BMW 3-Series (E90 E92) Forum
Oil catch can installed
| 11-06-2020, 01:31 PM | #23 | |
Cometh
1726
Rep 1,588
Drives: Boy's Soul
https://www.e90post.com/forums/showp...81&postcount=3 https://www.e90post.com/forums/showp...50&postcount=3 |
| 11-06-2020, 01:50 PM | #24 |
Rep 17
It was the PCV connections I was wondering about as I've read the PCV is 'built-in' to the cam cover. If there are external pipes then that's ok.
Guess I'll have to remove the plastic cover for a look-see. |
| 11-06-2020, 04:46 PM | #25 |
Cometh
1726
Rep 1,588
Drives: Boy's Soul
It shouldn't be any different from an N52 with the plastic valve cover. The PCV valve is in the valve cover but the hosing to the intake manifold is the same.
| 11-06-2020, 04:58 PM | #26 | |
Rep 17
I had the walnur decoke about 12k miles ago so I think keeping the intake oil free would be a good thing. ![]() I see you can get intake cleaners from the likes of Euro Car Parts these days. Dunno how effective they are thought ![]() |
| 11-06-2020, 06:27 PM | #27 |
Rep 2,098
It's really not necessary for the N52 because its not direct injection. So using something like a fuel system cleaner (where you dump it in the fuel tank - ie techron, et al) is gonna be more than enough. Even when the N52 valves get "dirty" they're not even a 1/4 as bad as a typical N54 that actually needs the walnut blasting. While oil does pass into the intake manifold, its usually not significant enough to cause a problem unless you leave the car without ever starting for months.
| 11-08-2020, 11:45 AM | #28 |
Rep 17
You used to be able to get water injection kits to help cool the intake charge on turbos. I wonder if something like that, maybe with some sort of additive would help keep the inlet ports clean?
| 03-19-2021, 06:50 PM | #29 | |
Cometh
1726
Rep 1,588
Drives: Boy's Soul
| 06-08-2023, 09:53 AM | #30 |
![]() 15
Rep 64
| 06-08-2023, 12:36 PM | #31 |
![]() 15
Rep 64
Hey Nightman, post is old I was hoping you would respond I appreciate you brother. I was actually thinking of removing the whole crankcake and connecting straight to the valve cover and then connecting straight to the intake manifold connection. Then "capping" the oil return pipe so that nothing gets in the oil pan.
Or, finding a way to split the hose using some kind of copper adapter with two fittings so that there are two hoses split, one going to intake manifold and another one to the oil return pipe. https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds |
| 06-09-2023, 09:40 AM | #32 |
Rep 396
Old thread but very relevant. I just bought the same can to install on my 2011 328i N51. Doing the same routing, good pics! I can't stand the oil in the intake and the constant slight odor of oil burning after turning it off. Keeping the oil off the DISA valves will help with life...
| 06-10-2023, 04:44 PM | #33 |
Rep 396
I got this one off eBay. Shows the directions of flow in one of the pictures.
https://www.ebay.com/itm/Billet-Alum...-127632-2357-0 |
StradaRedlands9709.50 |
| 06-10-2023, 08:49 PM | #34 |
![]() 15
Rep 64
Is ok brother ty anyways. I have a 3 state intake manifold so it appears to be the same if not similar. The crankcase has an in from valve cover an oil return hose to the pan and a connection to the intake.
| 06-13-2023, 11:45 AM | #36 | ||
Cometh
1726
Rep 1,588
Drives: Boy's Soul
I doublechecked BMS' photos and instructions and they have the baffles on the outlet: Quote:
![]() Baffle on the "out" port: ![]() |
| 06-16-2023, 01:44 PM | #37 | |
![]() 18
Rep 65
Question for the OP: Why add a catch can to the N52? Is this to circumvent having to replace the valve cover? Does the OEM setup (when functioning correctly) not do the same thing, but without the need to constantly empty and drain the can? If I'm not mistaken the stock CCV system is basically a (heated) catch can with a drain pipe to the oil pan? |
| 06-17-2023, 06:34 PM | #38 | ||
Cometh
1726
Rep 1,588
Drives: Boy's Soul
| 06-19-2023, 03:53 PM | #39 |
Rep 438
Got the same catch can. Did not help with the smokey issue. Caught stuff tho
| 06-20-2023, 09:25 AM | #40 |
Rep 396
That can is working, that little bit of oil collected helps save the DISA valves on an N51...and saves the N52 ingesting oil.
| 06-25-2023, 10:01 AM | #41 |
![]() 15
Rep 64
https://www.amazon.com/EVIL-ENERGY-R...2&sr=8-10&th=1
I would recommend you guys install this in the intake hose |
| 07-05-2023, 11:08 AM | #42 |
![]() 15
Rep 64
if you guys are taking the whole intake which i recommend make sure you check your disa valves and test them with inpa. Your intake should have no oil or little oil at all. Let your intake drain the oil there is no neeed to clean it there should be no build up in there. The crankcase system is trash. the source of most idling issues.
| 07-05-2023, 11:09 AM | #43 |
![]() 15
Rep 64
Also, don’t use heater hoses use fuel grade hoses.
https://www.amazon.com/dp/B088X2N3JQ...spXa6QjoXBtYCk |
The Nightman1726.00 StradaRedlands9709.50 |
| 07-11-2023, 08:26 AM | #44 |
![]() 15
Rep 64
1/2" Fuel Check Valve,Engraved with Flow Direction,Aluminium Alloy One Way Valve for Air Fuel Oil Diesel Gas E85 or Other Liquid Transfer Check Valve Car Parts (12mm) https://a.co/d/fwJaQbt
from catch to intake |
| Bookmarks |
