Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Velocity Stacks: Before You Buy
Reply
      11-13-2024, 11:49 AM   #45
AmuroRay
No Zaku
AmuroRay's Avatar
3671
Drives: M235i
Originally Posted by chilledn52 View Post
Mustang Dyno we put down: 238HP 205TQ. Doing conversion to dynojet as everyone for N52 seems to measure Dyno we made 257.49RWHP 219.46RWHP.
Main things I can improve on,
beginning there is a bump in torque that’s my clutch slipping, should be able to get some more torque for longer in the rev range when clutch is replaced.
FBO with MILVs, besides stock resonator stock muffler so that has to be hurting some top end too. Still in very happy with these numbers.
Winter Rims & Tires installed - heavier then summers
Also it’s RWD Xdelete so spinning of a transfer case as well. +10c maybe outside
This is awesome! Good job man - so all is well? Are you running with filters or a plenum?
Mods: Yes.
Originally Posted by umizoomi View Post
As long 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
      11-13-2024, 12:04 PM   #46
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Drives: 2007 BMW 328xi 6MT
2007 BMW 328xi  [10.00]
Thank you
All is well, no codes, drives great, cruise control all the time. Still on the beta intake manifold with the k&n pre filters, excited to have a more final manifold!
E90 328xi 6MT Velocity Stacks @ 257rwhp / Intake Scoops | K&N + Charcoal Filter Delete | DIY Dinan 3in | 3.25in + 3.5in piping | N54 Manifold | MILVS | Ceramic Coated Headers | Secondary Cat Delete | Xdelete | 3.91 Diffs | 22RPD Tune
      04-18-2025, 11:02 PM   #47
bent_rod
Drives: BMW E90
We have replaced the exhaust camshaft ledge due to scoring from being on track with less then FULL oil on digital dipstick. We had reduced timing, some exhaust scoring.
At the same time we installed MILVs from CobraMarty for increased lift
And cleaned up the valve cover to redo my crinkle black valve cover.
We are back on the roads with healthy engine, for more beta testing more.
nice wiring on the ignition side. stock is such an eye sore
      04-24-2025, 05:24 PM   #48
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Thank you!
Some Pico 8426-0-44
      06-25-2025, 11:24 AM   #49
The Nightman
Cometh
The Nightman's Avatar
1726
Drives: Boy's Soul
E90 LCI 330i  [10.00]
The N52 trumpets are available for pre-order now:
https://22rpd.com/blog/n52-trumpets-...rders-open-now
https://22rpd.com/shop/product/181
Introductory Pricing
$799 - Trumpets Only
$999 - Trumpets + Lid (For Filtered Applications)
Pre-order now at: https://22rpd.com/shop/product/181
We're officially opening pre-orders for the long-awaited 22RPD N52 Trumpets - a fully injection-molded intake runner system developed and tested in-house to unlock maximum performance gains for the N52 platform. This is the most complete and refined intake solution ever offered for this engine - designed to support both OEM+ builds and wild custom setups.
Pre-Order Options
Trumpets Only - $799
- Complete injection-molded trumpet stack system
- Designed to work with OEM-style lids or custom top-end designs
- DXFs provided for those fabricating or printing custom lids - think dual plenum designs, supercharger wedge intakes, turbo intakes, and more
Trumpets + Lid - $999
- Full trumpet stack system
- Injection-molded lid matched to trumpet geometry
- Lid includes:
- OEM MAP sensor mount
- EVAP port
- PCV connection
- Throttle body location closely matches OEM N54 for seamless integration
Engineering Notes
All testing and development was done using an open trumpet setup to streamline iteration. The performance gains come entirely from the trumpet and runner design - the lid and throttle body are not flow restrictions in our testing.
These trumpets have been beta tested on nearly three dozen cars worldwide - across every climate, from E85 to pump gas, daily drivers to track cars. We've proven the hardware works.
  • Software behavior may vary without the lid and matching throttle location
  • Some stock ECUs software's - particularly in AWD or automatic transmission cars may trigger limp mode or throttle inconsistencies without the lid.
  • Party mode software is still in beta - install at your own risk
  • We are actively working to improve compatibility across more software's, but there are thousands of permutations
  • For the most consistent, plug-and-play experience, we recommend the full system with lid
Boosted Applications Note
Preliminary FEA analysis shows these trumpets are structurally capable of handling boost, but real-world behavior will depend on heat, mounting support, and vehicle packaging.
Our goal is to test and validate boosted use cases and publish reliable pressure limits for common applications. Until then, use caution and let us know what works in your setup.
