BMW 3-Series (E90 E92) Forum
N52 Owners: Elec Water Pump Check-In Part Deux
| View Poll Results: How many miles have you logged, and have you replaced your water pump yet? | |||
| Not yet, I have 60-75,000 miles |
120 | 18.49% |
| Not yet, I have 75-90,000 miles |
98 | 15.10% |
| Not yet, I have 90-105,000 miles |
84 | 12.94% |
| Not yet, I have 105-120,000 miles |
63 | 9.71% |
| Not yet, I'm invincible and have 120,000+ miles |
73 | 11.25% |
| Yes, between 60-75,000 miles |
36 | 5.55% |
| Yes, between 75-90,000 miles |
49 | 7.55% |
| Yes, between 90-105,000 miles |
46 | 7.09% |
| Yes, between 105-120,000 miles |
36 | 5.55% |
| Yes, between 120,000 and xxx,xxx miles |
44 | 6.78% |
| Voters: 649. You may not vote on this poll | |||
Thread Tools |
| 05-14-2015, 09:27 AM | #23 |
Rep 54
2006 325i 6MT
Failed around 91k Cost was around $2000 at the dealer installed for pump, thermostat, other required parts, and labor out the door. Dealer No other damage Never tracked, 80-90% of the mileage was highway (during my ownership at least - purchased with 70.5k) |
| 06-02-2015, 02:21 PM | #24 |
markg
Rep 5
Drives: 2006 330i
failed at 120k
replaced pump and thermostat with updated OEM and BMW coolant indy shop at around $1,200 for everything auto trans no other damage never tracked |
| 06-25-2015, 02:46 PM | #27 |
![]() 21
Rep 85
2006 330i 6sp MTX
Failed just over 120,000 Part about $500 - will do myself Car has been tracked and autocrossed by previous owner Hopefully no damage - went from yellow to red almost instantly, pulled over immediately and turned it off.. |
| 07-06-2015, 10:03 PM | #28 |
![]() 6
Rep 100
a. 2008 / 328i / AT
b. preventive - throwing WP codes (~82k mi) c. $750 parts and labor, lowered from a lot more due to additional work being done d. indy e. N/A f. nope |
| 08-10-2015, 09:18 AM | #29 |
Diamond Geezer
227
Rep 2,384
Drives: Jet Black 2007 328i Saloon
a. 2007 / 328i / AT
b. Preventive, 145k miles. Thermo sticking and coinciding mixure codes, decided to do thermo, pump and hoses. c. $875 parts and labor, including hoses d. Indy e. no other damage f. light autocross, no track |
| 08-12-2015, 09:54 AM | #30 |
Rep 551
Just failed on me Saturday, had it towed to an Indy.
a. 2006 330xi auto b. Failed on the interstate, pulled off immediately-red thermometer and limp mode. c. 1350- 800parts rest labor...yes I know DIY is over half that d. Replaced at very well regarded Indy(charges more than dealer) that is 1 block from my apartment. My complex doesn't allow work on cars and I don't have open time for DIYS like this this summer so premium paid. e. No additional damage, had thermo replaced as well. Towed it home as soon as in the red. f. Never tracked once.
2006 Sonora Metallic 330xi.
DIY: Charcoal Delete, K |
| 08-19-2015, 05:28 PM | #31 |
![]() ![]() 37
Rep 331
Had a thermostat error a few weeks back.
A. 2008 328i auto B. Thermostat failed C. 450 parts skinned knuckes and swear jar tax D. Did it myself E. No additional damage F. does US129 count?
2008 Monaco Blue 328i Sedan / Charcoal Delete / K&N Drop In Filter / RM Intake Boot / AA Tune
1993 MR2 |
| 08-25-2015, 05:03 PM | #32 | |
Rep 385
My thought was this, which mode do you drive your car in mostly, this could be letter "g" on the list. For example I read that the thermostat setting for when you're in sport mode is lower, to help produce power, thus putting more strain on the thermostat (opening and closing more) and the possibly the water pump itself. I'm curious if there is any correlation or not is all. |
| 08-25-2015, 08:32 PM | #33 |
Rep 2
2006 330i Sedan
109,000 miles water pump failed light came on and went to instant limp mode. Bought parts online for less than $400 (water pump and thermostat) A buddy put it in for me in about 4 hrs all is good now. |
| 08-26-2015, 09:26 AM | #35 | |
Rep 7,212
| 08-26-2015, 10:00 AM | #36 |
Rep 385
| 08-26-2015, 10:04 AM | #37 |
![]() ![]() ![]() ![]() 246
Rep 956
Voted for "Yes, between 75-90,000 miles"
To be exact, the pump failed at 82k miles. Coolant was original 50.50 mix. Never had leaks. Never had to top off coolant. Original and only owner. a. May 2006 Build/330xi/Auto, 6HP19 b. Shadow faults stored in DME for deviation in pump speed. Radiator fan screaming week before warning lights/limp mode. Pump was not complete failure but on it way out . c. ~$350. I work for a shop so I get wholesale pricing and also installed myself. d. Indy, myself e. No. f. Yes. |
| 08-27-2015, 12:15 PM | #38 |
![]() 1024
Rep 2,306
Replaced mine at 85,000 Miles
Electrical Fault, No leakage I know have 145,000 miles on the car, starting to think about how long the second pump will last. |
| 09-23-2015, 05:49 PM | #40 | |
![]() 6
Rep 32
![]() Edit: 2006 325i First owner replaced it at 85k miles. Pretty sure it at least made it to the dealer, no tow. Dealer replaced, around 850 for parts and labor IIRC Manual transmission No tracking, mostly highway miles with spirited driving Last edited by d_slice1; 09-23-2015 at 06:47 PM.. |
| 10-12-2015, 11:50 AM | #41 |
![]() 20
Rep 77
Mine just crapped out at almost exactly 76k miles, which was fantastic as my extended warranty expires in December, and the mechanic (indy) found the belt tensioner was going out as well.
07 328i coupe ZF auto 100% Failed replaced by Indy under 3rd party warranty Yes, the thermostat overheated and was replaced No track time |
| 10-25-2015, 11:14 AM | #42 |
Rep 16
a. 2007/ 328i / 6MT
b. Preventive maintenance. Local Indy found codes when I brought it in for something else. c. Just under $500. New pump, tstat housing, bolts, hose, 2gal antifreeze, special sockets, silicone lube. d. Did it myself in 3hrs e. No other damage f. No track, although surviving on the DFW roads should count as track time. Just a daily driver. |
| 11-09-2015, 07:08 PM | #44 |
Rep 28
At 106K, ordering replacement pump as I'm doing a coolant flush and oil filter housing at the same time. Might as well do it all at once.
10/2005 330i. Yep, the one with the aluminum bolts.
| Bookmarks |
