BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > E Series DATEN Requests
Reply
      09-04-2025, 03:07 PM   #815
Elusiveturtle92
Drives: e87 118i n46
Looking for MEV17N46 ipo daten
So im confused as of now because of the amount of conflicting information i keep finding so please correct me i am probably wrong
!!!!!USEFUL INFO!!!!!
i have a video thats 1h 30m long of the ecu being originally programmed from the car it came out of........ now its going back into that car
i can provide vin if needed
Engine type should be a N46B20BZ or N46b20 or N46nb20 or n46t i have seen so many different possibilities im confused
Hello im in need of help finding an older daten. looking for a daten containing a daten for N46 engine and MEV17.2.1 bosch ecu compatible with inpa 5.0.6 or if anyone reckons id be better off trying to get inpa 5.0.8
The daten version suspected of having the best chance of containing the file is v47 v47.5 v48 and v48.1 but if anyone knows better please let me know. if anyone has these you would be a life saver currently trying to get inpa working alongside my ncs and winkfp or if anyone has a standard tool set that can accept newer daten files beyond Inpa 5.0.6 that way i can search newer datens for the file i need
really appreciate it.
this is my first post to pms are closed unfortunately so a good email you can reach me at would be
broyojo2@gmail.com
really appreciate any help right now. making this post at 5am after being up all night trying 1001 dead links and many different forums. 7 hours later im stumped.
Last edited by Elusiveturtle92; 09-04-2025 at 03:47 PM.. Reason: adding uncertainty because brain now work at 6am
      09-11-2025, 03:08 PM   #816
Alenorm
Drives: 528i 2008 BMW E60, E39, E53
Originally Posted by wildcatcrazy View Post
Thought I'd start a new post that speaks to any version in case some is searching for a specific version. Post your request here and state what version you need (newest or older version). You'll receive a PM with the link to the version of your request (if it's still posted).
Just extra knowledge if I have three deferent cars with deferent I-level do I need to have multi versions? The oldest has I.e. E60-16-11-500 at the end can I find any info by reading the numbers? Or E90-00-00-000, etc. And how to know the latest ver to use for each car. God bless doing great work for all
      09-11-2025, 11:35 PM   #817
bigGloch
Drives: e90 330i
does anyone have a SPdaten file for e89 v55? i need to get my zb and can't because inpa can't read my gm transmission
and I've tried v60 v69 ect but the inpa v is to old or smthn.. if anyone can help that would be much appreciated
      10-14-2025, 10:39 PM   #818
RenArgent
Drives: BMW 525xi
Working through a 2007 525xi (E60) with CAS3 and persistent 4x4/DSC errors that refuse to clear in Tool32—faults reset instantly after a clear command.
I suspected corrupted CAS3 software might be part of the problem, but when checking my v74 E60 SP-Daten I noticed ZUSB 6943814 is missing (6943815 is 'earliest' present).
Before I try a reflash, I’m trying to confirm whether an earlier Daten set still includes that CAS3 package.
If anyone’s dealt with these 4x4 codes tied to CAS/DSC sync issues—or knows which Daten version retains 6943814—would appreciate some insight.
      10-22-2025, 05:23 PM   #819
Santiago1992
Drives: BMW 325i e90 GM6AT 2011
Hi, i need files for my 325i e90 steptronic 2011, GM6 gearbox for inpa… when i want enter to transmission module i have errors.
      11-13-2025, 12:42 PM   #820
sacbimmers
Drives: bmw 335i, bmw 328i,
hey fellaws i need sp-datens for e93 im having some catostrafic problems . not knowing the consequinces with pitting a combi with greater milage i got 101k instead of 57k . now i have even greater problem my dme went down so i do have a replasement from the same car with 101k so i nstalled dme cas combi i need to code in the right vin to dowload my tune on this dme so chat gpt been helping me out on this gerney. if i could get some sp-datens to fix this mess i would apriciate it greatly . i got a 07 E93 335i thanks in edvence . timan001@gmail.com
      11-18-2025, 07:46 PM   #821
sacbimmers
Hoping to get sp-datens for e93 335i 2007
Thanks in advance timan001@gmail.com
      Today, 10:42 PM   #822
jcmitch13
Drives: E90
Need e89 daten files any version prior to v60. PLEASE
53.3, 55, 56, 57, 58, 59 will do. Please help
Reply
Tags
daten, daten files
