BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 oil leak. Valvetronic actuator?
Reply
      07-17-2019, 10:26 PM   #1
INTMD8
Drives: 2012 E91 manual
Any insight appreciated. I bought this car several years ago with about 130k and the valve cover was just done at that point.
Along the way I had the oil pan and oil filter housing done and it was solid for many miles.
Now at 190k it was leaking again and appeared to be the valvetronic actuator gasket, which I replaced and it did not help.
Did the valve cover gasket again and it's still leaking.
The void beneath the actuator is filled with oil so it seems to be coming from that area rather than the valve cover to head interface.
Has anyone had the actuator itself leak oil? That's what I'm leaning towards at this point but don't want to go that direction if it's not a possibility.
Also noticed the connector at the front of the valve cover is rather corroded.
Any suggestions on that? (Just clean it up?) Thanks!
[IMG]://imagizer.imageshack.com/img922/3650/1k0njF.jpg[/IMG]
      07-18-2019, 10:05 AM   #2
Volasko
Volasko's Avatar
742
Drives: 06 330i E90, 18 530xe G30
I can't remember the thread about this but I've seen others with similar problems with swapping out the actuator gasket and it still leaking. When I did mine I made sure I installed it with some liquid gasket maker + the new gasket and so far it has held up. I'd be very confident it isn't from the actuator its self and indeed the gasket. For what its worth I remember hearing that they updated the gasket design so maybe your continual issues are from the wrong part.
Edit:
Found the original thread in question
      07-18-2019, 12:16 PM   #3
INTMD8
Yes, looks like correcting the gasket holes plus rtv is my next move.
Thanks for the info, much appreciated!
Reply
