BMW 3-Series (E90 E92) Forum
M dynamic drive in iDrive in a 2009 335i
| 04-09-2017, 01:09 AM | #1 |
Rep 2,140
Drives: 2009 e92 335i MSport DCT
I activated the mdrive option in my cic but the individual settings are missing but is it possible? It seems that because the 1M has the options and the 335i has and the same or similar dme that it is possible ?..
Has anyone seen it done ?
When you doppelkaplung you doppel your fun.
| 04-09-2017, 03:58 PM | #3 |
Rep 2,140
So how do we add it ? Has anyone done it before ?
| 04-09-2017, 04:01 PM | #4 |
![]() 946
Rep 2,964
Read this, but remember this is retrofitting an M3. I wouldn't even want to guess how much this would cost on a 335i.
http://www.m3post.com/forums/showthr...=676825&page=9
'09 335D
'18 540i xDrive |
| 04-09-2017, 04:11 PM | #5 | |
Rep 2,140
| 04-10-2017, 07:33 AM | #6 |
![]() 946
Rep 2,964
And the control unit itself. Don't forget the M3 comes with a lot of this stuff standard that the 335 doesn't. In the M3 you're basically just enabling it. In a 335, you'd have to add the entire setup. Not cheap.
'09 335D
'18 540i xDrive |
| 04-10-2017, 02:46 PM | #7 | |
Rep 2,140
| 04-10-2017, 04:10 PM | #8 |
![]() 946
Rep 2,964
I was under the assumption there was some more hardware to be added. Who knows, though it's not something I've really looked into (sans for reading the thread I quoted)
Another thread about it.. http://www.1addicts.com/forums/showt...php?p=14033208
'09 335D
'18 540i xDrive |
Aus335iguy670.00 |
| 04-10-2017, 04:11 PM | #9 |
Rep 2,140
Thanks for trying in any case !
| 04-17-2017, 02:03 AM | #10 |
Rep 2,140
So today I noticed that the menu I had activated in CIC had some options
They seem to correspond the same as on an M3 with DCT.
| 04-17-2017, 09:08 AM | #11 | |
Ballin' out of control.
533
Rep 1,289
M Dynamic Mode (MDM) for instance is a function of the DSC module. The 1M uses a different ECU (DSCM80) than your E92, which likely has a DSC90. Servotronic will certainly not work if the vehicle isn't equipped with EPS. Like the DSC, ECU differences are possible. With regards to the DME, there are 1M-specific MSD81 firmware releases.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
Aus335iguy670.00 |
| 04-17-2017, 01:20 PM | #12 | ||
Rep 2,140
Where should I be looking for information. So I don't have to bother other people with questions ?
| 04-17-2017, 11:07 PM | #13 | ||
Rep 2,140
I'm mainly interested in Drivelogic which is to do with the DCT gearboxes. Nearly all e and f series DCTs use the same computer to run them. That includes the M3. There's 26 zb's in my daten folder....how can I tell which is which ?
| 04-17-2017, 11:52 PM | #14 |
Save the manuals!
6227
Rep 6,841
Drivelogic and shift lights will also never work as those are specific to the DCT hardware and software, and I'm 99% sure the 335i DCT firmware is totally different than the M3's. Not even sure if it can be flashed to M3 specific. There are lots of different firmware issues here.
This is a largely fruitless endeavour. |
| 04-18-2017, 12:22 AM | #15 | |
Rep 2,140
One guy has actually done it on N54 Can't find it for the life of me now but it can be done. The rest after that is going to be the hard part. We want the shift speed and the adjustability of the M3 calibration with the shift points of a 335/135. The part numbers for gearbox and mechatronics unit are the same. The GWS and DSC are different.... these are not insurmountable challenges.....
| Bookmarks |
