BMW 3-Series (E90 E92) Forum
Alpine | Coding & Activating Hidden/Euro Options Los Angeles
| 01-17-2018, 06:05 PM | #265 |
Rep 18
Just had the pleasure of working with Alex, he did the follow to my 08 e92 335xi
Comfort/Lighting Options: • Disable Seat Belt Chimes (Passenger, Driver, or both) • Folding Mirrors with key • Folding Mirrors with Comfort Access (Comfort Access required) • Unlock doors when engine is turned off • Key Eject (when holding Start/Stop for 3 seconds car will shut off and key will eject) • Window safety feature (When window is rolling up, you can open the door without it stopping, one touch operation of windows with door open) • Double Blinking Euro Hazards (2007+ cars and up build date must be after 03/07) • Welcome Lights Fog Lights (When you hit unlock, your fog lights come on) (2007+ cars and up build date must be after 03/07) • Welcome Lights Headlights (high & low)(2007+ cars and up build date must be after 03/07) • Removal of Amber Headlight Sidemarkers (Euro Look, will only come on when you signal) • Fog Lamps with High Beams (Fog lights will not shut off when high beams are activated) • Turn Off Daytime Running Lights • Switch DRL on E90 and E91 from inner halogen bulb to the Angel Eyes (2007+ cars and up build date must be after 03/07) full intensity all the time • Disable Key In Ignition Gong (no gong when key is in ignition and door is open) • Digital Speed Display (Speed will be displayed in numbers center of the cluster, added option does not remove anything, M3 style) • Cluster lights always on (M3 style) • Adjust low gas warning (M3s from 1/4 to 1/8th, standard 3 series is already at 1/8th) • Disable Headlight Washers iDrive/Navigation Options: • Removal of iDrive Disclaimer Message (no more pushing accept when first starting the car) E9X Software Flashes • Alpina B3 Transmission update (E9X 2007+ 335i with a build date of 03/07 or after can enjoy this amazing performance update, much faster shifts, almost instant response from paddle shifters, improved gas mileage, smoother shifts, an overall win) It was a great transaction and hes a top notch vender. Thank again Alex, one quick trip put a smile on my face with that Alpina Flash.
2008 E92xi |Sparkling Graphite Metallic w\ Saddle brown |Coded by Alex @ Alpine| Alpina B3 | aFe Power Magnum FORCE Elite intake| MHD 1+ | H&R spring| AG M359's w\ ECS stud conv|
| Bookmarks |
| Tags |
| coding activating options |
