BMW 3-Series (E90 E92) Forum
Post Your SULEV Warranty Success Stories
| 04-02-2018, 11:58 AM | #67 |
Rep 26
a) Had hard start problems followed by CEL, DSC, and BRAKE lights. Also had a high pitched whistle noise. Diagnosed to be crank position sensor was cause of hard start. PCV valve malfunction cause of whistle. Replaced crank position sensor, valve cover and valve cover gasket.
b) $0 c) SULEV warranty covered completely d) No hard time, as a matter of fact they brought up the SULEV warranty!!! e) Not one bit! BMW of El Cajon was the dealership |
| 05-02-2018, 11:25 PM | #68 |
Rep 322
a. Changed my spark plugs over the weekend and I noticed oil seeping into one of the cylinders. Other dealer said only VCG covered if it involves check engine light but said I had a crack in the cover. Brought it to another dealer for an oil change and mentioned that and SULEV. SA said he would ask for me. Changed out the valve cover under SULEV.
b) 96 for the oil change c) SULEV covered d) No e) No Done at BMW of Henderson , car registered in CA
Add Ons: Charcoal Filter Delete, K&N Drop-in, Air Scoops, HID Angel Eyes, Splitters, M3 Lip Spoiler, Gloss Black Kidney Grills, Blackvue DR500-GW, M-Tech rear, BMW Performance Exhaust, M3 control arms, Bilstein HD
| 05-02-2018, 11:34 PM | #69 |
![]() ![]() ![]() 2861
Rep 12,981
Garage List E86 Z4 M GTS [9.91]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.53] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
Good stuff guys... keep posting. Really good info for us high mileage SULEV owners!
| 06-01-2018, 10:46 AM | #70 |
Rep 634
Is there a consensus on whether or not the Valve Cover is covered on SULEV vehicles?
If the Valve Cover is leaking oil... Wouldn't that cause it to fail the "California Smog Check test or EPA approved short test"? I see some success here, and others posting that they had issues.
ED & PCD = DONE & DONE! 08' AW/Coral 335i coupe 6-speed (Premium Pkg, Sports Pkg, Heated Seats) *European Delivery
| 06-01-2018, 01:23 PM | #71 | |
Rep 289
Drives: 2023 M340i (Build)
| 06-01-2018, 02:23 PM | #72 | |
Rep 634
Basically, I pleaded my case with the service manager, and he gave me a discount on the valve cover; agreeing to put it on while they replace the VCG under SULEV. I get the dealer's point, but the whole thing is ridiculous, and based on the wording in the SULEV warranty, the valve cover should be covered. Maybe it's a reach, but for the failure rate of these things AND their own SULEV warranty.. There should be a class action lawsuit against BMW for this.
Fritzer1024.50 |
| 06-03-2018, 07:01 AM | #73 |
![]() 2
Rep 42
2009 328 Xdrive
I’ve had a fuel pump and thermostat replaced under SULEV. My dealership hasn’t given me an issue yet but I’ve only gone in when I was just about certain what the issue was and if it was covered. I always feel weird pulling into the dealership service bay with a 2009 and 90k.... I don’t belong there anymore. |
| 06-18-2018, 05:37 PM | #74 |
Rep 1
Drives: 2009 328xi 2007 328xi Coupe
Garage List 2007 BMW 328xi Coupe [0.00]
2006 BMW 330 ci ZHP [0.00] 1987 VW Scirocco 16V [0.00] 1997 BMW 328 ci [0.00] 1982 BMW 320i [0.00] 1974 BMW 3.0 CS [0.00] 1976 BMW 2002 [0.00] 1974 BMW 2002 [0.00] 1969 BMW 2002 [0.00] |
So the E90 is my wife's car. Mine are older BMW'S. I saw your thread on the SULEV warranty and wanted to add our recent experience. The car is a 2009 328xi with about 115,000. We reside in upstate NY and have to deal with state inspections annually. This car has been a challenge the last couple of years due to the radiator and the sensor. I made it a goal this year to deal with it early since she wants to keep the car for a while longer.
