Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > AFE Header Review. AFE high flow Cat Headers
Reply
      04-25-2015, 01:53 PM   #23
Isaiah5411
Isaiah5411's Avatar
Drives: 2008 Montego Blue 328i E93
I'm absolutely insane for getting into this discussion, but...I need a distraction today (it's raining, my tune is in , and I've been driving all morning) and, other than working out, thinking about modding cars is the healthiest.
First of all, let me get this straight - our choices of combinations when it comes to headers are:
1) Catless headers (e.g. AA), retaining the secondaries
2) Catless headers, removing the secondaries
3) Catted headers (e.g. AFE), retaining the secondaries
4) Catted headers, removing the secondaries.
Not to jack the thread, but here are some questions (say in a car with 3 stage manifold conversion, Euro airbox, PE and AA tune):
a) Clearly, #2 would yield the most power, right? But by how much over #s 1, 3 and 4?
b) How much less power than the others would you get if you chose #3? In other words, is this a horrible choice if you're looking for some noticeable gains?
c) If you have the PE and you're already concerned about the sound it makes, should any of these even be considered without plans to modify the PE, such as put in a resonator (e.g. Vibrant) or a small race muffler (e.g. Borla) where the straight midpipe is?
d) If smell is a concern (e.g. you have a convertible), is #1 still an option or is #3 really the only choice?
Thanks! Talk amongst yourselves.
2008 Montego "330i" /3.0 manifold /AA /Eurobox /PE /Alufelgen CS7 /Macht Schnell /Michelin PSS /XPel
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11)
      04-25-2015, 02:35 PM   #24
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
a)#2 most power - bad smell for daily car. Power gain of #3 catless I assume is like 5-10 whp 5-10 wTq more. This is based on Secondary deletes
b) based on my feel for these: up to 10 whp less than #1 Catless header + Secondary Catss. This is a main catalyc so its more restrictive or in a bad position. If the dyno surprises us and shows a power curve and top numbers similar to Catless + secondary cat then these are a great idea...
c,d I cant say
But I think question that needs to be asked is. For maximum power where should the Catalycs be: in the midpipe or on the exhaust manifold
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      04-25-2015, 02:53 PM   #25
TheTallJS
Member
TheTallJS's Avatar
Drives: Metallic Black 2006 325i
2006 BMW 325i  [0.00]
max power would be towards the exit, but then renders the cats pointless and might as well go catless.
Fly the BMW.
      04-25-2015, 03:37 PM   #26
hassmaschine
Drives: "NBO" 330i
Actually, what matters more is in the primaries and in the merge. With the cat located right at the merge, there's definitely a loss of scavenging effect (although less than the stock manifold design). The secondary cat would create some back pressure, assuming it's really a restriction - but the scavenging effect of the AA headers will be better regardless of the secondary cat.
Now if you swapped the 2nd cats for a y merge, then you would be on to something. Otherwise, replacing them with straight pipie won't make a lot of difference.
Also, BMW cats last a long time. They should easily do 200,000 miles.
      04-25-2015, 04:08 PM   #27
Tom Droze
Drives: 2012 BMW 328i (e92)
Originally Posted by TheAxiom View Post
Well?
If you are "welling" me, I gave it the old college try; in that I had everything disconnected and removed as per a header install write up TheSt|G had provided and I had three of the easier exhaust manifold nuts removed when I decided installing the headers really wasn't much fun, so I reassembled everything. However, I did manage to complete the secondary cat delete in the process. Part of my lack of enthusiasm is that I am only two days removed from having the flu for three days and I am still not feeling percent.
I will have the headers installed this week, I promise, as I know a good shop by my office with a few highly recommended BMW techs.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
      04-25-2015, 05:55 PM   #28
Isaiah5411
Isaiah5411's Avatar
OK, you gave it your best shot and we'll let you off this time IF you can provide us with a photocopy of a doctor's excuse. Now, rest up and feel better...you've got 72 hours to git 'er dun!
