F30POST
F30POST
2012-2015 BMW 3-Series and 4-Series Forum
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > F31 tow hitch automatically closing after extending
Extreme Powerhouse
      03-18-2021, 08:31 AM   #1
user8172726
Drives: F31 318d
Hello, does anybody know why it automatically returns back to its normal position and not staying extended? It remains approximately 1 second extended and than it closes... Fuses checked and no problem...
It's original electronic device - no retrofit.
Any help would be appreciated.
Maybe better than my description:
https://youtube.com/shorts/htSy0_z_rU0
      03-22-2021, 09:05 AM   #2
user8172726
Drives: F31 318d
Nobody?
      03-23-2021, 01:26 PM   #3
user8172726
Drives: F31 318d
Nobody?
Really nobody?
      03-25-2021, 12:14 PM   #4
user8172726
Drives: F31 318d
Nobody?
Really nobody?
Still nobody?
      03-25-2021, 02:40 PM   #5
zeikei
Finland
125
Drives: F36
Start by getting fault codes read with ISTA. I think there are also some service operations you can run with ISTA for the tow hitch. Based on how it comes all the way out it might be enough to take it apart and clean & lubricate the internal parts. Broken teeth of the internal gears usually gives different symptoms.
      03-25-2021, 07:20 PM   #6
jackstrath
Scotland
662
Drives: 16' F31 340i & 03' Focus RS
Light going red?
Should get a message on the dash..
Button isnt getting stuck is it?
      03-25-2021, 08:00 PM   #7
masterzapper
Drives: 328i X Touring
Was this an OEM option?
      03-26-2021, 11:04 AM   #8
user8172726
Drives: F31 318d
Thank you very much for your replies. Yes, it's OEM. All the time green light blinking. No strange sounds... however, in my idrive is the tow hitch not mentioned.
      03-26-2021, 01:22 PM   #9
masterzapper
Interesting. I didn't know that was an option. Check to see if there is something protruding it, or preventing it from locking in place.
      05-02-2024, 04:18 AM   #10
donataz1123
Drives: f30
did anyone manage to solve this issue? this is so bizarre
f30post
