BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Bilstein B14 Too low?
Reply
      11-06-2025, 11:43 PM   #1
oZades
Drives: bmw 335i
Has anyone had issues with bilstein b14s sitting too low? I'm on 19s and have them set at the highest setting and my bumper is almost touching the ground.
Attachment 1Attachment 1
      11-12-2025, 10:22 PM   #2
cruizinmax
Drives: 99 Civic, 09 335i
Can you show the threaded collar on the shock? It seems like something could be wrong there.
      11-12-2025, 10:38 PM   #3
whyzee125
Drives: Dinan stage 2 335i
That's typical from what I've heard. You do have enough travel since that's how they're designed to run but they're still quite low. E30 perches or adding Dinan camber plates will increase your height.
      11-18-2025, 10:33 AM   #4
craz azn
Drives: '87 M3, '06 325i
I used to run a set of these back in 2021-2022. They are super low. I had my adjuster all the way up in the front, and it was still almost too low for my liking. The rear was somewhere in the middle, luckily lots of adjustment there.
Reply
