The Tire Rack
BMW 3-Series (E90 E92) Forum > BIMMERPOST Universal Forums > Site Related Announcements - Suggestions - Feedback - Questions > Bimmerpost App 5.x WIP for Android
Reply
      05-27-2022, 09:42 AM   #485
apptest
all I do is test!
apptest's Avatar
4584
Drives: I lost count of how many
Originally Posted by MadBimmeRad View Post
It was from SUBSCRIPTIONS section
FWIW, I'm running v33
As for forcing it to misbehave, not really, it happens at random. It often happens when I'm replying to a post (where the page doesn't scroll up which means I can't see what I'm typing).
Then I check my reply and often Google has done an autocorrect on me which means I have to edit, and correct my reply.
The red font with yellow underline appears at this stage. I've had the red font on other occasions but it's not frequent.
So it goes like this, if the screen doesn't scroll, then edit will go red font, guaranteed. But, getting a red font doesn't just happen with the window not scrolling.
Ok I think I figured out how to make it happen, its happening when the app is closed, and you get a push notification and tap that to open the app and view the post/thread. Then if you try to use the drop down the red/yellow occurs.
Ok now to work on the fix…
Test 23456rt
      05-27-2022, 09:51 AM   #486
zcp312
///M
zcp312's Avatar
Drives: 2011 E90 M3 ZCP
Originally Posted by zcp312 View Post
Feature request - when searching on Google or any search engine on your phone and clicking into the search link for one of the forum threads, it opens in the browser, there is no popup asking if you want to open the thread in the app. This would be very helpful to open the threads in the app instead of staying in the browser.
Originally Posted by apptest View Post
That's a great suggestion! Its on the list for future work 👍
Any updates or eta on this feature?
      05-27-2022, 10:15 AM   #487
apptest
all I do is test!
apptest's Avatar
4584
I’d say another month best case, but it is very high on the list
Test 23456rt
zcp31297.50
      05-27-2022, 01:20 PM   #488
apptest
all I do is test!
apptest's Avatar
4584
Ok I have released version 5.2.34 with the above recent fixes 👍 (… I hope!)
I also added a new feature where you can go to the next page in a thread by pulling the screen up when you reach the end of a page.
Try it out and see if you like it and it works for you all, its experimental for now
Test 23456rt
      05-27-2022, 02:32 PM   #489
titomi
titomi's Avatar
No_Country
937
Drives: X3 G01 30i xDrive
2018 X3 G01  [0.00]
Originally Posted by titomi View Post
Can't see the user name in the notifications in dark mode. It's visible in the light mode.
Fixed. Thanks.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
apptest4583.50
      05-27-2022, 02:39 PM   #490
titomi
titomi's Avatar
No_Country
937
2018 X3 G01  [0.00]
I'm in the notifications section, open the notification, and then press back button, it takes me straight to the news page. Shouldnt it take me to the notifications section main window?
Or if I press the notifications button, it should do the same (open main window of the section)
      05-27-2022, 02:47 PM   #491
apptest
all I do is test!
apptest's Avatar
4584
Is this for a notification that you clicked on from a push notification and opened the app that way, or were you already in the notification page and clicked to open a thread?
Test 23456rt
      05-27-2022, 02:55 PM   #492
titomi
titomi's Avatar
No_Country
937
2018 X3 G01  [0.00]
Already in the page.
      05-27-2022, 03:26 PM   #493
titomi
titomi's Avatar
No_Country
937
2018 X3 G01  [0.00]
Android button on the phone (Samsung, Android 11). It behaves the same when I open the thread directly from the notification.
apptest4583.50
      05-27-2022, 08:18 PM   #494
MadBimmeRad
MadBimmeRad's Avatar
Australia
7135
Drives: M235i, 420i, and now the M2 CS
There's an arrow on top left hand side of the page to go back within the notifications. The Android back button on the bottom left hand side takes you back to, what I'd call, the root directory which is the news page
M2CS,
The second coming of ///M!
apptest4583.50
      05-27-2022, 09:10 PM   #495
apptest
all I do is test!
apptest's Avatar
4584
Ok this was a great report. I believe I’ve fixed the issue and it revealed some larger issues we had with push notifications, which I’ve also fixed.
Tapping on push notifications when the app is closed should be much improved for taking you directly to the notification (for example opening a post or PM).
I’ve just released version 5.2.35 which contains the new fixes, let me know if its still not working for you
Test 23456rt
titomi937.00
      05-28-2022, 12:58 AM   #496
titomi
titomi's Avatar
No_Country
937
2018 X3 G01  [0.00]
I know about that. But is that the desired behavior for the Android button ? Looks like developers agreed with me, that it's not.
      05-28-2022, 01:16 AM   #497
titomi
titomi's Avatar
No_Country
937
2018 X3 G01  [0.00]
I believe it's fixed, at least for the part I reported (Android back button now takes you back to the notifications section)
Good job!
apptest4583.50
      05-28-2022, 01:56 PM   #498
apptest
all I do is test!
apptest's Avatar
4584
Looks like the performance went down with the latest updates. The app is slower, when I owned after some time. It takes longer to load forums list, forum threads, news, etc. I'm on the latest version and wifi connection, using Samsung device with Anddiid 11.
Hi, I just released version 5.2.36 which tries to clear memory a lot faster then before. Maybe this has to do with what you mentioned, as I think you are saying performance gets worse over time? The more you use it the worse performance gets correct?
Try 5.2.36 and see if it improves performance for you at all?
Test 23456rt
      05-29-2022, 03:29 AM   #499
titomi
titomi's Avatar
No_Country
937
2018 X3 G01  [0.00]
It's worse I really need to download an app and make a screen recording. Samsung removed the native option.
apptest4583.50
      05-29-2022, 10:45 PM   #500
MadBimmeRad
Australia
7135
I'm no longer helping push notifications even though it's selected in my app and shows as active
M2CS,
      05-29-2022, 11:51 PM   #501
apptest
all I do is test!
apptest's Avatar
4584
I recently made some changes with push but was hoping it didn’t affect anyone. Maybe it did. You could try to either click on repair push notification option or just turn push off and then turn it on again and see if it helps?
Test 23456rt
      05-30-2022, 01:49 AM   #502
MadBimmeRad
Australia
7135
Somehow, it's stated behaving again (without intervention)
M2CS,
apptest4583.50
      05-30-2022, 01:50 AM   #503
apptest
all I do is test!
apptest's Avatar
4584
That's always the best solution 👌
Test 23456rt
      05-30-2022, 12:27 PM   #504
titomi
titomi's Avatar
No_Country
937
2018 X3 G01  [0.00]
When opening this thread from the news page, it remains open for a few seconds and then the app crashes, without any warning or information. Tried it numerous times. Didn't noticed this anywhere else.
apptest4583.50
      05-30-2022, 01:24 PM   #505
apptest
all I do is test!
apptest's Avatar
4584
I’ve never seen more images in a single thread before. So I think that’s the reason. Maybe your device is running out of memory in some way. My Samsung S20 is doing great with it, but I’m going to investigate this some more.
How are your other issues doing with the endlessly loading circles, are they now resolved after yesterdays update?
Test 23456rt
      05-30-2022, 01:32 PM   #506
titomi
titomi's Avatar
No_Country
937
2018 X3 G01  [0.00]
It's back to how it was, so better. You might be right about my phone. It's sometimes very laggy, which wasn't the issue before. Although it says the I have plenty of memory (both of them).
apptest4583.50
Reply
