll probably enter hell and most likely remove the whole front end to swap in this oil cooler bracket.
How'd you actually get at cleaning the valves that way without leaving any gunk behind. Access through the opening looks very tight...
      04-18-2020, 12:09 AM   #11667
Duraslack
Drives: BMW 328i
Stared at this one rock chip on the hood that has rusted over, for too long.
      04-18-2020, 12:55 AM   #11668
Serf27
Serf27's Avatar
2971
Drives: 335i
I used a soap dispenser to pump out all the valve and carb cleaner that turned into fluid.
Then I used a vacuum to to suck of any gunk and then while using the vacuum, I blew air in there.
Let the valve cleaner sit over night.
Pumped out, sprayed carb cleaner and brushed a bit then lit the cleaner sit a few minutes and pumped/vacuum/blew it out.
Did the carb cleaner step about 3 times to get them clean.
First few valves were trial and error and made a mess of the engine bay.
I installed a dual catch can set up today. My friend thinks there’s a more efficient way to run the PCV system. Anyone with great knowledge of the PCV system, please chime in this thread.
Thanks.
https://www.e90post.com/forums/showt...4#post26064094
apexit41246.00
      04-18-2020, 09:17 AM   #11669
Afanz
Drives: 2009 BMW 328xi
Nice Country Drive
Took it out for an hour to get it nice and warm down some old country roads. Still surprises me how much the E90 328 is on windy roads. Found an old airport to take cool pics. Love this car!
      04-18-2020, 03:51 PM   #11670
335IE90
335IE90's Avatar
Drives: Bmw 335i
Fixed the peeled start button with a little bit of matte black wrap was looking for my carbon black carbon wrap but couldn't find it so this will doo I think it turned out decent
      04-18-2020, 05:51 PM   #11671
MadJoe
Drives: 2011 328i
Finally installed my paddle shifters to the new Sport Steering Wheel, and bought some 18" rims. Waiting for the tires is killing me.
      04-18-2020, 06:57 PM   #11672
335e92tx
ahat
335e92tx's Avatar
1109
Drives: Was '07-335e92 - Now '13-335IS
About to put a full BAVSOUND setup in
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos.
https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8
tlow983151.50
nuron91.50
335IE90307.00
      04-19-2020, 12:15 AM   #11673
buzzybee
buzzybee's Avatar
48
Drives: e92 m3, e92 335i, f82 m4
flashed MHD stage 2 (v9) and took it for a little canyon run. It was really nice to go for a little spirited drive and Im really loving stage 2 except now its becoming very clear that I badly need an upgraded FMIC.
335IE90307.00
      04-19-2020, 01:13 AM   #11674
salpone
salpone's Avatar
Italy
125
Drives: Bmw E92 320d Msport
I have to paint my wheels again.
these plates I have to make them of another color and without writing
Silnismo233.00
      04-19-2020, 07:00 AM   #11675
335e92tx
ahat
335e92tx's Avatar
1109
its ok man,, that wont be the only time you need to see the betty ford clinic about BMW mod mania.
Good luck with rehab.
      04-19-2020, 07:50 AM   #11676
335i Denmark
Drives: BMW 335i
I just installed this analog boost pressure gauge
I am stock but DCI. Only bosting 0,4 bar however maybe its because of the outside temp. (10-12 degree Celsius)
      04-19-2020, 04:05 PM   #11677
GRUESOM3
GRUESOM3's Avatar
1106
Drives: 3 NA cars and 1 Turbo car
Installed a new gas cap. The rubber string broke on the oem and was bothering me.
Also installed a new cowl piece because the monkeys that replaced my first windshield broke some of the tabs.
Now I gotta wash that engine bay.
      04-19-2020, 05:11 PM   #11678
colorado.e9x
eBay Special
colorado.e9x's Avatar
4305
Drives: E90 330xi, E90 328xi
2006 BMW 330xi  [10.00]
2007 BMW 328xi  [8.33]
Does your gas cap click at the end or does it just go in? My old pre lci one clicked in and felt nice, my new one from oreillys feels cheap and just goes in like a regular cap.
Common sense is a flower that does not bloom in everyone's garden
      04-19-2020, 05:54 PM   #11679
GRUESOM3
GRUESOM3's Avatar
1106
It doesn't click, my old one clicked but then stopped clicking as well. This one I got from ecs tuning was pretty cheap so I can't complain.
      04-19-2020, 07:51 PM   #11680
Boosted12a
Drives: BMW 335i x
Pulled my injectors to see if they were leaking. Every dam one put out a nice fine spray that you could barely see. So, $1400 later I have some on the way from fcp. They were -7 so I think they put in time. I noticed the starting issues at around 101k(3k ago). One more thing I won't have to worrie about replacing latter!
      04-19-2020, 08:46 PM   #11681
Serf27
Serf27's Avatar
2971
Drives: 335i
Installed this bar just for looks.
I didn’t want to cut the shroud so I placed it in the back. It’s barely noticeable and that was the whole point lol.
Not sure if the time spent putting it on was worth it...
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black
E91 328 M Sport-Alpine over Black-Alpine over Saddle brown.
E93 335i-DINAN tuned. Alpine over Saddle brown
Silnismo233.00
      04-19-2020, 08:57 PM   #11682
Boosted12a
Drives: BMW 335i x
What dose that bar do?
Reply
