Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > DIY: How to setup BMW Standard Tools 2.12 w/Windows 10 x64 (64-bit)
Reply
      02-04-2016, 01:57 PM   #23
808AWD325xi
Ballin' out of control.
808AWD325xi's Avatar
No_Country
533
Drives: 2009 335i
Originally Posted by lE92l View Post
Awesome write up thanks for taking the time to put this together.
Thank you !! You're welcome.
Originally Posted by Chris_Rav View Post
So this install does not support the N55 engine in my LCI e92?
No, not quite. The only inherent limitation is with INPA.
In order to preserve English language localization to the greatest extent possible, this DIY utilizes the last English INPA scripts that the BMW Group released with INPA 5.0.2. INPA 5.0.2 did not include a script for the MEVD17.2 DME. That aside, all other functionality works as expected.
There are later German language INPA scripts available for that DME. I will PM you details.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
      02-13-2016, 09:30 PM   #24
scott60158
scott60158's Avatar
19
Drives: 2017 340i MPPSK
This guide is great, I am giving it a try now after I get the slow chinese download done. I havent had luck with other tutorials although I am very familiar with the windows environment... I hope this works.
Current: 2017 BMW 340i F30 B58 BSM Black Dakota Leather, MPPSK, Active Autowerke Catted Downpipe, MHD STAGE 2
SOLD 3/6/21: 2009 BMW 335i MANUAL E92 N54 MHD STAGE 2+
      02-14-2016, 01:25 PM   #25
scott60158
scott60158's Avatar
19
When I go to identifcation in INPA I get IFH-0009: No response from controlunit
When trying to code injectors I get Error #100 SYS-0010: INITIALIZATION ERROR API job error or no such result
These are the same errors I got with the other installations I tried... I'm starting to think my cable is not working but the clamps work???
      02-14-2016, 02:05 PM   #26
808AWD325xi
No_Country
533
Drives: 2009 335i
Hi Scott, it sounds like either the cable is faulty or you have a K-Line cable instead of a K+DCAN cable. Where did you purchase your cable from?
      02-14-2016, 02:56 PM   #27
scott60158
scott60158's Avatar
19
I ordered it from an ebay seller: autogadgets2015 it has a green circuit board and says K+DCAN. I have placed an order for the one stop electronics cable which is known to work. Hopefully its just a bad cable and my installation is fine?
      02-14-2016, 03:18 PM   #28
808AWD325xi
No_Country
533
Drives: 2009 335i
Most likely. The one-stop-electronics.com cable will definately work properly. Once you receive your new cable, please report back.
      02-15-2016, 07:35 PM   #29
Jozy
¯\_(ツ)_/¯
Jozy's Avatar
Singapore
176
Drives: R32 GTR
This source is also pre-tested and worked for me with MHD/Carly/NCS
https://www.bimmerstuff.com/collecti...le-with-switch
30FF
      02-20-2016, 10:06 PM   #30
Nitrousbird
Drives: '07 E92 335i 6MT
I messed around very briefly with a tablet running Windows 8 (ugh.) If I recall correctly, I needed to use the on-screen keyboard (osk) to depress the function keys in INPA.
I can confirm that no keyboard is needed for Win 10. Touch screen works perfectly.
      02-21-2016, 02:52 PM   #31
808AWD325xi
No_Country
533
Drives: 2009 335i
Exclamation DIY updated
A few updates...
Post #2 is now a BMW Standard Tools 2.12 FAQ:
http://www.e90post.com/forums/showpo...48&postcount=2
I will continuously update the FAQ over time.
Errata:
  • Added screenshots of the LADEN.BAT script execution in order to better illustrate the benign errors that will be displayed.
  • Added screenshots and steps to register the EDIABAS Windows ActiveX controls MSFLXGRD.OCX and RICHTX32.OCX. If this step is omitted, Tool32 will display a run time error 339 and fail to start.
  • Added an additional step to create the INFO.ENG file in order to avoid a nuisance error in WinKFP:
Code:
cd C:\EC-APPS\NFS\DATA\GDATEN
copy INFO.GER INFO.ENG /v
      02-24-2016, 07:51 AM   #32
Martin80k
Guest
n/a
Drives:
hello, i am confused about inpa, bmw standard tools, ediabas and the whole thing. i just need to diagnose my car 335d e92 and possibly with the least hassle. and i want to know if i have to download all the software here or if i can only install standalone inpa for diagnostics, as i dont want to do any coding. can somebody point me the right direction please ? my car has many many issues and i am trying to spend the least.
last failures included:
1.broken flywheel (mechanical problem, and very noisy one and also very expensive one (800 euro)
2.drive belt pulley failure (couldnt turn steering wheel, and smell of rubber, 500 eur)
3.before i had numerous other problems, basically every month something...