      04-25-2015, 10:26 PM   #29
mmmnot
Custom User Title
mmmnot's Avatar
Iran
421
Drives: E92 328i
Originally Posted by mlifxs View Post
any drone before or after?
After the headers, not too bad - after the secondary cat delete, yes. I do not mind it. I was told by a friend it sounds like a modded E46 M3. I don't know if that's good or bad - considering it still sounds like a BMW and not a Honda, I'd say good
They are a thing of beauty!
Now, for the BIG question, should I attempt the install tonight? Hmmmmm. . .
Haha! Told ya' so!
Originally Posted by NJ Krish View Post
Can't wait to see dyno with tune and IM. Great review! Also I agree with you on how awesome they look after the heat!
Also, shout out to CS majors haha
Thank you! They've stayed that color after over 3K miles.
Originally Posted by Eagle1oh7 View Post
I'm considering getting the aFe headers over the AA due to the emissions, but I'm still on the fence until such time when I do them later this year or next year.
Emissions has no concern with these, provided your state is NOT CA, where they are crazy strict with visuals.
Originally Posted by chris82 View Post
Nice review OP, they look as you say they do. I don't doubt AFE makes a great product
Very nice
Can't wait to see your results Tom Droze, I too have the N51
Thank you!
Originally Posted by andrey_gta View Post
OP not to discourage you. BUt don't know if you will see a 250whp number after manifold plus tune. That is maybe real headers territory if I recall correct.
I predict something like 235-240whp based on intuition.
Which tune will you do: a off road header tune or a typical manifold only tune? Will a tuner like AA allow header tune on this? Because Header tunes differ than just turning off the CEL, wonder if the 300 CEL can handle it...
Yeah, I understand what you are saying. Either way, I'm very happy over the gains, performance and mainly low to mid end torque. I'll for sure update when I get a proper dyno done as the car sits.
I did not need the off road tune, as per my research this is mainly needed for catless headers. It was their standard tune, with some feedback from one of my datalogged interstate runs at WOT in 4th. I did note of the header mod to AA as well as it reflected in the data I've logged, then sent back to them for a second, custom tune.
Well?
Well, well, well!
      04-25-2015, 10:31 PM   #30
mmmnot
Custom User Title
mmmnot's Avatar
Iran
421
Drives: E92 328i
Honestly, IMHO - it just depends on your purpose of the car. If youre trying to extract every single pony, then ideally the most straight pipe would be ideal. Header back with a nice straight pipe towards the end or side of the fenders. Again, in my humble opinion based only on my random thoughts and logic. I just wanted a better flow, louder sound and a nice crackle and pop, which I was able to accomplish without compromising any emissions issues or future headaches.
Speak more of this, would you? Does the Y pipe allow better flow? Any information/pics? Purdy please?
If you are "welling" me, I gave it the old college try; in that I had everything disconnected and removed....
Yeah, it's a real PITA. I did not even bother trying. I knew I'd just curse the time and pound my head against the wall. I hope you get it done at a good price. Again, it should be around 5 hours shop time.
      04-25-2015, 11:33 PM   #31
pinoye90
Philippines
86
Drives: 07-E90
The dyno graph on the AFE website states no tune necessary and will not cause a cel light. having the AA off-road tune would not be needed. The question is if AA can extract more power from this header? Someone local to FL should go and getter done!!!!
      04-26-2015, 09:30 AM   #32
justpete
Drives: '11 328i '19 M6
2019 BMW M6  [10.00]
2011 BMW 328i  [9.00]
That's what's going into my car after the cams, a Y collector followed by a 3" thinwall 304SS straight pipe exhaust with a low back pressure muffler or two, Coast Fabrication 17" glass packed with V-band clamps to make changing the packing easier every year. I _think_ Burns Stainless makes a Y collector with the correct spacing for the headers so it's a bolt-in but the rest of the exhaust has to be fabricated, typically by mitering and MIG welding the pipe so it angles back under the car to the stock tailpipe location. Then it's dropped, TIG welded together, and reinstalled.
