Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Heated Steering Wheel Retrofit
Reply
      07-30-2019, 12:53 PM   #67
Zap
Drives: 2009 BMW M3 Convertible (JZB)
Originally Posted by Nickco43 View Post
They never made a M3 heated steering wheel.
Ah, that's too bad - thanks for confirming that to be the case.
F30 (2017 340xi): 6MT Mineral Grey - CWP, DAP+, Lighting, M Sport, Tech, Track, M Rockers, MPPSK CF
E93 (2009 M3): 6MT Jerez Black - Ext Leather, CWP, Prem, Tech, Rear PDC, Premium Sound
M3 Retrofits [Alarm (w/ door sensors), FLA Mirror (Auto High Beams), Dyn RVC, Front PDC]
Past (6MT) 2007 E92 SG - 2007 E92 MB - 2014 F30 335xi EB II
      08-20-2019, 05:28 PM   #68
Canuck335
Drives: 2011 335ix Sedan 6MT
Thinking of doing this.. couple questions.
1. How can I tell if my airbag will fit the replacement steering wheel?
2. My 2011 335xi Sedan came with the M-sport package and I'd like to keep the ///M badge on the bottom spoke. Are all the cover trims on 3-spoke wheels interchangeable?
      08-20-2019, 06:09 PM   #69
gamesfrager
Drives: 2011 328i
Correct me if I'm wrong, but I believe sport and M wheels are the same trim and airbag.
The none-sport steering wheel has a different airbag.
I went from none-heated none-sport to heated none-sport => same airbag
Then I bought heated sport steering wheel and I had to buy it with the sport airbag.
      08-20-2019, 11:16 PM   #70
Canuck335
Could you please share the P/Ns for the sport wheel and airbag?
I currently have this
https://www.realoem.com/bmw/enUS/sho...diagId=32_1617
and it looks like I'd need this (not quite an M-Sport but perhaps close enough?)
https://www.realoem.com/bmw/enUS/sho...diagId=32_1519
Also does anyone know if a heated M-Sport wheel from an F30 work on an E90?
      08-21-2019, 12:44 AM   #71
gamesfrager
Drives: 2011 328i
Sorry, I don't have parts number. I just went from none-sport and just bought a whole steering wheel with its airbag.
As for the F series, you would need an emulator/control board that's about €200+ or so to convert the signal from the wheel controls to a signal that our E series understands.
But if you are going such route, might as well get an E9x custom wheel with flat bottom, nappa perforated leather etc.
You can find them on ebay.
      08-25-2019, 10:24 AM   #72
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
687
Drives: BMW
So, i also retrofitted the heated steering wheel but forgot to post about it
      08-25-2019, 01:50 PM   #73
6ixSpd
Save the manuals!
6ixSpd's Avatar
6227
Drives: '12 M3, '19 X5, '23 718 Spyder
You don't need a new airbag, the one you have is the same.
The trims are also exchangable. Just push the spokes of the wheel into the tabs of the more angular M-Sport trim. This is what I've done on my car as well: https://www.e90post.com/forums/showthread.php?t=1596605
Canuck335171.50
      08-25-2019, 06:20 PM   #74
Canuck335
Thanks.. I've acquired a sport heated wheel, clock spring and trim with button.
Going to order the connector parts tomorrow.
This place is like crack.. I came into these forums to investigate how to get Carplay working and now I've spent almost $1000 on upgrades!
The steering wheel cover is enticing.
      08-30-2019, 10:31 AM   #75
Canuck335
Got it done and would add the following hints and tips. Some of them are for noobies like me
1. When ordering the 3-pin connector 61136931929, don't forget to order the pins with it! I didn't read RealOEM correctly and got an empty shell for the connector. I ended up cannibalizing other connectors I had for pins.
2. To clear up any confusion about the harness you have to make:
- The backside of the non-heated clockspring has a 6-pin connector (plus another 12-pin connector). When you look at the heated clockspring both connectors are 12-pin. It's this 'new' 12-pin connector where the wires for the heated steering wheel get connected. You'll be connecting 2 pins from the heated steering wheel switch, plus ground and a +12v fused supply.
