Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Tech Info: E90 330i N52 Three-Stage Intake Manifold
Reply
      04-12-2021, 03:11 PM   #925
DavidPayne
Drives: 2011 BMW 328i xdrive
Hi,
I plugged in the small disa, and when I press the gas pedal it does move a little at about 4500rpm, but it does not shut completely.
With inpa I had trouble, but it does make it move a little every once in while.
Does that mean it's shot?
I did not update the ecu yet.
Thx,
David
      04-13-2021, 07:19 AM   #926
Hotter
Hotter's Avatar
100
Drives: BMW E92 328i -> 330i
Does N52B25UL 753082806 from E60 2006 523i also works for 328i->330i?
From photos it has 2 hoses at the bottom.
      04-13-2021, 08:10 AM   #927
neilvan
neilvan's Avatar
Drives: 09 E90 335i M-Sport 6MT RWD
I mean it'll bolt on, but the 2.5L manifolds have smaller diameter runners than 3.0 versions
      04-13-2021, 08:57 AM   #928
Hotter
Hotter's Avatar
100
Thanks, I will use N52B30OL then, not sure which car it came from, but that should definitely fit correct?
      02-21-2023, 01:18 PM   #929
dragon-fly
Drives: BMW E91 BMW E46
I will have a manifold + disa and possibly ccv for sale soon, am located in Canada, Montreal area, anyone interested?
Car is probably getting totaled out from rear end collision.
      03-22-2023, 10:27 AM   #930
omarg
Drives: E92 328xi
I'm in Ottawa, on if you have that intake for sale I would be more than happy to take it
      03-22-2023, 10:37 AM   #931
dragon-fly
It's already gone.
Good luck!
      04-26-2023, 07:05 AM   #932
Arturas
Drives: 325i
2005 325i  [0.00]
Can anyone please elaborate on this?
I run european e90 325i 160kW '05, on a pillar B there's indication it's equipped with N52B25A which is ok. But I've looked into my intake manifold it clearly has something DISA'ish things on it. As I understand, it must not have these flaps since it's 2.5L. If not DISA's what is it then? Not su much familiar with BMWs
      04-26-2023, 10:39 AM   #933
vilord
Drives: E91, Tundra, TT, SV650
You do have a DISA manifold already. 2.5 did get it in some variants.
Jesse
      04-27-2023, 03:39 AM   #934
Arturas
Drives: 325i
2005 325i  [0.00]
Thanks for reply. If there're DISA's, then couple more questions.
- Does that mean I have physically same manifold as the one found on 3.0L 190-200kW versions?
- If the answer is yes, going further, does that mean it's enough to have current ECU flashed/mapped (or even replaced with another sourced from 3.0L together with CAS and key) to reach more than 160kW? I know I won't reach 190kW since it's 2.5L but heard rumours that even 2.5L versions benefit significantly.
      04-27-2023, 08:04 AM   #935
neilvan
neilvan's Avatar
Read 6 posts up on this page; I have a pic showing the difference between the 2.5L and 3.0L manifolds
Arturas16.50
      05-15-2023, 01:42 PM   #936
mattanderson
Drives: 2007 E92 328i
What's everyone doing for DISA valves in 2023? Bite the bullet and go genuine BMW from FCP Euro?
      05-17-2023, 09:56 AM   #937
Spence90
Spence90's Avatar
Drives: Bmw 330i
Most people recommend genuine only on disas just make sure any oil from ccv system is sorted or they'll keep failing
      07-17-2024, 05:32 AM   #938
Doreen
Doreen's Avatar
Drives: BMW M3 G80
yes, it makes a lot of sense
      07-18-2024, 01:22 PM   #939
firesnatch
Drives: 2008 328i 6MT
I was cheap and got the ones that were $50 each from Amazon. We'll see how long they last. If I end up with problems I'll try the cheapest ones from FCPeuro, since they'll replace them for free if they go bad. The big DISA is easy to swap out. There's no oil in my manifold.
EDIT: Update, I've replaced my $50 Amazon large DISA twice now in 3 months. I lucked out and found some OEM BMW ones from a u-pull-it yard that were in excellent shape, 2018 and 2017 dates on them. Car runs smoother for sure with the OEM ones.
      07-18-2024, 01:24 PM   #940
vilord
my small disa is apparently failed, and has been for months... i should probably do something about this.
what is recommended for "any oil from ccv system is sorted"? catch can added between the valve cover and the PCV heater port?
Jesse
      07-18-2024, 11:16 PM   #941
mattanderson
I took a different budget approach and bought 3 cheap N51 manifolds with original DISA's from eBay and tested the valves with INPA.
Out of the 6 DISA's, I found 2 fully working (1 large and 1 small, thankfully), so I'm running those.