Last week I took it to Keeler BMW in Latham, NY and told them I wanted their time to pull the code and give me a diagnostic. I was very clear to the service adviser that I knew what was going on Radiator and the EAC Sensor. When the tech checked it and the SA came to get me he told me the radiator would be replaced per warranty for the SULEV engine. That the VCG would be replaced, along with the valvetronic sensor. The tech recommended changing the coolant hoses, which we did do. Along with the VC, it was cracked. Cheap plastic part. Thought all was good. Until she told me yesterday that the car was stumbling. I drove it and it misfired on #6, but did not turn on the check light. I checked the OBD just for the heck of it. Waiting to call the dealer tomorrow and see what happens. |
| 06-25-2018, 01:00 PM | #75 | |
Rep 665
According to the Carly OBD reader, her car has the following codes: 2A94 (Crankshaft sensor signal) 29E0 (mixture control) 29E1 (mixture control 2) 581E (engine control unit error: engine speed) 5E1A (ECU/DSC speed signal invalid/coil outlet valve [dump] shorted rear left) I dropped it off at my local BMW dealer this past Friday morning, and the initial call from the Service Advisor said it appears the CCV/PCV is bad, and replacement is going to be covered under the SULEV warranty. More to follow today after they finish completing the diagnosis. By the way: my daughter's car was originally sold & registered in CA; we bought and drove it home to TX. Despite the fact the car is no longer in CA, it is covered under the SULEV warranty. According to the SULEV warranty, it covers the "original and subsequent owners". Since the warranty has no specific reference to the location of subsequent owners and registration, the car is covered in the remaining '49 States'. Hopefully my experience helps others who question the warranty coverage outside CA. |
| 07-04-2018, 12:43 PM | #76 |
Rep 11
Insane situation and pictures as I have never seen the new power plant cutup like that. Good to know warranty took care of everything Good job BMW AND dealership.
| 07-12-2018, 03:12 PM | #77 |
Rep 97
Fuel pump
2011 bmw 328xi Sulev
116,000 mileage Got ignition coils at 111,000 Spark plugs at 111,000 Got an issue with fuel pump i drove over at 40-50mph car starts to stumble or lose power then I'd wait 10 min to cool down and start engine. Pray that i don't stall again. Uphill - car stalls and gives fuel pump warning Even if car is parked/idle for a certain amount of time, fuel pump sign comes on and car turns off. (Maybe certain temp, i don't know) Park ave in NJ (Dealer) wants to do diag. If covered under warranty they'll waive the diag cost. After reading people's stories I'm now confident that it will be covered. Anyone have a similar situation? |
| 11-26-2018, 09:41 PM | #78 |
Rep 2
We'll see!
Bought my son a 2007 328i E90 N51 SULEV.
Current Mileage = 151,895 miles ![]() Fuel pump or something in the fuel delivery system took a shit. Took it to my local BMW Guru who quoted $2200 for new fuel pump & fuel tank. Had it towed back home. Here it sits as I contemplate what to do. ![]() My 1st attempt will be to warranty repair as it's 1,895 miles over (need luck). Questions in the event I have to fix it. 1. Why was the shop requiring a new tank & fuel pump if only the pump is bad? 2. Is there a way to diagnose what is actually bad (control module, relay, filter) Thanks for any info and I'll update as events occur... ![]() |
| 11-27-2018, 08:25 AM | #79 |
Rep 1,430
Drives: M-Sport 128i, 328xi, 3.0CS
I looked on www.getbmwparts.com and the fuel tank $801.04 and fuel pump $273.32 are available separately. I believe that the fuel tank is plastic, so I don't know why it would need to be replaced. $1,000 for labor to replace both sounds a little high.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
dboybord0.00 |
| 11-27-2018, 09:02 AM | #80 | |
Hoonigan
6956
Rep 3,017
Drives: '09 328i, '98 Wrangler
My 2009 328i with the N51 and 35,000 miles cracked the valve cover. I brought it to New Country in Hartford where they replaced the gasket, the cover, and performed the outstanding recalls on the car. They also cleaned the engine bay, replaced my coolant reservoir cap, and did a full inspection of the car. All I paid was the cost for the second key I purchased/had programmed while I was there.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
| 11-28-2018, 12:39 PM | #81 |
No one sleep in Tokyo
1025
Rep 1,542
130,000 2011 SULEV here, car only ever resided in CA. I believe they replaced my radiator back when I first bought the car under SULEV warranty. Although I had used my extended warranty to replace OFHG and VCG later on, I wonder if I can get reimbursed for the VCG?