      02-24-2016, 09:20 AM   #33
808AWD325xi
No_Country
533
Drives: 2009 335i
Hello, I replied to you in the other thread.
      02-25-2016, 03:58 PM   #34
scott60158
scott60158's Avatar
19
I got my onestopelectronics cable and everything works now. I was able to code my injectors no problem. Thanks for the guide!
      03-02-2016, 10:45 PM   #35
808AWD325xi
No_Country
533
Drives: 2009 335i
Thank you for reporting back, scott60158 !!
      03-07-2016, 07:44 PM   #36
J. Dub
Bob Saget
J. Dub's Avatar
Drives: 2010 335i e92 N54 A/T
Jesus christ wealth of info in here. I'll have to come back and read all of this. Thanks OP
In memory of Robert E. Flynn (AR)
      03-08-2016, 08:36 AM   #37
houtan
houtan's Avatar
806
Drives: 2011 135i
2011 135i  [9.85]
Thanks for the info. In your post about identifying which daten you have, how do would I know it's v51? I do not see 51 anywhere in the data posted.
      03-08-2016, 05:00 PM   #38
808AWD325xi
No_Country
533
Drives: 2009 335i
You're welcome!
You're welcome. You can easily tell which integration level your SP Daten supports, that's what I covered in the FAQ. However, determining which SP Daten you have is not as straightforward. To the best of my knowledge, none of the files in the SP Daten state which ISTA/P version they're from.
You can get a rough idea by reviewing an ISTA/P version and I-level overview chart to determine which ISTA/P version(s) align with the integration level of your SP Daten. The chart for ISTA/P P3.57.4 is attached.
For example, if your SP Daten supports integration level "E89X-14-11-501" then you know it's SP Daten 54.3. However, if it supports integration level "E89X-15-03-500", it could be SP Daten 55.0, 55.1, or 55.2. In that case, there really isn't any way that I know of to easily narrow it down further.
Beginning with the F-Series, BMW replaced the former KMM database with the CIS database. From the best that I can ascertain, unlike the KMM data, the CIS data is not contained within the SP Daten. Otherwise in the example above, we could have at least been able to distinguish between 55.0 and 55.1 by determining the F01 supported integration level.
File Type: pdf P3.57.4_ISTA-P+VERSION+AND+I-LEVEL+OVERVIEW.pdf (560.2 KB, 8328 views)
      03-08-2016, 05:06 PM   #39
houtan
houtan's Avatar
806
Drives: 2011 135i
2011 135i  [9.85]
You're welcome!
Thank you. Great explanation. I coded my car a couple of years ago. In one day, I have learned more from your thread than over the last two years! lol.
      03-08-2016, 05:44 PM   #40
808AWD325xi
No_Country
533
Drives: 2009 335i
You're welcome! I'm glad to know that it helped you.
      03-18-2016, 02:03 PM   #41
EmirF121
Drives: BMW E60 530d
Hey guys!
I am a new member, I am from Bosnia so my English isn't very good.
808AWD325xi
I have come to the point where you suggest to reinstall Windows.
When I choose to reset windows in recovery tab it offers me two options:
1. Keep my files - Removes apps and settings, but keeps your personal files
2. Remove everything - Removes all of your personal files, apps, and settings.
What should I choose?
Thank you!
      03-18-2016, 02:34 PM   #42
808AWD325xi
No_Country
533
Drives: 2009 335i
Originally Posted by EmirF121 View Post
Hey guys!
808AWD325xi
Thank you!
Assuming that you have saved the INPA CFGDAT and SGDAT folders to a USB thumb drive, I would choose #2., remove everything.
      03-18-2016, 09:42 PM   #43
335isturbo
Drives: 335is
This has got to be the best DIY I have ever come across in my life. Not only was the DIY very comprehensive, but the OP was extremely helpful through PM. I was able to download and install despite being a total noob + hitting every obstacle along the way!
Thank you so much. Someone in OR get this man a beer!
      03-21-2016, 04:40 PM   #44
J. Dub
Bob Saget
J. Dub's Avatar
OP, what is your opinion of the self installing program? http://www.e90post.com/forums/showthread.php?t=1233568
Reply
Tags
bmw standard tools, coding, diy, inpa, winkfp
