TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > E90 Brake Caliper Piston Boot DIY????
Reply
      04-05-2020, 10:38 PM   #1
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I'm looking for a DIY for a brake caliper piston boot. It has a metal ring inside the boot that's supposed to snap in place when you apply enough "even" pressure to it.
I'm wondering if any has seen a DIY either here or I. YouTube etc.
      04-06-2020, 03:34 AM   #2
bluewater328
Drives: 2011 bluewater 328i LCI sedan
This is for the F30 Msports, but its the same theory.
      04-07-2020, 05:37 AM   #3
juld0zer
Australia
486
Drives: Prev 135i 7DCT, Now 130i 6sp
Any popular car with ATE calipers will have a DIY that someone has written up. eg. Mazda3, Golf..
They are really easy but i wouldn't call it a 'snapping' sound. I've only done boots as part of a piston seal replacement. I usually fit the inner section of the seal onto the groove of the piston, lube up the outer ring and push the piston home with an object wider than the piston and (collapsed) boot like wood, jar lid, even bare hands. The metal part is in the side which goes into the groove in the caliper (if there is any. I haven't done an E90 personally but the Mazda3 had a metal core in the outer section)
      04-07-2020, 01:38 PM   #4
mweisdorfer
2008 bmw x5  [0.00]
I'm 99% sure that there is a lip on the caliper in which the metal ring in the boot must snap over for it to be installed correctly
      04-08-2020, 05:59 AM   #5
juld0zer
Australia
486
https://www.m3post.com/forums/showthread.php?t=1377763 This might give you an insight.
Here is an article about a Golf R32 which uses a very similae caliper to the 335i: https://www.thebeardeddetailer.com/blog/2019/7/18/mk5-volkswagen-r32-brake-caliper-rebuild?format=amp
It's not something we do every day but the last time, I managed with a block of wood and rubber grease or rubber care spray
Reply
