BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
How to code out cornering light
| 05-12-2017, 12:10 PM | #1 |
Rep 112
Drives: 2013 E92 M3
I have coded many cars but seem to be stuck on a set of errors that I cannot code out. Before you guys start crucifying me, I am not talking about side markers or corner LEDs. Thank you.
P. S i went up and down the nfrm3 module and there were no codes really pointing to cornering hot/cold checks. *2011 335d |
| 05-15-2017, 01:24 PM | #2 |
Rep 143
Drives: 2020 M340i
In the NFRM set the following to aktiv:
ERR_SCHWENK_L_IGNORIEREN ERR_SCHWENK_R_IGNORIEREN and the following to nicht_aktiv: KALTUE_FL_M2_6_M1_04 WARMUE_FL_M2_6_M1_04 That will ignore cornering light faults and turn off the bulb checking for those bulbs. You may want to try the first set, and if that doesn't work, change the second set as well.
2020 M340i | Mineral Grey Metallic | Premium | Exec | Adaptive M Suspension | Harmon/Kardon
![]() Previous: 2011 E90 335i | Black Sapphire Metallic | 2007 E90 335i | Monaco Blue Metallic |
jsanchez33576.50 6ixSpd6226.50 |
| 05-15-2017, 06:52 PM | #3 | |
Rep 112
Drives: 2013 E92 M3
| 05-16-2017, 05:20 PM | #5 |
Rep 143
Drives: 2020 M340i
Set KLS_BEI_AL_AKTIV and ALC_SCHWENK_LATCH to nicht_aktiv.
the ocho0.00 |
| 12-02-2018, 11:44 PM | #6 |
Rep 14
Cornering light issues on e92
Hi, I´m having cornering light malfunction (I have searched all the web without a solution) and maybe you guys can help me with your experience.
I have a 335i e92 2010. I changed the cornering light to an LED bulb (canbus error free) and I´m getting 00A8A9 (High beam and cornering broken right) and 00A8A8 (Defective main beam or cornering left), scanned with Carly. I tried to clean the fault codes with Carly but nothing happens (the fault error still there)... I was thinking on removing that cornering bulb and clean with carly and see if it disappear (because maybe is the module), and then connect the bulb again. Someone can help me? I appreciate!! Thank you! |
| 10-08-2019, 08:23 AM | #8 |
![]() 13137
Rep 1,965
| 10-08-2019, 08:37 AM | #9 |
![]() 15
Rep 109
so I upgraded the cornering lights to LED, there is an option to turn them off, but I'm trying to stop the voltage test so I don't get the error.
2009 e93 Black Sapphire
| 10-08-2019, 09:42 AM | #10 |
![]() 13137
Rep 1,965
I upgraded mine to LED as well. I never got the error, but voltage test on the cornering lights and my LED fogs, made the front of my car look like an emergency vehicle when I started the car. I'm just glad that I got it corrected before encountering anyone with photo-sensitivity. From what I remember I don't think you disable the voltage monitoring for the cornering lights with Carly. You can disable the cornering lights with Carly and then use your fogs as cornering lights.
| 10-08-2019, 12:48 PM | #11 | |
![]() 15
Rep 109
| 10-08-2019, 01:04 PM | #12 | |
![]() 13137
Rep 1,965
If you have LED fogs, you will also have the flickering during ignition unless you code that out to, which is an option in Carly. Even though I upgraded my cornering lights to LED, I found that my LED's weren't as bright as the factory halogens anyway. Plus, I had several people question me about my lights thinking that I had a bulb out when they saw on cornering light on. I played with several options and ultimately chose to do disable them. I no longer have my E93 and haven't used any other programs for coding, but I'm sure the voltage check for the cornering lights could be coded out, just not with Carly. Hope this helps. |
| 10-08-2019, 04:42 PM | #13 |
![]() 15
Rep 109
thanks that makes sense, I've upgraded the angel eyes and fogs to led and coded out the check. there last part was the cornering but at this point I might just turn them off.
| 12-11-2019, 10:14 AM | #14 |
![]() 15
Rep 109
I ended up putting resistors to fake the wattage of a regular bulb but still get error
| 01-16-2020, 08:36 AM | #15 |
![]() 15
Rep 109
at this point I'm just trying to turn them off, anyone have any idea how to do that I turned off all there cornering lights in Carly but still getting the error.
| 01-25-2020, 03:44 PM | #16 |
![]() 275
Rep 1,173
| 02-05-2020, 04:32 PM | #18 |
![]() 531
Rep 1,290
In bimmercode I did it in expert mode - footwell module to 3404 pwm-teil-1 to "PWM_FL_NSW_FKT_ABBLIEGEL" set to "wert_03".. Not sure if this is the same in Carly..
https://www.e90post.com/forums/showthread.php?t=1681232 |
| 05-31-2021, 10:11 PM | #20 | |
Rep 913
I'm in a 2008 E92 M3, got the cornering lights failure warning on the dash, and I think it's related to the left ballast unit, but I'm not willing to replace it for now, so, right now I just wanted to turn off the warning. I managed to find the following expressions and turned them to aktiv: ERR_SCHWENK_L_IGNORIEREN ERR_SCHWENK_R_IGNORIEREN But could not find the following: KALTUE_FL_M2_6_M1_04 WARMUE_FL_M2_6_M1_04 The module I went was NFRM. With only those first two, the warning kept on coming. What else could I look for? Maybe in another module? |
| 06-01-2021, 04:03 PM | #21 |
![]() 531
Rep 1,290
The code above is for FRM3 you need FRM2, all to nicht_aktiv
KALTCHECK_E89_FL__E7x_NSW KALTCHECK_E89_NSW__E7x_FL WARMCHECK_E89_FL_E7x_NSW WARMCHECK_E89_NSW__E7x_FL That should do, report back. |
| 06-02-2021, 08:09 AM | #22 |
Rep 913
Thanks for replying.
Both nsw__e7x_fl were already default set as nicht_aktiv And both fl_e7x_nsw were aktiv, so I changed to nicht_aktiv The others I returned all to default, and put the two ignorieren as aktiv again. Unfortunately the fault still came on. Last edited by jvictormp; 06-02-2021 at 08:23 AM.. |
| Bookmarks |
