BMW 3-Series (E90 E92) Forum
Hesitation @ low RPM
| 02-26-2017, 08:51 PM | #67 |
Rep 9,004
| 02-27-2017, 10:01 AM | #69 |
![]() 793
Rep 1,001
| 02-27-2017, 07:24 PM | #70 |
Rep 797
2f7b oil pressure switch plausibility
29e0 fuel oil mixture control 29e1 fuel mixture control 2 2d06 air masss system 2d29 differential pressure sensor, suction pipe plausibility 29dc cyl injection switch off these are the codes ive pulled from my car when I first had this problem...all symptoms like you guys slight hesistation surging and even car dies atleast once or twice a month..i just pull over shut off the car and start it back up again and its good to go sometimes even runs better its been like this since about November (I installed headers and 3IM with AA tune) that's when all the problems started happening as of today still running like that but it was bareable now my car sounds like a montercarlo (not in a good way lol sounds more rumbly and went in limp mode today) very sluggish will be tackling maf and throttle body tomorrow and after that maybe coils and plugs as I already have plugs. will update tomorrow. |
| 02-27-2017, 11:33 PM | #72 | |
Rep 778
NONE of which I would have an issue replacing (love the car) but doing all for no reason is not attractive... ![]()
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD . M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings . BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts . Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete |
| 02-28-2017, 12:52 AM | #73 | |
![]() 1064
Rep 2,114
| 02-28-2017, 02:43 AM | #74 |
Rep 11
2006 330i 219000KM
Reading through this thread it sounds like at least some of you have the same issue I am chasing. Here's my description: When starting the car cold, the engine stumbles for perhaps a second, maybe two then smooths out. If I put it in gear when this is happening it surges, sometimes pretty hard. With the car in park and idling fine if I mash the throttle to the floor it will also stumble. Most of the time it recovers and revs at which point I of course release the throttle, other times it may actually die. Today when I went to start it after work, it took four tries to get it to stay running, and this is the worst it has been. Since this car is new to me I am going through it and doing maintenance so I know where things stand. As part of this and to address this issue I've replaced the MAF after cleaning the original did not help. There have not been any codes, but I will check it again since I need to reset the oil change interval anyway. I will be happy to replace the coils if there is good indication this will help. I suspect they are pretty old, since I have not been able to disconnect the electrical connector for a few of them (I tried quickly, didn't put much effort into it... They didn't easily come off though). After this I'll pull the DISA's and inspect and from there the throttle body. |
| 02-28-2017, 08:35 AM | #75 | ||
Rep 797
| 02-28-2017, 09:01 AM | #76 |
![]() 1064
Rep 2,114
Reason I asked you could be having electrical connection issues. Most of the codes you posted indicate lean air fuel. You may have a vacuum leak around manifold. But why you got the injector error? The MAF code indicates electrical also in my experience, but mine is 06 car so uses analog output, later years are digital output mafs. Lean may be because of fuel pump or regulator too, but then why Maf error?
| 02-28-2017, 09:08 AM | #77 | |
![]() 1064
Rep 2,114
| 02-28-2017, 09:12 AM | #78 |
Rep 9,004
Well, car went into a limp/ studder mode on my way to work. Bank 1 and 2 o2 sensor codes, mixture codes and manifold pressure sensor code, plus 1 unknown...
Thoughts? |
| 02-28-2017, 09:59 AM | #79 | ||
Rep 797
| 02-28-2017, 10:00 AM | #80 |
Rep 797
Same this is what im getting man
| 02-28-2017, 11:10 AM | #82 |
![]() 1064
Rep 2,114
| 02-28-2017, 11:15 AM | #83 | |
Rep 9,004
Intake manifold pressor sensor error Mixture error O2 sensor errors |
| 02-28-2017, 03:28 PM | #84 |
![]() 1064
Rep 2,114
"Electrical connection problem" not sensor.
We take the connections to be working as granted but they don't always. All those sensors giving error at the same time could be because of a large connector at a junction box not being seated well or got dirty pins or similar resulting in intermittent issues. I had my share with the MAF connector but I had rich and Maf error. The above post has errors on oil pressure switch, map, Maf and ITA sensor. I wonder if their wires all go to the junction box under intake manifold. |
| 02-28-2017, 04:32 PM | #85 |
Rep 9,004
| 02-28-2017, 07:58 PM | #87 |
Rep 797
| 03-03-2017, 04:46 PM | #88 |
Rep 11
| Bookmarks |
