BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Velocity Stacks: Before You Buy
Reply
      07-18-2024, 08:25 PM   #23
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Drives: 2007 BMW 328xi 6MT
2007 BMW 328xi  [10.00]
Originally Posted by Dru128m View Post
Where does the MAP sensor go? I couldn't get any vacuum to read porting into a runner, maybe if I would have used all six it would have been enough.
Also n52 has vacuum pump cause from factory it never made enough vacuum in the manifold
E90 328xi 6MT Velocity Stacks @ 257rwhp / Intake Scoops | K&N + Charcoal Filter Delete | DIY Dinan 3in | 3.25in + 3.5in piping | N54 Manifold | MILVS | Ceramic Coated Headers | Secondary Cat Delete | Xdelete | 3.91 Diffs | 22RPD Tune
      07-29-2024, 02:23 PM   #24
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
My own 3D printed velocity pipe bumper intake for the velocity stacks, sold a few already
      08-01-2024, 05:11 AM   #25
jonwilli
Drives: E81 130i
Is there any news on the final production velocity stacks? I thought they were meant to be available for sale a couple of months ago?
      08-01-2024, 02:47 PM   #26
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Best I can say is that the tuning is taking longer then expected. Don’t think anyone is at a final tune yet as the problems are timing, smooth throttle response, better fuel economy
      08-01-2024, 05:28 PM   #27
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Never shared the dyno run I’ve done -
EDIT: 2A87 Exhaust Camshaft Sprocket constantly being fluctuation
      08-01-2024, 05:34 PM   #28
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Beta tune not fully complete
Hitting a torque limiter
Low timing 7 degrees off
Not most power of out tune
83F or 30C outside air temp
2200ft -6% off
Without MILVs
234rwhp / 194ftlb - mustang dyno
254rwhp / 207ftlb - dyno jet conversion
      08-03-2024, 02:52 PM   #29
jonwilli
Drives: E81 130i
I'm guessing tuning for velocity stacks and cams could be a nightmare then when they are released? Any idea if this is on 22RPDs future plans?
      08-04-2024, 12:21 PM   #30
The Nightman
Cometh
The Nightman's Avatar
1726
Drives: Boy's Soul
E90 LCI 330i  [10.00]
2200ft -6% off
Thanks for the update. Impressive so far and sounds glorious
      08-04-2024, 10:07 PM   #31
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
I’m not sure, if 22RPD gets solid velocity stacks tune, and these cams still use valvetronic then I assume it can be done
      08-30-2024, 04:59 PM   #32
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
We have replaced the exhaust camshaft ledge due to scoring from being on track with less then FULL oil on digital dipstick. We had reduced timing, some exhaust scoring.
At the same time we installed MILVs from CobraMarty for increased lift
And cleaned up the valve cover to redo my crinkle black valve cover.
We are back on the roads with healthy engine, for more beta testing more.
3PedalJake3511.50
      09-02-2024, 07:36 PM   #33
colorado.e9x
eBay Special
colorado.e9x's Avatar
4114
Drives: E90 330xi, E90 328xi
2006 BMW 330xi  [10.00]
2007 BMW 328xi  [8.33]
Good to hear. Any butt meter difference with MILVs?
Common sense is a flower that does not bloom in everyone's garden
      09-03-2024, 01:03 PM   #34
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
butt meter has seen in increase of power and torque at almost every point in rev range
      09-04-2024, 11:57 AM   #35
jonwilli
Drives: E81 130i
What are you thoughts on this video?
I think you were in contact with Bruno when he was testing? I have MILVs fitted at the moment but hope to move to upgraded cams from StageFP or BDS once they have been released/tested a bit more.
      09-04-2024, 12:27 PM   #36
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
https://www.youtube.com/watch?v=u4zKBsJRvYA
Contact with Bruno? No
To my understanding, technically it’s just changing the position of the eccentric shaft so at a given rpm point, you have more valve lift.
      09-09-2024, 11:14 AM   #37
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
MILVs on N54 manifold is WAY more noticeable then it was for me on velocity stacks.
On N54 manifold at this point cause not more much tuning needed, pretty much done on mine.
I still have 2A87 exhaust mechanism so I do have to tear back into the car.
If you plan on getting these velocity stacks, good healthy engine is required for sure.
      09-09-2024, 03:01 PM   #38
colorado.e9x
eBay Special
4114
Thanks for the info! Whats your thoughts on it so far compared to the N54 manifold?
      09-09-2024, 07:44 PM   #39
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Thanks for the info! What's your thoughts on it so far compared to the N54 manifold?
gonna have to get readjusted to the n54 manifold with milvs now. trumpets are drone-y and higher fuel economy, doing lots of highway.
      09-11-2024, 01:09 PM   #40
AmuroRay
No Zaku
AmuroRay's Avatar
3671
Drives: M235i
Economy or consumption? Did you run a filter? And plan for them to put a pendulum on the trumpets?
Mods: Yes.
Originally Posted by umizoomi View Post
As long 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
      09-11-2024, 01:15 PM   #41
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
consumption. some beta users have same fuel economy while mine has increased at least by +4-5L/100km at highway speeds.
3.91 diffs and over 3k isnt helping.
running a K&N prefilter over the trumpets
AmuroRay3670.50
      11-03-2024, 06:12 PM   #42
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
So timing was off most likely due to the camshaft sprockets, it was pre recall but still went bad on me. With 94 + octane booster we hitting our target timing goals.
Fuel economy has been a lot better (cruise above 3k 17~mpg or 14~L/100km), maybe because of timing and fuel quality it was dumping more to compensate.
I’ve been daily driving them now for over a week, been dead reliable for me, very happy now for what it makes.
With MILVs now, and my previous dyno being calculated to dyno jet and fix for timing.
Without MILVs was 261rwhp correct timing on Dyno jet
With MILVs, assuming the same power curve to other manifolds. I’m assuming around 270rwhp
I could dyno again now but it’s a 30 degree difference (now 0c or 32f) in temperature so I think I gotta wait for summer to make it fair.
AmuroRay3670.50
      11-07-2024, 07:47 AM   #43
AmuroRay
No Zaku
AmuroRay's Avatar
3671
Drives: M235i
You should do it now. Temps don't matter so much after a certain point.
Mods: Yes.
      11-09-2024, 12:57 AM   #44
chilledn52
PrintablesAuto.ca
chilledn52's Avatar
199
Mustang Dyno we put down: 238HP 205TQ. Doing conversion to dynojet as everyone for N52 seems to measure Dyno we made 257.49RWHP 219.46RWHP.
Main things I can improve on,
beginning there is a bump in torque that’s my clutch slipping, should be able to get some more torque for longer in the rev range when clutch is replaced.
FBO with MILVs, besides stock resonator stock muffler so that has to be hurting some top end too. Still in very happy with these numbers.
Winter Rims & Tires installed - heavier then summers
Also it’s RWD Xdelete so spinning of a transfer case as well. +10c maybe outside
EDIT: my car was still having timing / internal issues while on the dyno.
Last edited by chilledn52; 08-13-2025 at 01:33 PM.. Reason: EDIT: my car was still having timing / internal issues while on the dyno.
AmuroRay3670.50
Reply