No bends and minimum departure from a straight line line maximizes velocity, I think, and that's really all that matters. We'll be adding another type of Y adapter at the end so a couple of pieces of the 3" pipe can be added to duplicate the look of the PE tips but the usual termination is a single pipe with a slight turn-down to help with noise to meet track requirements.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
      04-26-2015, 09:46 AM   #33
Taskmaster
Japan
2539
Drives: M235i 6MT / E92 328 Msport 6MT
The biggest part of the exhaust system is going to be the Y pipe and the placement of it. Everything after it makes little to no impact on power.
      04-26-2015, 10:29 AM   #34
justpete
2019 BMW M6  [10.00]
Well, not necessarily. If not using a low back pressure muffler it's difficult to optimize flow velocity. Pipe diameter matters as does whether it's mandrel bent or mitered, etc. although it's not terribly critical. The Y-collector determines scavenging timing at the head so yes its placement is more critical than the others but its effectiveness can be reduced by poor downstream design choices, I think. You and hass know more about it than i do, I'm going by the results the guys at the shop have found by dyno'ing many many different exhaust configurations on their NA and turbo race cars.
      04-26-2015, 11:04 AM   #35
hassmaschine
Drives: "NBO" 330i
Right, it can be restrictive. But the stock cats are sized for the engne, so whatever flow restriction is present is minimal. It's no different than putting in an intake, the stock one is already pretty good so gains are minimal.
Headers make more power because they improve scavenging, have better merges, longer primaries, etc. If the only difference was the lack of cats, you could cut them off and make the same power as headers. While it will make a difference, headers still make more power.
      04-26-2015, 12:28 PM   #36
Isaiah5411
Isaiah5411's Avatar
So...in your opinion, is it worthwhile to replace stock with the AFE catted headers while leaving the secondaries? (Note: I have the PE on my convertible and don't want it much louder.)
      04-26-2015, 09:13 PM   #37
Taskmaster
Japan
2539
That's up to you - we haven't seen a real dyno proven increase, but they can/should add power. Otherwise those secondaries removed and that exhaust will probably be louder than you have now - Even with the AFE headers.
      04-26-2015, 11:32 PM   #38
pinoye90
Philippines
86
Drives: 07-E90
If I already have secondary delete with PE, adding AFE header would make it louder? I don't think it would be anymore louder than it is already. What's funny is after upgrading to stage 3 manifold the PE+secondary delete did get just a bit louder but tolerable.
Anyone have vids on PE+secondary+AFE header?
      04-27-2015, 01:11 AM   #39
Benan
Benan's Avatar
Sweden
Drives: E90 330i M-sport 6MT
The look mighty nice, but the arnt much diffrent to the OEM?
Or do US and Euro have diffrent headers? Mine look like this:
E90 M-Sport 330i N53 272hp w Dynomax VT Muffler & Mod. OEM airbox w Ramair filter
      04-27-2015, 11:47 AM   #40
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
Was it my DIY you referenced? If so, you should have felt free to PM me if you had any questions. AFE headers most definitely do not fall into my "tough shit you bought China junk" rule.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      04-27-2015, 12:25 PM   #41
jc5988
Taiwan
102
Drives: 2010 328i 6MT
yes, US has different and more restricted header design, AFE uses euro design but with 300 cell cat.
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
      04-27-2015, 12:50 PM   #42
TheSt|G
TheSt|G's Avatar
Euro version was also only used on pre-facelift euro cars.
      04-27-2015, 02:35 PM   #43
hassmaschine
Drives: "NBO" 330i
isn't the euro N52 rated at the same HP output as the US N52?
      04-27-2015, 03:04 PM   #44
TheSt|G
TheSt|G's Avatar
That's a pretty broad question, but to what it is relevant here, the N52 in Europe lost 6-7hp in the facelift when those headers changed to the worse US spec design.
Reply
