05-19-2024, 04:24 AM | #4225 | |
Rep 790
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
05-19-2024, 06:56 AM | #4226 | |
Rep 60
I will do a re flash, add some more E and then do another run. I'm located in Sweden, and our fuel is known to be bad. But that doesn't really explain why my stage 1 tune with less E runs better. Maybe higher boost/lower timings. I'm thankful for any other suggestions. |
05-19-2024, 10:35 AM | #4227 |
Rep 228
Yeah as you say, flash stock, use stock gap, check for any fault codes, and do a log while stock. Start from there
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
05-19-2024, 05:58 PM | #4228 |
Rep 69
MHD Stage 2 HPFP Logs & Dyno Chart
So I had a couple of runs on one of the UK's most conservative dynos at the weekend. First run was MHD Stage 2 HPFP 95 Ron; second run was MHD Stage 2 HPFP 98 Ron. Tesco Momentum 99 Ron fuel was used in both runs and with no ethanol. Only hardware modifications were a 4.5" 200 cell downpipe and TU HPFP.
See both logs below and accompanying chart. Hopefully this might be useful but comments would be welcomed! Note how things seem to plataeu a little early on the 98 Ron map, around 5200rpm? I'm undecided if I should just run the 95 Ron map in the longer term or add ethanol on the 98 Ron. This car is my daily driver and I'm not sure if I want to be adding an extra £15 per tank when the benefit isn't actually that much? There was an M140i there too with the exact same MHD map, same fuel, same TU HPFP but had a 4.5" decat, rather than 200 cell. His peak power was 456 bhp. His graph looked identical to mine in every way. I have seen his logs too and they are very similar, albeit with slightly worse timing corrections. Dyno chart is flywheel figures. https://datazap.me/u/simonocr/2024-0...og=0&data=3-17 https://datazap.me/u/simonocr/2024-0...0&data=3-17-43 Last edited by SimonO; 05-19-2024 at 06:15 PM.. |
IMS-340C400.50 |
05-19-2024, 11:24 PM | #4229 |
Rep 3
Hey y’all, in the middle of tuning my 340i right now, car is on a ds25 and e50 mix, how’s this log look to y’all?
https://bootmod3.net/log?id=664abdced333f04fe73d5dad |
05-20-2024, 01:49 AM | #4230 |
Rep 60
I have now reflashed stage 2. This time BM3 asked me to download stage 1 map before flashing, which didn't happen before. I also set all the settings to OEM or otherwise without leaving them on "choose".
The log looks a bit better, but I think the power is still down. Do I have to high expectaions or are the timings actually low? https://www.bootmod3.net/log?id=664a...2aed60cedf4296 |
Yesterday, 01:06 PM | #4231 | |
Rep 1,016
Thanks for the info very useful, both logs say HPFP 98 as there is no HPFP 95 map in existence but surprisingly the 2 maps produce totally different boost levels.
The 2nd log with higher boost doesn't look too good I recommend adding ethanol to fix it. Did you take that log while the car was on the dyno ? Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
Tunes: Self Made Tunes - MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=...33-34-35-36-37 |
Yesterday, 04:23 PM | #4232 | |
Rep 69
Yes, both logs were taken on the dyno - the 2nd log may have suffered due to increased IATs. I'm going to try another log on the road this week. Thanks for the advice - I need to go down the rabbit hole on octane booster vs ethanol |
Yesterday, 05:39 PM | #4233 | |
Rep 1,016
Yeah this explains it though confusing as Stage 2 95 is not a HPFP map.
The logs also show the importance of ignition timing, 15.3 psi / 11.5 degrees almost equal same power as 17.3 psi / 9 degrees. I would definitely go the Ethanol route. Quote:
