05-05-2024, 11:48 AM | #1 |
Rep 77
Msport spring rates, kw v2 and kw v2 SC
good morning everyone.
I need to know the spring rates for my 440i rwd. I have adaptive suspension and I want to put Kw V2 or KW V2 SC suspension. Knowing the spring rates of these 3 suspensions, I will be able to decide which one to mount. My use is 90% road and 10% mountain and circuit. |
05-06-2024, 04:57 PM | #2 |
Rep 77
This is the response of kw between the hardness of the springs between V2 vs V2 sc.
The spring rates are down below for you. 1522000F Front: Around 226LBS./IN Rear: 629LBS./IN 1802000F Front: Around 226LBS./IN Rear: 572LBS./IN |