Fitment & Compatibility
  • Fits all N52B30 engines, including N52K and N52N
  • Also fits N51 and N53 engines (N53 must use the included lid)
  • OEM B30 intake port flange - not compatible with B25 intake ports
  • Fits most E9X, E8X, E6X, E89 Z4, and E70 X5 platforms
  • Compatible with OEM throttle body or N54 throttle body
  • Redesigned to use OEM lower gaskets and hardware
  • Built with OEM-style metal inserts for safe torque-to-spec - no risk of cracking under proper install
Technical Highlights
  • Smooth internal finish for optimized airflow
  • Textured outer surface for heat resistance and structural rigidity
  • Engineered for superior flow consistency and structural integrity compared to printed units
  • Maintains OEM hood clearance on all tested platforms
  • Stack height and throttle flange follow factory geometry
Installation
  • Full installation guide included with every kit
  • Requires standard hand tools
  • OEM-style install: no permanent modifications
  • Minor rerouting of PCV/EVAP lines may be needed when using the lid
  • Throttle adaptation/reset recommended after install
Tuning Support
  • Free retune for customers from 1/1/25–6/23/25 upgrading to matching tune style
  • $160 retune for tunes 6–12 months old upgrading to matching style
  • Tunes over 12 months require new purchase
  • Email us if unsure about your status
Beta Trade-In Program
  • Return your beta trumpet system
  • Get discounted upgrade to final version
  • Email for a custom invoice
4 Doors1386.00
      06-25-2025, 04:21 PM   #50
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Thanks for the update!
OH BOY IM EXCITED
      06-25-2025, 05:45 PM   #51
colorado.e9x
eBay Special
colorado.e9x's Avatar
4114
Drives: E90 330xi, E90 328xi
2006 BMW 330xi  [10.00]
2007 BMW 328xi  [8.33]
Need to know if the intake manifold version has less gains asap
Andd if it comes with the tune or not
Common sense is a flower that does not bloom in everyone's garden
      06-25-2025, 05:57 PM   #52
4 Doors
Wagon Addict
4 Doors's Avatar
1386
Drives: Current: 2011 BMW 328i (E91) Touring
2008 BMW 335xi  [10.00]
I ordered the full kit: trumpets + lid! I will update when it arrives.
      06-25-2025, 06:03 PM   #53
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
LETS GOOO!!
Waiting on email so i can send in the old ones and get myself Velocity Stacks + Lid!
      06-25-2025, 06:25 PM   #54
The Nightman
Cometh
1726
Drives: Boy's Soul
The product page has more info about tunes: https://22rpd.com/shop/product/181
Tuning Support
      06-25-2025, 06:36 PM   #55
colorado.e9x
eBay Special
4114
I read that, pretty vague in regards to if it comes with it or not. I'm assuming it's separate, and if thats the case it's a bit of a letdown
      07-11-2025, 11:15 AM   #56
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
We have sent back the beta manifold in preparation for the final manifold with lid.
Now with a new engine installed (due to crank bolt being undone at a shop), we are back off MILVs for now
I know if you run the Manifold plus Lid, you can just run your stage 2 tune and adaptations will adjust as you have a sealed factory style system
and mainly need a custom tune if you want to run throttle-less, or if you want to optimize the more air coming into the system
      07-11-2025, 03:41 PM   #57
AmuroRay
No Zaku
AmuroRay's Avatar
3671
Drives: M235i
257 was with the MILVs + FBO and the trumpets?
Mods: Yes.
      07-11-2025, 03:45 PM   #58
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
257rwhp dynojet, Xdrive (RWD),
Catless headers, secondary cat delete, stock resonator, stock muffler. Yes with MILVs
      07-11-2025, 03:53 PM   #59
AmuroRay
No Zaku
AmuroRay's Avatar
3671
Drives: M235i
So, headers, midpipe, MIlvs and tune - And what manifold?
Mods: Yes.
      07-11-2025, 03:55 PM   #60
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Open plenum beta velocity stacks
AmuroRay3670.50
      07-11-2025, 04:02 PM   #61
AmuroRay
No Zaku
AmuroRay's Avatar
3671
Drives: M235i
Ahh, understood. Thank you.
Mods: Yes.
      07-11-2025, 04:06 PM   #62
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
No problem, 🫡
      09-13-2025, 02:09 PM   #63
firzen1540
Drives: E92 328 & E92 335is
How do you relocate the junction box?
      09-13-2025, 02:12 PM   #64
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
I 3D printed a bracket that holds it to my chassis, has holes to allow zip ties to mount it.
https://printablesauto.ca/products/n...-bracket-whb52
      10-20-2025, 04:42 PM   #65
acefighter028
Dumpster fire
38
Drives: 06 330I, 06 330XI, 24 Frontier
Im excited to do this over the winter. Waiting on info for the ITG filter. We have a dyno at our shop so i can get numbers before and after.
      10-20-2025, 11:05 PM   #66
bimmermech123
Drives: 2008 BMW 328i
I placed my pre-order for the velocity stacks with the lid back in June. I know in the latest blog post by 22RPD, they mentioned that they had one production unit manufactured. Anybody have any update since?
Reply
