BMW 3-Series (E90 E92) Forum
DIY: E90 Oil Pan Gasket and Subframe Drop
| 11-24-2019, 11:33 AM | #265 |
16 years and counting...
111
Rep 476
Word of advice — don’t be as dumb as me. Was trying to get the tow hook in as far as it’ll go and didn’t notice I was digging into the head(!)... think I took off a pretty small part of it but the tow hook design is a little awkward for this area.
E90 325i 6MT + E61 530xiT 6AT = N52B30*2
![]() ![]() Last edited by 850CSi; 11-24-2019 at 12:13 PM.. |
| 11-24-2019, 01:43 PM | #266 |
Rep 598
Clean it up with brake cleaner spray after an oil change. A lot of times oil left over in the car tray from oil changes will mess up the whole car.
Clean it up and drive around and then check again. It might not even be the oil pan gasket. |
| 11-24-2019, 02:47 PM | #267 | |
111
Rep 476
I’m relatively new to DIYing and not great at detecting leaks (and I think the VCG is ALSO leaking) but oil pan seems like a safe bet to me? Can’t think of anything else that would present in this way?
| 11-30-2019, 07:16 AM | #269 |
Rep 11
Drives: 2008 328i E92 6MT TiAg/black
How to determine oil pan type?
I read this whole thread and took some notes. I'm still confused about the steel and aluminum oil pans. How do I determine which one I have? The torque specs are different for each?
My oil pan is black. 2008 e92 n52k 6MT not sure if magnetic. My brother's oil pan is silver 2009 e93 n51 6MT not magnetic. Anyone know if the e93 will have any significant differences with the extra support rods under the car? Thanks! |
| 11-30-2019, 08:18 PM | #271 |
111
Rep 476
So, I broke the connector itself. And even after I broke the connector, it still wouldn’t come loose! I finally got it off ... by breaking it some more.
I assume I’m taking off the intake manifold now to replace that line? Guess I can do my 3 stage conversion now... Anyone have any ideas what he was referring to here? Last edited by 850CSi; 11-30-2019 at 09:42 PM.. |
| 12-01-2019, 12:42 AM | #272 |
111
Rep 476
This isn’t a high pressure linkage of any sort is it? Any reason why I can’t just wrap it in silicone tape as a temp fix until I get around to the manifold?
| 12-01-2019, 07:37 AM | #273 | |
![]() 1071
Rep 2,115
| 12-01-2019, 10:42 AM | #274 | |
![]() ![]() ![]() ![]() 22095
Rep 21,213
| 12-01-2019, 10:44 AM | #275 |
Rep 21,213
You have to get a good air seal on that hose or the engine will lose vacuum and run like crap. How broken is the end of the hose that slips over the oil pan pipe?
| 12-01-2019, 11:30 AM | #276 |
111
Rep 476
So... anyone have any idea where this might have come from?
Found in oil pan.
| 12-01-2019, 11:32 AM | #277 |
111
Rep 476
I probably broke off about half of the bell connector. I’m guessing it’ll still click into place but as you say no idea if that’ll be enough.
| 12-01-2019, 01:08 PM | #278 | |
111
Rep 476
Also posting a pic of the broken thread with one of the oil pan bolts for comparison. Don’t think I have much choice but to continue on.
| 12-01-2019, 02:16 PM | #279 |
Rep 21,213
When you get the pan back on, reassemble the drain hose and see how the engine runs. If it won't hold idle, then there is a leak at the drain hose. If it clicks on, then is probably is a good connection.
| 12-01-2019, 03:45 PM | #280 |
111
Rep 476
| 12-02-2019, 12:20 AM | #281 |
111
Rep 476
Aaaaaand of course it’s leaking again and I haven’t even turned it on. All that work and worse off than I started! Lesson learned.
| 12-02-2019, 05:56 AM | #282 |
![]() 1071
Rep 2,115
Unless it is an XI. All XI has aluminum oil pan regardless of transmission type.
| 12-02-2019, 08:41 PM | #283 |
Rep 21,213
Then that'd be a manual transmission'd E93xi, which doesn't exist as a factory build.
| 12-03-2019, 11:02 AM | #284 | |
![]() 10
Rep 68
| 12-03-2019, 03:04 PM | #285 | |
111
Rep 476
I guess what I was asking is why your mechanic didn’t seem to think replacing the whole pipe would be a big deal. Doesn’t it require removing the intake? Or is there another way to get there that I’m missing? (does anyone know if it might be possible just by removing the air filter housing?) ... As for my leak I left the car in my folks’ garage for the week. In some instances I was hesitant to torque the pan bolts the full 90 past 8nm. I’ll go back next weekend and try re-torquing. I did use some Permatex black on the pan-to-gasket surface — does anyone know how that might affect the amount of torque needed to get a full seal? Perhaps I should’ve waited longer before filling the engine with oil? |
| 12-04-2019, 07:15 AM | #286 | |
![]() 10
Rep 68
Depending on how much of a hurry you are, I might be able to help because I have to inspect and possibly replace one of my DISA valves. Oh, and LOL ... here is what Pelican Parts says about that effing hose "... If you are doing a repair where this hose may be moved or bumped, have a spare on hand, because it will break." https://www.pelicanparts.com/BMW/tec...eplacement.htm Last edited by Pohsib; 12-04-2019 at 09:10 AM.. |
| Bookmarks |
