12-06-2022, 09:43 PM | #23 |
Rep 6,977
Drives: 2022 DG/BLk xDrive M4C Wk 34
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
apptest2999.00 |
12-06-2022, 10:18 PM | #24 |
Rep 0
Not a bad idea, we will put this in consideration for sure. Still on the fence on this one
BMW is great
Limegrntaln13512.00 |
12-06-2022, 10:20 PM | #25 |
Rep 6,977
Maybe just a switch in settings for the option to do it. Default it on so we can turn it off.
YT: G Dubyou |
12-06-2022, 10:21 PM | #26 | |
Private2
2999
Rep 49
Drives: BMW M3 F32 Coupe!
Was that a one off thing for you or is it consistently happening? Or even ALWAYS happening?
Test 23456rt
12-06-2022, 10:23 PM | #27 | |
Private2
2999
Rep 49
Thinking out loud right now, the default will be the way it is now, and you would have to set it to skip confirmation as a setting. Keep an eye out for the next update either tomorrow or in a few days that will include that update, if it makes the cut it will be in the release notes 👍
Test 23456rt
12-06-2022, 10:24 PM | #28 |
Rep 6,977
I tried to reply 4 times in dark mode. Everytime I either tried to reply, or start a new post, it defaulted to white text. I turned off dark mode, for the night, so, I could use the app.
YT: G Dubyou |
12-06-2022, 10:26 PM | #29 |
Private2
2999
Rep 49
Can you totally close/shut down the app and open it from scratch (should see the blue splash screen at the start) and let me know if it is still white?
Test 23456rt
12-06-2022, 10:32 PM | #30 |
Rep 6,977
Still white. Closed and got the BP logo on the splash screen.
YT: G Dubyou |
12-06-2022, 10:37 PM | #31 | |
Private2
2999
Rep 49
Do you mind if I ask what phone and what iOS version you are on so I can try to drill down on what is going on there? Anyone else out there having dark mode issues? **** EDIT: I looked at the top of your screen shot—- duh I know what it is. iPhone 14pro and iOS 16 I’m using it on the same device and it looks great, but I did make a change that might fix it for you, look for it in the next update in the next day or two
Test 23456rt
12-06-2022, 10:49 PM | #32 |
Rep 6,977
Attached
YT: G Dubyou |
12-06-2022, 10:50 PM | #33 |
Rep 6,977
Also back in darkmode
YT: G Dubyou |
12-06-2022, 10:59 PM | #34 |
Private2
2999
Rep 49
Thanks. Yes that is no dark mode at all. Not exactly sure what the issue is since I’m not seeing that on a simulator or my own phone.
Anyone else out there seeing this? Are you using the auto bright -> dark mode or the fixed dark mode?
Test 23456rt
12-06-2022, 11:03 PM | #35 | |
Rep 6,977
Also, when you attach an image, there is no return to message button. I have to swipe down after I upload a picture, because once you attach a pic, it doesn’t automatically go back to the message to type.
YT: G Dubyou |
12-06-2022, 11:52 PM | #36 | |
Private2
2999
Rep 49
That’s one weird bug I have to say— Never seen it before and the app has been in production for a long time on the Android side without anything like that happening. Maybe it has to do with auto change. Like you started using the app when it was on bright mode, and then when it auto switched to dark it got confused. The app right now wont auto switch, it has to be totally closed and exited and restarted to take on whatever mode you are in. I will have to work on getting it to auto adjust for a future version for sure As for attachments, that’s on purpose in case you want to add multiple attachments. If it auto closed and you wanted to add 3 pics, it would be a pain in the *** to have to keep reopening it to add another pic
Test 23456rt
12-07-2022, 12:43 AM | #37 | |
Rep 6,977
YT: G Dubyou |
apptest2999.00 |
12-07-2022, 08:03 AM | #38 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Can’t find the search functionality ???
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium63575.00 M5Rick60359.00 |
12-07-2022, 02:14 PM | #40 |
Rep 397
Drives: 2019 M4
After reading and then closing a post app returns to top of postings list instead of holding its place. iPhone 12 mini iOS 16.1.1.
2019 M4 Coupe MG SS DCT ZCP
2015 M4 Coupe MG SS DCT (Trade) 2009 335xi Coupe Dinan Stage 2 (Sold) 2003 M3 Coupe (Sold) 1998 M3 Sedan (RIP) |
12-08-2022, 09:50 AM | #44 |
Rep 5,384
Drives: 2022 Aventurin/SS G82 xDrive
I've posted in the G80 forum and on the Bimmerpost FB page, but I have been having a ton of issues since the update. Got logged out on all my devices, and it took me 12+ hours to reset my PW (with all the timeouts), finally got the PW reset with my iMac, but I can't sign in on the iOS app (iPhone or iPad) and I can't even sign in on Safari on my iPad. I hardly use my iMac, so that means I won't be able to be as active in the community as I used to be. Any help? Anyone else with similar issues?
Also, FWIW, things I have tried: deleting and reinstalling the App, rebooting both devices, clearing cache, etc. Pretty frustrated right now. |