If/when they fail, I might just convert to the N54 manifold. Gotta say the 3-stage torque is awesome, though. As is FCP.
      08-09-2024, 10:25 PM   #942
slow92now90
slow92now90's Avatar
Drives: 09 328i coupe > 06 325i sedan
Question, please forgive me if this is question has been answered
Has anyone done any testing with the 3stage + euro intake box and a tune?
ECS has the Euro N52 box which states being a "less restrictive" intake system, assuming this is true, would this not mean the airflow is 'freer flowing' and therefore able to take in more for the 3stage?
      10-19-2024, 12:10 PM   #943
alfredo330
Drives: 2009 BMW X5 xdrive 3.0i gas
N52 disa valves
Originally Posted by ksfrogman View Post
(1) Collector for intake air
(2) Resonating pipe
(3) Overshoot pipe
(4) Resonance pipe
DISA actuator motor
(1) DISA actuator motor
(2) Throttle valve
The actuator forms a unit with the drive. The actuator is driven by an electric motor and gearing. The control electronics are integrated in the DISA actuator motor. The DME controls the DISA actuator motor by means of a pulse-modulated signal. There are only 2 possible positions. The actuator can be closed or opened. When activated, the actuator moves the flap to each end position. Depending on the engine concerned, the N52 is fitted with 2 DISA actuator motors, or 1 DISA actuator motor, or without.
How it works
The power and dynamics of an engine depend heavily on the quality of the cylinder filling. The intake air mass oscillates due to the piston motion. These oscillations are overlapped in turn by oscillations from pressure peaks. To guarantee optimum air intake, the N52 engine has a three-stage differentiated air intake system (DISA).
The air intake guide is realized by a switchover mechanism in the inlet pipe with two DISA actuator motors and an overshoot pipe in the intake area. The DISA actuator motors are each driven by an electric motor. The two DISA actuator motors are of different sizes. DISA actuator motor 2 is fitted in the overshoot pipe and DISA actuator motor 1 is fitted in the collector for intake air in front of the resonating pipe.
1st stage - idling/lower engine speed range
At idle speed and in the lower engine speed range, the DISA actuator motors 1 and 2 are closed.
The intake air flows past the throttle valve into the resonance pipe. In the resonance pipe, the intake air mass splits. The air is fed via the collector pipe and resonating pipes into the individual cylinders. In this way, three cylinders are provided with a comparably high air mass.
2nd stage - medium engine speed range
In the medium engine speed range, DISA actuator motor 2 is opened.
In this case, it is assumed that the inlet valves of the first cylinder are just closing. The gas motion creates a pressure peak at the closing inlet valves. This pressure peak is passed on via the resonating and collector pipes to the in next cylinder in the firing order. This improves the filling of the next cylinder to be charged.
3rd stage - upper engine speed range
In the upper engine speed range, both DISA actuator motors are opened.
In this case, it is assumed that the inlet valves of the first cylinder are just closing. The gas motion creates a pressure peak in front of the closing inlet valves. The intake air mass is now fed via the resonating, overshoot and collector pipes.
EDIT: The firing order of the N52B30M1 engine is 1-5-3-6-2-4
Excellent explanation of the 3 stage manifold with dual DISA valves. However, could anyone with certainty please tell me what is considered to be DISA actuator motor 2 in the above quoted explanation? Would it be the smaller of the two DISA valves with part number 11617560538????
      10-21-2024, 09:24 AM   #944
firesnatch
Disa 1 is small DISA (Right)
Disa 2 is large DISA (Left)
      12-08-2024, 03:27 PM   #945
BlackBetty328
Drives: 2011 BMW 328i Xdrive
Looking for 3 stage DIY sticky
Sorry this forum is dense and I can't find what I am looking for.
Does anyone have a good link to a complete DIY of the Three Stage DISA conversion?
I have a 2011 328i Xdrive with manual transmission.
I have a used 3 stage intake manifold from an X3.
Is there a way to test the valves before you install? I am planning ot replace the DISA valves just to make sure I dont have to pull it and put in new valves. Unless its better to just try it with the used valves?
Where can I source the ECU reflash? Ive seen Bimmerlabs and ActiveAutowerk but I dont see it on active's website. I have a laptop do I need a special cabel beyond an OBD2 Cable?
How risky is this mod? How often do people brick their ECU?
Kind Regards from me and Black Betty.
      12-09-2024, 11:38 AM   #946
firesnatch
Youtube is a good resource for instructions on the entire process. You can test the DISA's with INPA. If you have ISTA software, you can test there as well. I have a ton of notes on the process. I should create a complete guide at some point. If you have questions, there are lots of people here that can help.
The flash is low risk. The only people that bricked their cars are people who did the flash with low battery. If you have an enhanced firmware cable, it will flash at twice the speed, so there is a lot lower risk of low battery issues.
Reply
