TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > If you key falls from the slot, you may repair it this way
Reply
      04-08-2020, 02:40 PM   #1
Angelcma
Drives: 2006 BMW e90
So in my car the key lock was broken, this lead to the key falling on bumpy roads or in corners. I decided to remove the key lock and investigate and it turned out that a small leg or clip from inside the module was broken. I decided to use some epoxy clay to try to simulate the function of said broken part.
I am trying to do as many diy because I am currently locked down in quarantine
Hope this diy can some day help someone
      04-10-2020, 04:47 PM   #2
hvipa
Estonia
Drives: Pretty casual E90
Ohh that's clever. I just replaced mine week ago, got an used one for 15 pounds from fleabay
      04-10-2020, 07:34 PM   #3
Angelcma
15 pounds sounds great, in my country I couldn't find the replacement part. As an update, this has worked just fine. Same as new
Reply