Additionally, do you guys think that a muffler delete would make my vehicle ineligible for the warranty? I still have 20,000 miles until it's up. I wonder if I can go in there and say that there was a "misfire" and have them replace the coils/plugs preemptively. Defintely would like to juice as much as I could out of this warranty. Fricken' cylinder head bolts shearing should be covered by this too! |
| 12-08-2018, 12:39 AM | #82 |
Rep 2
just got my car back (2011 bmw 328i n51) from Bmw of el cajon. I brought it in for recall and diagnostic. Code is 2A7C and I have been trying to fix it. I started replacing aftermarket VC for PCV problem, aftermarket Vanos solenoid, intake cam sensor. IWhen I brought it in, I mention to Laralyn(SA) about the Sulev Warranty and she told me that she will help me out. The problem was Vanos units. intake vanos 3 bolts damage and fell into oil pan. exhaust vanos bolts loose. They replaced Vanos units under Sulev warranty and was asked to put new VC(OEM) or cleaned the silicone that I put on the aftermarket VC. For the price that was quoted on cleaning, I decided to install a new VC. Car runs great so far.
| 12-15-2018, 12:16 AM | #83 |
![]() 25
Rep 35
My daughters 2008 328i is at 148,000 miles. I took it to the dealer to see what they could find before the SULEV warranty expires.
1. Radiator replaced , tank to core crimp damp. 2. Valve cover pulled to reseal it... then upon inspection, replaced 3. Cam position sensor damp with oil, replaced 4. Crankshaft position sensor damp with oil, replaced 5. SAS Valve 6. I had the upper and lower radiator hoses and coolant tank return hose replaced, was charged for parts only, no labor. Thank you BMW of America !! |
| 12-16-2018, 12:37 AM | #84 |
![]() 38
Rep 51
First post. Bought the 2011 328i car a few weeks back. First BMW for me and I love the I6 whine at 6500 rpm!. Pre-sale Carfax showed recalls need to be done so I dutifully took it to BMW of Valencia, CA, to get it done after I bought it. They did the VCG under warranty (at 64k miles). Funnily enough, it had previously been done by past owner at 50k-ish miles, along with OFHG. BMW Valencia told me I had a leaking OFHG and also leaking upper radiator coolant arms, and they wanted me to spend approx.1100 bucks repairing them. BUT, I can’t find any leaks. Oil pressure and oil levels are good and stable. Coolant level is good and stable over the past 500 miles. I cant smell oil or coolant under the hood. So weird. Anyway, new free VCG under SULEV warranty.
So: A. VCG B. 0 C. SULEV covered. D. Not really but dealer suggested other maintenance i can’t see that I need done. E. No. |
| 12-18-2018, 08:51 AM | #85 |
Rep 1
Considering purchase
I'm considering the purchase of a 2011 328ix SULEV. It spent it's entire life in NY. I am in OH.
I read upthread that someone in TX purchased an SULEV vehicle that was originally sold in CA and that the SULEV warranty applied. This is significant if this would apply. Any input? |
| 12-18-2018, 11:56 PM | #87 |
Rep 3,855
Got my VCG replaced at 85,000 miles in my 2009 car. They simply noticed it was leaking and an SULEV vehicle and offered to do it for free
![]() Car not registered in an SULEV state |
| 01-02-2019, 07:12 PM | #88 | |
Rep 17
B) FREE from Habberstad BMW dealership in Bayshore, NY C) SULEV covered initially...made an appointment over the phone, spoke with the service manager and told him about my fuel pump issue and this warranty I found online D) dealer made me a priority, personally talked with service manager upon appointment, told him about this 15 year/ 150,000 mile warranty for fuel tank/fuel pump....at first he couldn't find what I was talking about and was very nice about it, even showed me his computer screen to show me he wasn't lying. He only found a warranty for 70,000 and 8 years for the fuel pump but then continued looking since I kept saying how I saw it all over the internet. He then made a phone call and BOOM, he had to change some setting on his computer search and found the updated 15 year/ 150,000 warranty and told me he would run the diagnostic test and if it is fuel pump he would take care of it for me E) BMW then gave me a rental car from enterprise on their expense since they were out of loaners, dropped the car off on 12/31/18 in the early afternoon, and got my car back 2 days later... 1/2/19 6pm. They washed my car and gave me no hard time at ALL. Was even able to drop the rental from enterprise off at BMW! Didn't have to deal with the bums at enterprise lol Thanks to this forum I saved ALOT of moooola!! ![]() |
| Bookmarks |