3. I used fuse #5 for my +12V supply. On my car this position is unoccupied and according to the wiring diagram it's this fuse location that's used for cars with a heated steering wheel. The nice thing is that the heat turns off with ignition so you don't have to worry about the heated wheel staying on and draining your battery.
4. Before removing your original steering wheel, adjust the wheel height and extent so it's in the middle of its travel. This makes it easier to remove and install the trim pieces which fit together like a toothed clamshell. In all honesty this was the toughest part of the job. Also cable tie your new wiring to the factory harness, up and out of the way - there is no clearance on the lower side of the trim assembly.
hope that helps.. happy to answer any questions!
      09-17-2019, 09:34 AM   #76
CaprE92
Drives: BMW 335i Coupe
part numbers for pins
Hi Canuck 335. Do you know the part numbers of the pins I need for the two connectors? Wasn't successful so far in finding the right ones...
Thank you in advance for your help!
      09-17-2019, 10:26 AM   #77
Canuck335
Sure you need the following:
1. Female pins: Qty 4 61130005197 for the 61136954518 12-pin connector
https://www.schmiedmann.com/en/product/1956991-new
2. Male pins: Qty 3 61130005198 for the 61136931929 3-pin connector
https://www.ebay.co.uk/itm/BMW-Pin-c...-/282671546923
I would inquire with your local BMW dealership on these first.
They may have local stock and perhaps lower pricing. I was lucky and got the parts the next day.
      09-18-2019, 04:05 AM   #78
CaprE92
Thanks for your help and your tips! I just saw that on those pins, there's already a cable crimped.
Since I'd prefer those without cable, I was looking for them and I found part number 61131393703 (instead of 61130005198) and part number 61138369696 (instead of 61130005197 with cable). Are those the same parts just without the cable?
Thanks again for your help!
      09-18-2019, 10:12 AM   #79
Canuck335
Yes, those look like the right ones. Should work fine if you're able to crimp your own wires.
      09-19-2019, 03:02 AM   #80
CaprE92
Thank you very much. You've helped me a lot!
      10-02-2019, 08:56 AM   #81
Maniac0908
Maniac0908's Avatar
Drives: Alpine White 07 335xi Sedan
Where did you guys tap ground? And can ground wire for button be tied into ground for heat?
      10-03-2019, 08:27 PM   #82
gamesfrager
Drives: 2011 328i
There is a big screw on the left side on the fuse box as Nickco mentioned to me and worked great.
      10-14-2019, 02:01 PM   #83
nagybalazs
Drives: BMW 330i E90 6MT
I did this retrofit, however, my heater turns off after about 10 seconds. Based on my research, I'm thinking I need to replace the heated steering wheel module. Does anyone know the part number for this or where I can get one?
Thanks!
      10-14-2019, 02:06 PM   #84
gamesfrager
Drives: 2011 328i
Thanks!
I believe it's this https://www.ebay.ca/itm/09-2009-BMW-328i-Heated-Steering-Wheel-Control-Module-61319166341-OEM-2867W-/163674261161?nav=SEARCH
      10-20-2019, 09:20 AM   #85
bimmerzeit
Drives: E28, E39, E90
Wow nice write up! I definitely would like the heated wheel upgrade in my winter car. Jealous of the heat in my wife's X5, it is a great option for those of us who endure 6 months of cold every year.
      10-23-2019, 01:17 PM   #86
Canuck335
Another good place, if you have it, is the 12V Aux power outlet in the passenger side footwell. The brown wire is ground.
      10-30-2019, 05:12 PM   #87
bimmerzeit
I just missed a mint 135i heated wheel for like $150 on eBay. Procrastinated too long.
      11-09-2019, 11:49 AM   #88
Soravia
Drives: 2011 E91 Silver xDrive 6MT
Here is the heater control module to go inside E90, E91, E92, E93, E82, E83, E84 X1 steerings.
Part number 61319217865
They all fit the same.
https://www.bmwpartslink.com/oem-par...ol-61319217865
Reply
