The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Oil catch can installed
Reply
      07-11-2023, 01:35 PM   #45
The Nightman
Cometh
The Nightman's Avatar
1726
Drives: Boy's Soul
E90 LCI 330i  [10.00]
Originally Posted by jaysone90 View Post
1/2" Fuel Check Valve,Engraved with Flow Direction,Aluminium Alloy One Way Valve for Air Fuel Oil Diesel Gas E85 or Other Liquid Transfer Check Valve Car Parts (12mm) https://a.co/d/fwJaQbt
from catch to intake
Could you explain why?
      07-11-2023, 02:51 PM   #46
jaysone90
Drives: E90 (2006 330i)
Well if anyone wanted to ensure proper air flow and to ensure it goes one direction. Is it really needed? You of all would be a good person to ask. Doesn't hurt to install it, you just need to make sure you buy the right diameter one.
https://www.amazon.com/Check-Valve-B...s%2C354&sr=8-4
This is the only one I manage to fine that is a tight fit. By the way I got the hoses you recommended bro. Thank you for pointing that out to me as we speak I am doing this. I also got my inline check valve today but its too small so I will order that one.
      07-11-2023, 07:40 PM   #47
jaysone90
Done
      07-12-2023, 08:10 AM   #48
blingers
blingers's Avatar
Australia
27
Drives: Pre-LCI 130i
There is also the mishimoto check valve MMFT-CHKVLV-34
https://www.mishimoto.com/performanc...valve-3-4.html
      10-28-2023, 12:52 AM   #49
Chking_it_out
Drives: ‘21 BMW G20 330i
Catch can
Originally Posted by s5s View Post
I was about to install a catch can on 330i but I came across this video which seems to suggest you shouldn't:
Anyone have issues putting on a 330i G20 with B46d? I’ve browsed the threads about not installing, then of course there are lots that say it’s a must have; just checking for more opinions.
      11-05-2025, 01:06 PM   #50
Bhughes_32
Bhughes_32's Avatar
Drives: 2013 BMW E93 328i
Originally Posted by jonwilli View Post
I have just installed a GruppeM intake. Need to give it a drive once I refit my diff this weekend
How’d the intake setup do? And how is the catch can holding up?
Reply
