BMW 3-Series (E90 E92) Forum
Rough Idle and Cylinder Misfire Code after 3 Stage Intake Installed
| 06-10-2017, 08:12 PM | #23 |
Rep 2,041
My advice is just to take your car out from that shop. They sound like know only how to change brakes and oil in Toyota corolla 2003. Your car has to run smooth even without proper tune. I did 2 3im swap on pre lci an lci 328's with no problems to tune. Till this day I'm running without tune cause I'm waiting for some good discount from BPC
N52UNED188.00 |
| 06-10-2017, 08:55 PM | #24 | |
![]() ![]() ![]() 2943
Rep 12,992
Garage List E86 Z4 M GTS [9.91]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.53] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
Only thing I can think of outside of install are the donor parts you sourced, I take it these are used? Also I think it was Hass who said it but some of these hoses are really brittle especially when you factor the donor car may likely be 10 years old. |
N52UNED188.00 |
| 06-10-2017, 09:36 PM | #25 | |
Rep 601
For clarification he did state there was a cylinder misfire code thrown ... but since it didn't specifically mention which cylinder (ex Cylinder #3) they dismissed the thrown code. So surprised they're this ignorant / arrogant about the misfire. When I mentioned to the manager, that other than a vac leak; perhaps a coil was loosened during the install ... that those are the 2 big things to check if there's an issue with the install .... I did see a glimmer of 'that's possible' in his look. After I listed the issues: rough idle, lurching a bit when goosed, stalling at stop lights ... and mentioned those are spark issues not intake issues .. he then stated the code didn't show which cylinder, that it would show a cylinder number if it was a particular coil, and finally that they do a lot of coil jobs. Then blamed the Vanos. Yes the donor parts are used. The 3IM with DISA's from Bimmer World in GA. Regarding the hose ... the mechanic elected to use my hose, although they purportedly ordered a new one. They said it was in good condition for the number of years. My car has only ~ 37,500 miles ... not sure if that came into play. I was a bit surprised they just didn't use the part they stated they ordered. Why not cover their ass and bill me for a part I already okay'd? IDK. Before the install I spoke to the mechanic and he insisted we get a new one, and that my car was 10 years old ... so it's best to install a new one since they get brittle over the years. I agreed to do it right the first time and better to be safe than sorry. He also looked over the intake and said he like the condition. . Last edited by N52UNED; 06-10-2017 at 10:07 PM.. |
| 06-12-2017, 11:25 AM | #26 | |
Rep 601
The shop found the issue .... it was the throttle body. The donor 3IM throttle body is by a different manufacturer ... One was Siemens the other Continental. The 3IM donor came with a throttle body, but not knowing there was a difference in manufacturer; I asked the mechanic to use my stock one since my car only has 37K. Although the mechanic noticed the difference, he did what he was asked. I'm a bit disappointed that the mechanic didn't bring this to my attention, as I would've stated to use the donor just in case. Plus that would've been helpful for me to fully understand any and all differences. I guess the mechanic didn't think it was a going to be an issue ... but once the car came back ... that was the first thing he though it might be. Regardless ... the car runs like it should. I only took it for a quick spin (no speed over 50 mph). Although they did figure out the issue ... I'm a bit hesitant using them again though. . |
| 06-12-2017, 11:32 AM | #27 |
Rep 12,992
Different manufacturer throttle bodies isn't a big deal. The issue is he probably didn't replace the green rubber o-ring / gasket with a new one. And between the 2 tb's your old one has a better seal.
N52UNED188.00 |
| 06-12-2017, 02:02 PM | #28 | |
Touring cars rock
354
Rep 907
| 06-12-2017, 02:16 PM | #29 | |
Rep 601
All I really know is during the quick run I did ... it started and idled fine twice. Drove like before the install. The shop manager stated the mechanic mentioned the TB manufacturer difference could be a cause ... and once they swapped them out it ran as it should. He also mentioned they didn't even look at the coils. Frankly I don't know if the manufacturer really made a difference; if they got a better seal with the "used" TB or a better seal the second time in general ... Heck, or if they're just shining me on. Honestly I'm more along the lines that is was an install error rather than parts. BUT with BMW I don't rule out seemingly trivial differences from coming into play. . Last edited by N52UNED; 06-12-2017 at 02:46 PM.. |
| 06-12-2017, 03:32 PM | #31 |
Rep 601
| Bookmarks |
