TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Hesitation @ low RPM
Reply
      12-10-2016, 11:47 PM   #45
Snoball M3
Snoball M3's Avatar
Drives: 2008 328i MB Sedan/11.5 ZCP M3
BM  [0.00]
Originally Posted by tdavis42 View Post
Could be the fuel regulator or fuel pump.
Thats what I'm thinking but I think if it was that it would've stalled during normal driving, but then I found out that my 328 has the N51 and I read they come with a 15 year or 150,000 mile warranty on emission related problems so Monday I'll find out if I'm qualified cause I hear some dealerships don't accept that, bit if they do I'll let you guys know what it could be and maybe fix our problem lol.
      12-12-2016, 05:44 PM   #46
tdavis42
tdavis42's Avatar
184
Drives: 08 E90 328i ZSP AT
2008 328i  [0.00]
I had my regulator crack and start sloshing gas out of the top and it still drove. It just had a strong smell of gas.
      12-15-2016, 01:41 AM   #47
Snoball M3
Snoball M3's Avatar
BM  [0.00]
Just got the car back, told me my DME needed an update and possibly replace the MAF sensor, that the DME codes dont set off lights to go off, but they quoted me 430 to update so if anyone else having issues might want to check that out...
      01-29-2017, 08:45 PM   #48
DaanBMW
DaanBMW's Avatar
Romania
92
Drives: 2007 328i coupe
So did you go ahead with it or not ? If you did, did it solve it ?
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD
. M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings
. BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts
. Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete
      01-31-2017, 04:17 AM   #49
Snoball M3
Snoball M3's Avatar
BM  [0.00]
Not yet but I knew that wasn't the only problem so I took it to another indy and it also ended up being a damaged crankcase vent valve diaphragm causing an improper air to fuel ratio so I'd have to get my valve cover replaced that I and haven't been able too yet also my oil filter cap wasn't tight enough which was part of the idle too. Does anyone know if valve cover replacement is covered by the SULEV warranty?
      02-10-2017, 09:56 AM   #50
ZeroSum
ZeroSum's Avatar
37
Drives: E90 328i/MR2
Had a similar issue until I changed my Vanos.
2008 Monaco Blue 328i Sedan / Charcoal Delete / K&N Drop In Filter / RM Intake Boot / AA Tune
1993 MR2
      02-10-2017, 11:30 AM   #51
DaanBMW
DaanBMW's Avatar
Romania
92
changed vanos solenoids, camshaft sensors, vvt motor, maf, vanos check valves. result: no improvement.
      02-10-2017, 08:14 PM   #52
dstrickland
Drives: BMW 06 325I
What kind of hesitation is it? Like a rumble almost like a misfire when you take off?
      02-10-2017, 11:13 PM   #53
DaanBMW
DaanBMW's Avatar
Romania
92
imagine you step on the gas pedal to take off. you can imagine that what happens is the rpms go continually up until you feel the engine is revving so high that you should shift to 2nd. so basically the graph would be a continuously rising curve rpm = f(time).
mine would basically be a v. v. brief rpm rise, then a dip - a bog down, feels like a hesitation as it I suddenly took my foot off the gas but I didn't - after which the rpms finally continue the rise expected by the order via the gas pedal. so curve would be a Z shape: up - down - up again.
rumble ? not sure i'd call it that, it is a severe and short dip in rpms that if it would last would kill the engine (it never does).
misfire ? likely not, as a misfire would likely getting more pronounced at high loads/speeds, which never happen.
idling is steady, no dips, no chasing.
      02-11-2017, 07:53 AM   #54
rjahl
rjahl's Avatar
1024
Drives: Z4 35is
2012 Z4 35is  [0.00]
If it's a stumble from a stop or low speed right after gunning it I would guess it's the DTC or DSC kicking in.
Mine did the same thing until I changed tires. Dstickland also had the same experience. I thought it was strange to not get lights on the dash.
Even with sticker tires you have to manage your traction / foot or the car will do it for you.
      02-11-2017, 02:53 PM   #55
DaanBMW
DaanBMW's Avatar
Romania
92
i actually turn off the 1st stage DSC usually (it screws up the LSD), so no it can't be that. and I'm taking off pretty slow / feathering it when it happens (or I guess it is felt more). it also does it w/ 2 sets of tires+wheels, 18" summers + 17" all weathers
      02-16-2017, 11:00 AM   #56
frenchi
frenchi's Avatar
France
93
Drives: F30 340i M Performance
Replace your both precat oxygen sensors even if you don't have a Cel you will be surprised
      02-16-2017, 12:02 PM   #57
DaanBMW
DaanBMW's Avatar
Romania
92
Can you elaborate on your experience with doing this (symptoms you had fixed) ? As you can imagine after changing lots of parts that were supposed to fix it based all sorts of online threads, I'm a bit leery to try anything without some solid basis.
      02-26-2017, 10:44 AM   #58
whinojosa
Drives: 2011 535i (6sp)
2011 BMW 535i  [0.00]
Daan,
I'm having a similar experience in my 325i.
I finally received a code as the car went into limp mode. The code indicated a bad CRANKSHAFT POSITION SENSOR. I have the new part in hand and am going to swap out sometime this week.
I'll post back with acceleration hiccup results.
      02-26-2017, 11:28 AM   #59
Taskmaster
Japan
2510
Drives: M235i 6MT / E92 328 Msport 6MT
Oddly enough, mine is doing this too, and only below 4000rpm.
Changed valvecover, vanos solenoids, sparkplugs, valvetronic sensor, and I have a AIT (but might use my MAF again, and changed the manifold pressure sensor.
I'm a a loss.
      02-26-2017, 06:51 PM   #60
Taskmaster
Japan
2510
Let me know what you find.
What else could it be - throttle positioning sensor? Fuel pump? Vacuum leak? O2 sensors?
      02-26-2017, 07:30 PM   #61
Taskmaster
Japan
2510
Fuck, it may be the clutch slipping already. I JUST had it replaced.
      02-26-2017, 07:32 PM   #62
rjahl
rjahl's Avatar
1024
Drives: Z4 35is
2012 Z4 35is  [0.00]
DTC and DSC?
      02-26-2017, 07:49 PM   #63
Taskmaster
Japan
2510
DTC and DSC?
I had the DTC off. I'm at a loss here, I don't know what else I can do.
I'm reading threads and they say its the CDV and I should toss it out....
      02-26-2017, 07:57 PM   #64
rjahl
rjahl's Avatar
1024
Drives: Z4 35is
2012 Z4 35is  [0.00]
DTC and DSC?
Try pulling through a higher gear at slow speed. If it develops good torque and pulls evenly, I would think the problem lies with the DSC.
You can't turn off the DSC completely. The nanny police don't believe you can handle it.
      02-26-2017, 08:32 PM   #65
Taskmaster
Japan
2510
[QUOTE=rjahl;21336031]Try pulling through a higher gear at slow speed. If it develops good torque and pulls evenly, I would think the problem lies with the DSC.
You can't turn off the DSC completely. The nanny police don't believe you can handle it.[/QUOTE}
Basically, it's acting like the clutch is slipping. The Engine speed keeps going while the cars speed accelerates at normal pace. It's odd.
      02-26-2017, 08:48 PM   #66
justpete
Drives: '11 328i '19 M6
2019 BMW M6  [10.00]
2011 BMW 328i  [9.00]
[QUOTE=TheAxiom;21336145]
Sounds like they didn't bleed the clutch cylinder.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
Reply
