The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY REQ: ECU box removal
Reply
      01-24-2010, 11:02 PM   #1
themyst
themyst's Avatar
South Korea
195
Drives: '16 MK7 GTI
I am sure I can get as far as removing the ECU itself along with the harnesses/wiring, but are there any specific instructions for removing the actual box? I have a screwdriver below the box that I dropped in there and want to get it out. Thanks!
E90 LCI N54 6AT
      01-30-2010, 10:53 AM   #2
Sparky66
Sparky66's Avatar
Australia
63
Drives: 335 E92 Coupe. Jet Black.
Hope these pictures help you. (Ignore comments on pictures, as I pulled this from another thread)
Remove all the plastic sections inside the box and look against the firewall side for the 4 Torx screws (part #7)......you'll notice these in one of the pictures below. These seem to be holding the fan unit shroud assembly. Undo these cautiously, as I believe they hold the ventilation cover (shroud) and the fan assembly located through the hole in the firewall, just behind it.
Also looks like there is a Water Outlet Valve (part #2) and a rubber stop buffer (part #3) located at the base of box that is press fit to hold the box down......just pull up on the whole box, to release it.
Goodluck!
      03-29-2010, 12:41 PM   #3
KL07RPH
KL07RPH's Avatar
237
Drives: . .
Does anyone know if that slot where the USB passes through interferes with the ECU fan? I thought that slot was for some ductwork for that fan
      04-15-2018, 02:44 AM   #4
Jeffman
Jeffman's Avatar
41
Drives: 2008 335xi E90
I also dropped a socket extension between the firewall and the E-box. It sounded like it’s sitting just beneath the E-box. Any issues just leaving it since it’s a major hassle to pull everything out?
      03-21-2020, 07:17 AM   #5
youbarajs
youbarajs's Avatar
Singapore
19
Drives: BMW M3 sedan, BMW 328i
Did anyone try removing this? Any learnings? I have dropped the top bracket holder on this black hole . Is it as easy as removing those 4 screws and the rubber buffers at the bottom?
Y
Reply
